Nintendo Super NES Technical Manual (Playtronic, Rev. 01-94)
The Manual Técnico do Super NES (Rev. 01/94) is Nintendo's own service manual for the Super Nintendo Entertainment System and Super Famicom, published in Portuguese by Playtronic, Nintendo's licensed manufacturer and distributor in Brazil. It is one of the very few pieces of Nintendo 16-bit service literature to survive in a complete form, and it is the primary source for the board-level diagnostic tables used on this wiki's Super Famicom pages.
Contents
  • System overview — console, controllers, Super Scope, Game Paks
  • Console theory of operation, with the board divided into its functional sections
  • Console diagnostic table — malfunctions and probable causes, in Nintendo's order of priority
  • Colour-fault and image-fault diagnostic trees
  • General disassembly instructions for the console
  • The GPM mainboard revision and what changed on it
  • Sound module, controller, SNES Mouse and Super Scope 6 sections, each with its own test procedure, diagnostic table, exploded view and parts list
  • Parts lists with Nintendo part codes, including the 1.5 A axial fuse and the 7805 regulator
Notes for readers outside Brazil
The manual was issued for the Brazilian market, so its alignment figures are PAL-M. The master clock adjustment at TC1 is specified as approximately 21.453666 MHz, not the 21.47727 MHz of an NTSC or Japanese machine or the 17.734475 MHz crystal of a European PAL SNES. Everything else in the manual — the diagnostic tables, the disassembly sequence, the component designators and the parts lists — applies across the range.
Download
Download the Manual Técnico do Super NES here: File:Manual Tecnico do Super NES Rev 01-94.pdf
Used by
