Professional 325 Troubleshooting Guide
Fault-finding on the Professional 325, from DEC's Professional 300 Series Technical Manual (EK-PC350-TM-001) and the Professional 380 Pocket Service Guide (EK-PC380-PS-003), which also covers the 325 and 350.[1][2] DEC's service method works to the field replaceable unit and assumes one FRU has failed; if the symptoms change as parts are swapped, follow the current symptom.[3]
Power-up sequence
[edit | edit source]When the power switch is turned on, all four red LEDs on the rear panel light as a lamp test. The power-up self-test then checks the system core (CPU, memory, self-test ROM and memory management), the base options on the system module (communications port, clock, floating point adapter if fitted, printer port, battery and battery-backed RAM, video/keyboard port) and finally each option module from its own ROM. If everything passes, the LEDs go out, the DIGITAL logo appears and the system boots.[4][5] A failure is shown on the screen as a picture of the system with the failing part highlighted, an error code and an ID number; the LEDs give the same information when the screen cannot.[4] A picture of a diskette with a question mark means no bootable volume was found; the ROM then keeps retrying the boot sequence.[6]
No response at power-up
[edit | edit source]| Symptom | Check | Action |
| Nothing happens at the power switch | Power cord, circuit breaker, wall outlet | Reconnect the cord; reset the breaker by pushing it in; check the outlet and the cord with a meter |
| Fan runs but the green LED on the back is off | Power cable from the supply to the system module | Reseat it; otherwise replace the power supply |
| Green LED on, all four red LEDs off, screen blank | Monitor cable and controls; memory daughterboards | Reconnect the monitor cable, adjust the controls, reseat the daughterboards, then try another monitor |
| Green LED on, one or more red LEDs on | Self-test failure | Read the LED code below |
[7] DEC asks for a restart with the power switch if the screen stays blank for more than two minutes.[7]
Rear-panel LED codes
[edit | edit source]The Professional 325 and 350 system module reports its self-test result on four red LEDs, numbered 3 to 0 here as in DEC's table:[8]
| LED 3 | LED 2 | LED 1 | LED 0 | Meaning |
| off | off | off | off | No errors |
| off | off | off | on | Error in bus slot 0 (physical slot 1) |
| off | off | on | off | Error in bus slot 1 (physical slot 2) |
| off | off | on | on | Error in bus slot 2 (physical slot 3) |
| off | on | off | off | Error in bus slot 3 (physical slot 4) |
| off | on | off | on | Error in bus slot 4 (physical slot 5) |
| off | on | on | off | Error in bus slot 5 (physical slot 6) |
| on | off | off | on | Keyboard failed |
| on | off | on | off | No boot found |
| on | off | on | on | Monitor cable not present |
| on | on | off | off | Memory in slots 0 and 1 both failed |
| on | on | off | on | Memory in slot 1 failed (low bank) |
| on | on | on | off | Memory in slot 0 failed (low bank) |
| on | on | on | on | System module failed (all four stay lit after the lamp test) |
[8] The remaining two combinations are reserved. The Professional 380 uses a different system module, and its pocket service guide's LED table is laid out for it; use the table above for a 325.[8][3]
Power supply faults
[edit | edit source]| Symptom | Cause |
| Fan at half speed, green LED off, no output | Voltage select switch at 240 V on 120 V mains |
| Internal fuse blown | Switch at 120 V on 240 V mains; if the breaker also tripped within 3 to 8 seconds, the primary capacitors and possibly more parts are damaged |
| Supply shuts down and stays off | Overvoltage latch: +5 V above 7.0 V, +12 V above 14.5 V or −12 V beyond −14.0 V; remove the power to reset it |
| Supply cycles off and restarts slowly | Overcurrent shutdown (+5 V 21 to 29 A, +12 V 11 to 15 A) followed by soft start; look for a short on an output |
| Supply stops switching | Start-up supply fallen to 8.75 V or below |
| System does not start although the outputs are present | DCOK not asserted: +5 V below 4.7 ±0.2 V, +12 V below 11.1 ±0.3 V or −12 V below 10.8 ±0.3 V in magnitude |
[9][10] Measure at the 16-pin connector J2: +5 V on pins 6 to 9, +12 V on pin 5, −12 V on pin 4, DCOK on pin 1, POK on pin 3, ground on pins 10 to 16.[11] At power-up DCOK follows the outputs by at least 3 ms and POK follows by at least 70 ms; at power-down POK drops first and DCOK at least 4 ms later, giving the CPU time to run its power-fail routine.[12] The H7862 has no adjustments.[13] Work inside it only after the input capacitors have discharged; see Professional 325 Capacitor Replacement Guide.
Clock and configuration
[edit | edit source]The clock chip's "valid RAM and time" bit is cleared if its supply has fallen too low, and the date, time and the boot devices stored in battery-backed RAM may then be wrong.[14][6] A fully charged pack (48 hours of running) should hold the clock for at least ten days. The charger is a voltage divider from +12 V that supplies 10 mA.[14][15]
Maintenance ODT
[edit | edit source]The F-11 microcode includes a console emulator (micro-ODT) reached through the printer port. Connect a terminal with DEC's terminal cable BCC08, which links pins 8 and 9 of the printer connector; the printer cable BCC05 does not, and without the link the console registers read as zero. ODT is entered by a HALT instruction in kernel mode, or by BREAK from the terminal when the break-enable bit in the system control register is set. It accepts 16-bit addresses and the usual PDP-11 ODT commands, including / to open a location, P to proceed and H to toggle a halt request for single-stepping.[16]
Diagnostics diskettes
[edit | edit source]DEC's maintenance services diskettes run under P/OS: boot the P/OS diskette in drive 1, then at the prompt insert the installation/maintenance application diskettes in drives 1 and 2. The system unit test checks the diskette drive, printer and communications ports (internally looped back), the floating point processor and any option modules; service mode, entered with F12, F19 and F5, allows single or repeated passes and external loopback with connectors fitted. A keyboard test, printer test, configuration display and RX speed test are also included.[17]
[edit | edit source]- Professional 325
- Professional 325 General Maintenance
- Professional 325 Capacitor Replacement Guide
- Floppy Drive Repair
- Professional 350
- Professional 380
- Professional 350 Documentation
[edit | edit source]- ↑ Digital Equipment Corporation, Professional 300 Series Technical Manual, EK-PC350-TM-001, December 1982 (File:Professional 300 Series Technical Manual (EK-PC350-TM-001, 1982).pdf).
- ↑ Digital Equipment Corporation, Professional 380 Pocket Service Guide, EK-PC380-PS-003, June 1986 (File:Professional 380 Pocket Service Guide (EK-PC380-PS-003).pdf).
- ↑ 3.0 3.1 DEC, EK-PC380-PS-003, pp. 1 to 2, sections 1.1.1 and 1.1.2.
- ↑ 4.0 4.1 DEC, EK-PC350-TM-001, p. 5-5, section 5.2.3.4, power-up self-tests.
- ↑ DEC, EK-PC350-TM-001, p. 3-1, section 3.2.2, indicators.
- ↑ 6.0 6.1 DEC, EK-PC350-TM-001, p. 5-6, section 5.2.3.5, boot sequence.
- ↑ 7.0 7.1 DEC, EK-PC380-PS-003, pp. 15 to 16, section 1.5 and Table 1-1, no response at power-up.
- ↑ 8.0 8.1 8.2 DEC, EK-PC350-TM-001, p. 5-33, Table 5-6 and Figure 5-15, indicator (LED) error codes.
- ↑ DEC, EK-PC350-TM-001, p. 13-4, Table 13-1, AC voltage switch settings, and warning.
- ↑ DEC, EK-PC350-TM-001, pp. 13-5 to 13-9, protection circuits, Table 13-2 and the DCOK thresholds.
- ↑ DEC, EK-PC350-TM-001, p. 13-10, Table 13-3.
- ↑ DEC, EK-PC350-TM-001, pp. 13-8 to 13-9, section 13.4.3 and Figure 13-9, power status timing.
- ↑ DEC, EK-PC380-PS-003, p. 80, section 2.8, power supply note.
- ↑ 14.0 14.1 DEC, EK-PC350-TM-001, p. 5-9, section 5.2.12, battery backed-up clock and RAM.
- ↑ DEC, EK-PC350-TM-001, p. 5-54, section 5.3.13.2, battery charger and voltage sensor.
- ↑ DEC, EK-PC350-TM-001, pp. 5-119 to 5-126, sections 5.4.14 and 5.4.15, maintenance ODT and maintenance terminal.
- ↑ DEC, EK-PC380-PS-003, pp. 4 to 15, section 1.4, maintenance services tests.
