IBM ThinkPad i Series 1400 1500 Hardware Maintenance Manual
The ThinkPad i Series 1400/1500 Hardware Maintenance Manual is IBM's hardware maintenance manual for the ThinkPad i Series 1400 and 1500, machine type 2621, First Edition (September 1999). The preface describes it as service and reference information "for IBM ThinkPad i Series 1400/1500 (2621) products". The PDF has 108 pages: the edition notice, preface and contents (pp. ii-vi) and 103 numbered pages. There is no cover page, and no part number is printed anywhere in the file.
Contents
Page numbers are the manual's own.
  • Preface (pp. iii-iv): related publications, the Mobile Systems HMM Volumes 1 to 4 with their part and form numbers, and a list of ThinkPad diagnostic and maintenance diskettes.
  • Introduction (pp. 2-18): important service information and FRU replacement strategy (p. 2); drive and diskette compatibility matrix (p. 3); safety notices in English, French, German, Italian and Spanish (pp. 4-10); safety information (p. 11); laser compliance statement (p. 16).
  • Read this first (p. 19) and FRU replacement notices (pp. 21-23): LCD replacement notice with IBM's dead-pixel limits, screw notices, system board replacement notice.
  • Related service information (pp. 24-27): power button as reset switch, low-level format, service web site, passwords (p. 24), power management (p. 26), Fn key combinations (p. 27).
  • Checkout guide (pp. 28-32): testing the computer with PC-Doctor, power systems checkout (p. 30).
  • Product overview (p. 33), status indicators (p. 34) and FRU tests (p. 36).
  • Symptom-to-FRU index (pp. 38-43): numeric error codes and messages, and symptoms grouped as LCD, keyboard/TrackPoint, indicator, power, memory, audio, PC Card, power management, peripheral device, modem, intermittent and undetermined.
  • FRU removals and replacements (pp. 45-83): from the battery assembly and CD player panel to the system board (p. 67) and bottom case, then the LCD bezel, LED board, inverter, microphone cable, hinge and rear cover and FPC assembly separately for the 12.1-, 13.0- and 14.1-inch displays. The backup battery is on p. 61 and the DC-DC charger board on p. 66.
  • Locations (pp. 85-88): front, rear and bottom views and switch locations.
  • Parts list (pp. 89-101): system FRUs (p. 89), LCD FRUs (p. 92), keyboards (p. 98) and common parts, including AC adapters and power cords by country (pp. 99-101).
  • Notices (p. 102) and trademarks (p. 103).
The manual works at FRU level. There are no schematics, no board layouts and no component values; the system board ("planar") is one part number per processor and TV-out option (p. 90). The only capacitor mentioned is the "bulging capacitor" hazard in the safety inspection guide (p. 14). Unlike later ThinkPad manuals it has no backup battery voltage check.
What it settles
The product overview (p. 33) lists Intel Celeron processors at 400, 433 or 466 MHz, two DIMM slots with no memory on the system board, and 12.1-inch SVGA TFT, 13.0-inch SVGA HPA or 14.1-inch XGA TFT displays.
The power systems checkout (pp. 30-32) gives these figures. The AC adapter should read 15.5 to 17.0 V dc at pin 1 of its plug. The battery pack is discharged if it reads below 10.6 V (Li-ion) or 9.6 V (NiMH); above that, the resistance between terminals 5 and 7 must be 390 Ω (Li-ion) or 10 kΩ (NiMH). The step text says to measure between terminals 1 (+) and 7 (−), but the terminal table on the same page gives terminal 1 as ground and terminal 7 as BT+ (p. 32).
The system board replacement notice (p. 22) puts the serial-number EEPROM on the inverter, not the system board. After a system board replacement the system unit serial number is restored with the ThinkPad Hardware Maintenance Diskette version 1.60.
The password section (pp. 24-25) says there is no override for the setup (supervisor) or hard disk password: a forgotten setup password means replacing the system board, a forgotten hard disk password means replacing the hard disk. A power-on password on its own is cleared by removing the backup battery for 20 minutes, or by shorting it with a screwdriver for one second.
The screw notices (p. 21) refer to screw kit P/N 05K4841; the parts list gives the i Series 1400/1500 screw kit as P/N 08K5877 (p. 92). The power cord table (pp. 100-101) gives IBM's cord part numbers by country, for example 76H3518 for most of continental Europe, 76H3524 for the United Kingdom, Ireland, Hong Kong, India, Malaysia and Singapore, and 76H3528 for Switzerland and Liechtenstein. The Danish cord is 76H3520, but a note says that as a consumer product the 2621 was supplied to Denmark with 76H3518.
Download: IBM ThinkPad i Series 1400 1500 Hardware Maintenance Manual.pdf
