RetroTechCollection:Technical specifications
| This page documents an the RetroTechCollection guideline. Editors should generally follow it, though exceptions may apply. Substantive edits to this page should reflect consensus. When in doubt, discuss first on this guideline's talk page. |
Technical specifications form the foundation of accurate hardware documentation on RetroTechCollection. This guideline establishes standards for presenting, verifying, and maintaining technical data to ensure reliability and usefulness for repair, restoration, and preservation activities.
Purpose and Scope
[edit source]Technical specifications provide the quantitative and qualitative data necessary for:
- Hardware identification - Distinguishing between models and revisions
- Repair procedures - Voltage levels, timing parameters, and component values
- Compatibility assessment - Interface standards and operational requirements
- Safety procedures - Operating limits and hazard identification
- Historical documentation - Performance characteristics and design parameters
Specification Categories
[edit source]Core System Specifications
[edit source]Essential characteristics that define hardware functionality:
- Processor specifications - Clock speeds, instruction sets, cache sizes
- Memory specifications - Capacity, speed, organization, and timing
- Storage specifications - Capacity, transfer rates, format compatibility
- Interface specifications - Connector types, signal levels, protocols
- Power specifications - Voltage requirements, current consumption, efficiency
Operational Parameters
[edit source]Performance and environmental characteristics:
- Clock and timing - Operating frequencies, setup/hold times, propagation delays
- Voltage levels - Supply voltages, signal levels, tolerance ranges
- Current specifications - Consumption, drive capability, surge requirements
- Temperature ranges - Operating and storage temperature limits
- Physical dimensions - Size, weight, mounting requirements
Component-Level Specifications
[edit source]Individual component characteristics:
- Semiconductor specifications - Part numbers, package types, electrical characteristics
- Passive component values - Resistors, capacitors, inductors with tolerances
- Connector specifications - Pin assignments, mechanical characteristics
- Display specifications - Resolution, color depth, refresh rates, geometry
- Audio specifications - Frequency response, dynamic range, distortion
Specification Presentation
[edit source]Standardized Tables
[edit source]Present specifications in consistent table formats:
{| class="wikitable" style="width:70%; text-align:center;"
|+ '''System Specifications'''
! Component !! Specification !! Value
| '''CPU''' || Type || Motorola 68000
| || Clock Speed || 7.83 MHz
| || Bus Width || 16-bit data, 24-bit address
| '''Memory''' || Main RAM || 128 KB
| || ROM || 64 KB
| || Video RAM || 22 KB (shared)
Specification Formatting
[edit source]Use consistent formatting for technical data:
- Units - Always include appropriate units (V, MHz, KB, etc.)
- Precision - Match precision to measurement accuracy and relevance
- Tolerances - Include tolerance ranges when applicable (5.0V ±5%)
- Conditions - Specify measurement conditions (room temperature, no load)
- Ranges - Use appropriate range notation (10-15V, >100MHz)
Revision Handling
[edit source]Document specification variations across hardware revisions:
{| class="wikitable" style="width:80%; text-align:center;"
|+ '''Revision-Specific Specifications'''
! Revision !! RAM Capacity !! ROM Version !! Notes
| Rev A || 128 KB || 1.0 || Initial release
| Rev B || 512 KB || 1.1 || Increased memory
| Rev C || 512 KB || 1.2 || Bug fixes
Verification Standards
[edit source]Source Verification
[edit source]Technical specifications must be verified through reliable sources:
Primary Sources:
- Official service manuals and technical documentation
- Component datasheets from manufacturers
- Engineering specifications and design documents
- Factory test procedures and specifications
Secondary Sources:
- Technical reference books by recognized experts
- Peer-reviewed academic papers
- Established technical websites with documented expertise
- Community measurements verified by multiple sources
Measurement Verification
[edit source]When possible, verify specifications through direct measurement:
- Test equipment requirements - Use calibrated instruments appropriate for the measurement
- Measurement conditions - Document environmental conditions and test setup
- Multiple measurements - Take multiple readings to ensure consistency
- Uncertainty assessment - Estimate measurement uncertainty and limitations
Cross-Reference Validation
[edit source]Validate specifications against multiple independent sources:
- Source agreement - Check consistency across different documentation
- Logical consistency - Ensure specifications make technical sense
- Historical context - Verify specifications fit known design practices
- Expert review - Have knowledgeable community members review questionable data
Accuracy Standards
[edit source]Precision Guidelines
[edit source]Present specifications with appropriate precision:
Voltage Specifications:
- Power supply voltages: ±0.1V precision (5.0V, 12.0V)
- Signal levels: ±0.01V precision for critical timing
- Reference voltages: Match source documentation precision
Frequency Specifications:
- System clocks: Match crystal specification precision
- Audio frequencies: Standard audio measurement precision
- RF frequencies: Match regulatory specification requirements
Dimensional Specifications:
- Physical dimensions: ±0.1mm for PCB measurements
- Component spacing: Match mechanical drawing precision
- Connector dimensions: Match industry standard specifications
Uncertainty Documentation
[edit source]When specifications are uncertain or estimated:
- Clearly mark estimates - Use "approximately" or "~" notation
- Document uncertainty sources - Explain why exact values are unknown
- Provide ranges - Give best-estimate ranges when exact values unavailable
- Note verification needs - Identify specifications requiring confirmation
Safety-Critical Specifications
[edit source]High-Voltage Systems
[edit source]Special requirements for potentially dangerous specifications:
- Clear hazard identification - Mark high-voltage specifications prominently
- Safety warnings - Include appropriate caution statements
- Protective equipment - Specify required safety equipment for measurements
- Verification sources - Require authoritative sources for safety-critical data
Chemical and Environmental Hazards
[edit source]For specifications involving hazardous materials:
- Material identification - Clearly identify hazardous substances
- Concentration levels - Specify exposure limits and safe handling procedures
- Disposal requirements - Include proper disposal and cleanup procedures
- Regulatory compliance - Reference applicable safety regulations
Regional and Standards Variations
[edit source]International Variations
[edit source]Document regional differences in specifications:
Power Specifications:
- Line voltage variations (110V vs 220V regions)
- Frequency differences (50Hz vs 60Hz systems)
- Connector and safety standard variations
- Regulatory compliance differences
Communication Standards:
- Regional broadcast standards (NTSC vs PAL vs SECAM)
- Telecommunications standards variations
- Wireless frequency allocations
- Interface standard differences
Regulatory Compliance
[edit source]Include relevant regulatory information:
- Safety certifications - UL, CE, FCC compliance information
- Electromagnetic compatibility - EMI/EMC specifications and requirements
- Environmental standards - RoHS, REACH, and similar compliance
- Regional approvals - Country-specific certification requirements
Historical Context
[edit source]Design Evolution
[edit source]Document how specifications changed over time:
- Performance improvements - Speed increases, capacity expansions
- Compatibility changes - Interface modifications and standard updates
- Cost reductions - Component substitutions and manufacturing changes
- Reliability improvements - Design modifications to address known issues
Industry Standards
[edit source]Relate specifications to contemporary industry standards:
- Interface standards - RS-232, IEEE standards, industry protocols
- Component standards - Standard component values and packages
- Performance benchmarks - Comparison with contemporary systems
- Technology generations - Relationship to broader technology development
Component Specifications
[edit source]Semiconductor Components
[edit source]Detailed specifications for active components:
{| class="wikitable" style="width:90%; text-align:center;"
|+ '''CPU Specifications'''
! Parameter !! Specification !! Notes
| Part Number || MC68000L8 || Motorola 8MHz version
| Package || 64-pin DIP || PDIP-64 ceramic or plastic
| Supply Voltage || 5.0V ±5% || Single supply operation
| Clock Speed || 8.0 MHz maximum || Specify actual operating frequency
| Power Consumption || 1.2W typical || At 8MHz, room temperature
| Temperature Range || 0°C to +70°C || Commercial temperature grade
Passive Components
[edit source]Specifications for resistors, capacitors, and other passive components:
- Value and tolerance - Nominal value with precision specification
- Power rating - Maximum power dissipation capability
- Temperature coefficient - Value change with temperature
- Voltage rating - Maximum safe operating voltage
- Package information - Physical size and mounting type
Mechanical Components
[edit source]Specifications for connectors, switches, and mechanical parts:
- Electrical ratings - Current, voltage, and resistance specifications
- Mechanical ratings - Insertion force, durability, operating life
- Environmental ratings - Temperature, humidity, vibration resistance
- Standards compliance - Industry standard compatibility
- Dimensional information - Physical dimensions and tolerances
Test and Measurement
[edit source]Test Procedures
[edit source]Standardized procedures for specification verification:
Power Supply Testing:
- No-load and full-load voltage measurements
- Ripple and noise measurements
- Regulation testing across load and line variations
- Efficiency measurements at various load levels
Digital Signal Testing:
- Logic level measurements (VIL, VIH, VOL, VOH)
- Timing measurements (setup, hold, propagation delays)
- Noise margin verification
- Drive capability testing
Analog Signal Testing:
- Frequency response measurements
- Distortion analysis
- Signal-to-noise ratio measurements
- Dynamic range testing
Test Equipment Requirements
[edit source]Specify appropriate test equipment for measurements:
- Digital multimeters - Accuracy requirements for voltage/current measurements
- Oscilloscopes - Bandwidth and sample rate requirements for timing measurements
- Spectrum analyzers - For frequency domain measurements
- Function generators - For stimulus generation and testing
- Environmental chambers - For temperature and humidity testing
Documentation Standards
[edit source]Specification Sources
[edit source]Document the sources of all technical specifications:
{{cite manual
| title = Technical Reference Manual
| publisher = Hardware Manufacturer
| year = 1985
| pages = 23-45
| note = Primary source for electrical specifications
Revision Tracking
[edit source]Maintain records of specification changes and updates:
- Change date - When specifications were updated
- Change reason - Why specifications were modified
- Source verification - New sources that prompted changes
- Previous values - Historical record of superseded specifications
Quality Assurance
[edit source]Procedures for maintaining specification accuracy:
- Periodic review - Regular verification of specification accuracy
- Source updates - Monitoring for new or better documentation sources
- Community feedback - Mechanisms for reporting specification errors
- Expert validation - Review by recognized technical experts
Common Specification Errors
[edit source]Typical Mistakes
[edit source]Common errors in technical specification documentation:
- Unit errors - Incorrect or missing units (MHz vs KHz, mA vs A)
- Precision errors - Inappropriate precision for measurement accuracy
- Condition errors - Missing measurement conditions or test setup information
- Source errors - Specifications from unreliable or inappropriate sources
- Transcription errors - Mistakes in copying specifications from sources
Error Prevention
[edit source]Strategies for avoiding specification errors:
- Double-check transcription - Verify copied specifications against sources
- Validate reasonableness - Check that specifications make technical sense
- Cross-reference sources - Compare specifications across multiple sources
- Peer review - Have other contributors review technical specifications
- Use measurement verification - Confirm specifications through direct measurement when possible
