Power Macintosh 7200 Series/WS 7250 Service Source
The Power Macintosh 7200 Series/WS 7250 Service Source is Apple's 158-page service manual for the Power Macintosh 7200/75, 7200/90, 7200/120 and Workgroup Server 7250/120. The PDF was created on 22 March 1996. Page numbers below are PDF pages.
It is module-level: Apple's specifications, symptom charts, take-apart procedures, upgrade procedures and an exploded view with part numbers. It has no schematics and no component values.
Specifications as Apple prints them
[edit | edit source]| Item | As printed | Page |
| CPU | PowerPC 601 at 75 or 90 MHz (7200/75, 7200/90; system software 7.5.2 or later) or 120 MHz (7200/120, WS 7250/120; 7.5.3 or later, 7.5.3 Revision 2 for the 8× CD configurations); built-in FPU and 32K cache | 30 |
| RAM | 8 or 16 MB standard; 168-pin, 64-bit, 70 ns or faster DIMMs; 256 MB maximum | 31 |
| ROM | 4 MB, in a ROM SIMM slot or soldered to the logic board | 31 |
| Line voltage | 100–240 V AC (7200) or 100–270 V AC (WS 7250/120), RMS single phase, "automatically configured"; 50–60 Hz | 39 |
| Maximum power | 150 W, excluding the monitor | 39 |
Contents
[edit | edit source]- Basics: Overview (p. 3), Configurations (p. 7), PowerPC 601 Microprocessor (p. 8), Peripheral Component Interconnect (PCI) (p. 9), Dual In-Line Memory Modules (DIMMs) (p. 10), Memory Configurations (p. 11), Ethernet Support (p. 14), GeoPort (p. 15), PC Compatibility Cards (p. 16), The Cuda Chip (p. 17), Resetting the Logic Board (p. 18), Rear View Diagram (p. 20), Power Macintosh 7200 Logic Board Diagram (p. 22), Workgroup Server 7250 Logic Board Diagram (p. 24), Repair Strategy (p. 26), Ordering (p. 27), Warranty and AppleCare (p. 28)
- Specifications: Processor (p. 30), Memory (p. 31), I/O Interfaces (p. 32), I/O Devices (p. 34), Video Support (p. 35), Disk Storage (p. 36), PC Compatibility Card (Optional) (p. 37), Electrical (p. 39), Physical (p. 40), Environmental (p. 41)
- Troubleshooting: General (p. 43), Cleaning Procedure for Card Connectors (p. 44), Symptom Charts (p. 45)
- Take Apart: Top Housing (p. 69), Bezels (p. 72), CD-ROM Drive (p. 74), Floppy Drive (p. 78), Hard Drive (p. 83), Chassis Latch (p. 87), Drive Rails (p. 89), Battery (p. 92), Power Supply (p. 96), Speaker (p. 105), Power Actuator (p. 109), PCI Covers (p. 111), Rear Panel (p. 114), PCI Cards (p. 118), VRAM DIMMs (p. 121), Logic Board (p. 127), Processor Fan (p. 135), Bottom Chassis (p. 140)
- Upgrades: PC Compatibility Cards (p. 143), Power Macintosh 7600 Upgrade (p. 144)
- Exploded View (pp. 157–158)
Notable content
[edit | edit source]The Electrical page says the supply is "automatically configured", then adds: "the power supply has two voltage settings: 115V and 230 V. The power supply must be set to 115V in the U.S." (p. 39). Check the setting on any machine of unknown history.
The Basics chapter describes the Cuda microcontroller, which handles soft power, resets, PRAM, ADB and the clock, and its reset button (p. 17), and the logic board reset: unplug the computer, remove the battery, disconnect the power supply cable from the logic board, press the Power On button and wait at least 10 minutes (pp. 18–19). The Troubleshooting chapter starts with cleaning residue from PCI card edge connectors with a pencil eraser (p. 44). On some 90 and 120 MHz machines a fan plugs into the logic board at J70 and must be unplugged when the internal chassis is swung open to reach the battery (pp. 93, 95).
[edit | edit source]- No schematic, no parts list below module level, no component values.
- No Adjustments chapter, no rail voltages and no battery voltage threshold; the battery appears only in Take Apart and in the logic board reset.
Pages that cite this document
[edit | edit source]- Apple Workgroup Server 7250: WS 7250 configuration, line voltage, memory and the 1.2 GB drive fault.
- Power Macintosh 7200: models, specifications, power supply and service parts
- Power Macintosh 7200 General Maintenance: take-apart procedures, memory, battery and resets
- Power Macintosh 7200 Troubleshooting: Apple's symptom charts
- Power Macintosh 7200 Capacitor Replacement Guide: logic board and power supply part numbers from the exploded view
The machine's article is Power Macintosh 7200. Apple's other documents for it are Power Macintosh 7200 Computer Developer Note, Power Macintosh 7200 Logic Board Schematic and Power Macintosh 7200 User's Guide. The volume is listed on Maintenance Guides.
Related volume: Power Macintosh 7300/ 7500/7600 & WS 7350 Service Source, which covers the 7500 and 7600 in the same case.
Download: Powermac_7200_series.pdf (2.0 MB)
