Power Macintosh 9500 Series Service Source
The Power Macintosh 9500 Series Service Source is Apple's 111-page service manual for the Power Macintosh 9500/120, 9500/132, 9500/150, 9500/180MP and 9500/200. The PDF was created on 27 March 1996. Page numbers below are PDF pages.
It is module-level: Apple's specifications, symptom charts, take-apart procedures and an exploded view with part numbers. It has no schematics and no component values.
Specifications as Apple prints them
[edit | edit source]| Item | As printed | Page |
| CPU | PowerPC 604 card at 120, 132 or 150 MHz; PowerPC 604e card at 200 MHz, or two 604e at 180 MHz (9500/180MP); built-in FPU | 27–28 |
| RAM | 16 or 32 MB standard; 168-pin, 64-bit, 70 ns or faster DIMMs; 1536 MB maximum | 29 |
| Cache and ROM | 512K level-2 cache soldered to the logic board; 4 MB ROM, in a ROM SIMM slot or soldered | 29 |
| Expansion | Six PCI slots | 4, 31 |
| Line voltage | 100–240 V AC RMS single phase, automatically configured; 50–60 Hz | 35 |
| Maximum power | DC 225 W (excluding monitor); AC 340 W maximum continuous, 520 W peak input | 35 |
Contents
[edit | edit source]- Basics: Overview (p. 3), Configurations (p. 5), PowerPC 604 Microprocessor (p. 7), Multi-Processor Support (p. 8), Peripheral Component Interconnect (PCI) (p. 9), Dual In-Line Memory Modules (DIMMs) (p. 10), Memory Configurations (p. 12), Ethernet Support (p. 15), GeoPort (p. 16), The Cuda Chip (p. 18), Resetting the Logic Board (p. 19), Fast SCSI (p. 21), Rear View Diagram (p. 22), Logic Board Diagram (p. 24)
- Specifications: Processor (p. 27), Memory (p. 29), I/O Interfaces (p. 30), I/O Devices (p. 32), Video Support (p. 33), Disk Storage (p. 34), Electrical (p. 35), Physical (p. 36), Environmental (p. 37)
- Troubleshooting: General (p. 39), Cleaning Procedure for Card Connectors (p. 40), Symptom Charts (p. 41)
- Take Apart: Top Housing (p. 65), CD-ROM Drive (p. 68), Floppy Drive (p. 71), Hard Drive (p. 74), Power Supply (p. 77), Speaker (p. 83), Rear Panel (p. 87), Processor Card (p. 90), PCI/Video Cards (p. 92), Logic Board (p. 96), Fan (p. 104)
- Upgrades: PC Compatibility Cards (p. 109)
- Exploded View (p. 111)
Notable content
[edit | edit source]The processor is on a plug-in card (p. 8). Apple's first cure for a 9500 that does not power up is to reseat the processor card, video card and ROM SIMM, then reset the Cuda chip, then reset the logic board (p. 41). For the eight-part error chord (death chimes), Apple's first step is to check the DIMMs are installed from banks A6 and B6 downwards, leaving A1 and B1 until all the others are full (p. 43). The Basics chapter covers multi-processor support on the 9500/180MP (p. 8), the Cuda chip (p. 18), the logic board reset (pp. 19–20) and Fast SCSI (p. 21).
[edit | edit source]- No schematic, no parts list below module level, no component values.
- No Adjustments chapter and no Additional Procedures chapter, so there is no battery verification procedure or battery voltage threshold. The battery appears in the logic board reset (p. 20).
Pages that cite this document
[edit | edit source]- Battery Refurbishment: listed among the volumes that print no battery threshold
- Power Macintosh 9500: models, specifications and service parts
- Power Macintosh 9500 General Maintenance: take-apart procedures, memory, battery and resets
- Power Macintosh 9500 Troubleshooting: Apple's symptom charts
- Power Macintosh 8500: the 9500 power supply part number
The machine's article is Power Macintosh 9500; Apple's developer note is Power Macintosh 9500 Computers Developer Note. The volume is listed on Maintenance Guides.
Related volumes: Power Macintosh 8200 and 8500 Series/WS 8550 Service Source and Power Macintosh 8600/ 9600 & WS 9650 Service Source.
Download: Powermac_9500_series.pdf (1.1 MB)
