Related changes
Enter a page name to see changes on pages linked to or from that page. (To see members of a category, enter Category:Name of category). Changes to pages on your Watchlist are in bold.
List of abbreviations:
- N
- This edit created a new page (also see list of new pages)
- m
- This is a minor edit
- b
- This edit was performed by a bot
- (±123)
- The page size changed by this number of bytes
25 September 2026
08:54 | Recommended Tools 2 changes history +2,697 [Josh (2×)] | |||
08:54 (cur | prev) +1,439 Josh talk contribs (P4 verification: cite Apple's own equipment lists: the LaserWriter Technical Procedures bench requirements and the light meter specified for the all-in-one video adjustments) | ||||
07:58 (cur | prev) +1,258 Josh talk contribs (cite Apple TechStep, the Chilton repair guide and the OneScanner volume (P4 orphan fix)) | ||||
| 08:51 | Macintosh SE/30 diffhist +924 Josh talk contribs (P4 verification: cite Apple's own Service Source volume for this machine (hosted here) for the electrical specification and battery threshold, and link the documentation page) | ||||
08:05 | File:Classic ii.performa 200.pdf 2 changes history +634 [Josh (2×)] | |||
08:05 (cur | prev) +62 Josh talk contribs (categorise this file page (P4 verification drive)) | ||||
08:04 (cur | prev) +572 Josh talk contribs (P4: real summary, source and licence for this file (verification drive)) | ||||
| 08:01 | Macintosh Classic diffhist +1,250 Josh talk contribs (cite the hosted Service Source volume and what it settles (P4 orphan fix)) | ||||
| 02:31 | Sad Mac Error Codes diffhist +929 Josh talk contribs (Link Apple's OS 8.1 Emergency Handbook and the MacsBug guide from the Sad Mac page - both were reachable from no article) | ||||
23 September 2026
23:33 | Sad Mac Error Codes 3 changes history +569 [Josh (3×)] | |||
23:33 (cur | prev) +17 Josh talk contribs (House style: rephrase the corrections as statements about the facts rather than about this page's own history) | ||||
23:28 (cur | prev) 0 Josh talk contribs (Fix the remaining FFFFTTEE to FFFFEETT for consistency with the rest of the page) | ||||
23:27 (cur | prev) +552 Josh talk contribs (Verification drive: labelled as {{Original research}} per the wiki's own policy for native decoding work. Fixed internal inconsistencies: the expanded line-1 layout is FFFFEETT not FFFFTTEE (the page's own worked example, the extended exception list and the decoder gadget all put the exception in the upper byte of the lower word); the intro example called RAM Bank A test 03 when the page's own table makes it 04; the per-ROM checksum Test Manager command was given as test 04 (RAM Bank A) rathe...) | ||||
23:30 | Sad Mac Decoder 2 changes history +651 [Josh (2×)] | |||
23:30 (cur | prev) +164 Josh talk contribs (Add the Sad Mac illustration to the decoder page) | ||||
23:27 (cur | prev) +487 Josh talk contribs (Verification drive: labelled as {{Original research}}; spelled out the FFFFEETT layout so it matches the Sad Mac Error Codes page and the gadget's own parsing; added 512Ke to the short-format model list to match the gadget; noted that the chimes are synthesised rather than sampled) | ||||
| 18:18 | Macintosh Classic diffhist −586 Josh talk contribs (Rebuilt against Apple Classic/Classic II/Performa 200 Service Source: DELETED fabricated memory map, ROM SIMM module table, SWIM-II/53C80 detail, MacBench benchmark table, Seattle/LittleFish codenames and MacsBug easter egg, and the 512KB 32-bit-clean/HFS+ ROM claim; CPU 8MHz -> 7.8336MHz, ONE ADB port (not two), Apple dimensions and 100W; predecessor SE/30 -> SE; added the real Command-Option-X-O ROM disk; fixed red link to a nonexistent Troubleshooting page; release_date parameter fixed; re...) | ||||
| 18:17 | Macintosh SE/30 diffhist +285 Josh talk contribs (Rebuilt against Apple SE/30 Service Source + Guide to the Macintosh Family Hardware: release date was 16 January 1986 (wrong; 19 January 1989), CPU 16.667MHz -> 15.667MHz, ROM 512KB -> 256KB, weight 19.5lb -> 21.5lb, RAM 128MB claim qualified against Apple 32MB; DELETED fabricated memory map, ROM module table, SCSI/sound path detail, JP13 and chess-tone easter egg; pseudo-slot video explained from Apple ch.12; chip location map from the hosted 050-0253-01 redraw; refs and reflist) | ||||
18:12 | Macintosh Classic / Classic II General Maintenance 2 changes history +2,109 [Josh (2×)] | |||
18:12 (cur | prev) +1,639 Josh talk contribs (Sourced to Apple Classic/Classic II/Performa 200 Service Source: battery 3.0V threshold and lithium chemistry (bicarbonate not vinegar), DELETED invented maintenance intervals, added Apple eight-chip SIMM rule and jumper check, noted Dead Mac Scrolls does not cover these models, refs and reflist) | ||||
01:47 (cur | prev) +470 Josh talk contribs (Removed unsourced rail tolerance table (+5V 4.90-5.15, +12V 11.9-12.7) and the R56 trimmer adjustment: Apple's Classic/Classic II Service Source publishes no rail figures and its Adjustments chapter covers video only. Added Apple's actual Electrical spec (100-120 VAC, 47-63 Hz, 100 W max)) | ||||
02:25 | Recommended Tools 2 changes history +7,999 [Josh (2×)] | |||
02:25 (cur | prev) +183 Josh talk contribs (Add a topical image (page had none)) | ||||
02:11 (cur | prev) +7,816 Josh talk contribs (Rewrite and verify every named product: corrected Retro Chip Tester (standalone 8Bit-Museum instrument, not a TL866 add-on) with its real capabilities; corrected ESD mat/strap earthing to require a current-limiting resistor per ANSI/ESD S1.1 (a direct bond to mains earth is dangerous); removed insulated gloves as CRT protection in favour of goggles and the correct discharge tooling; replaced the unsourced 20-50 MHz scope rule with edge-speed reasoning; added sourced solder melting points (Kes...) | ||||
02:15 | CRT Discharge Procedure 2 changes history +11,081 [Josh (2×)] | |||
02:15 (cur | prev) −45 Josh talk contribs (Remove self-referential wording per house rule) | ||||
02:05 (cur | prev) +11,126 Josh talk contribs (Rewrite against Apple Service Guide 1990 and Goldwasser CRT notes: corrected earth-return point (ground lug, never logic board), added never-wear-a-wrist-strap rule and implosion/goggles hazard, replaced unsourced 25 kV blanket with sourced per-class figures, replaced dead-short tool with resistive tooling, removed invented 30-min wait / 10-s hold / 10-15-min re-discharge interval, added ongoing shorting lead and aquadag mechanism; full ref citations) | ||||
| 01:47 | Macintosh Classic / Classic II Troubleshooting diffhist +392 Josh talk contribs (Removed unsourced rail tolerance figures (+5V 4.90-5.10, +12V 11.9-12.7): Apple's Classic/Classic II Service Source publishes no rail voltages. Replaced with Apple's actual Electrical spec and a sourced +-5% logic-supply check) | ||||
