Using the 64
Using the 64 is a book by Peter Gerrard in the Duckworth Home Computing series, published in London by Gerald Duckworth & Co. It was first published in September 1983; the hosted scan is the second impression of November 1983. ISBN 0-7156-1777-X.[1] The numbered pages run to 328.[2]
The book runs through BASIC and machine code on the Commodore 64, then covers colour, high-resolution and sprite graphics, sound and the common peripherals. The last three chapters describe the four main chips: the 6566 VIC-II, the 6581 SID, the 6510 processor and the 6526 CIA. The appendixes include memory maps, BASIC and 6510 instruction references, screen codes and a listing of an assembler/disassembler.[3][4] Appendix E gives the pin assignments of the control ports, cartridge expansion slot, audio/video socket, serial port, cassette port and user port, with the 100 mA limit on the +5 V and 9 V AC pins.[5]
Contents
Page numbers are from the book's contents list.[4]
  • 1: An Introduction to Basic Programming, p. 1
  • 2: More Basic Programming, p. 41
  • 3: An Introduction to Machine Code Programming, p. 69
  • 4: Colour on the Commodore 64, p. 103
  • 5: High Resolution and Sprite Graphics, p. 108
  • 6: Sound on the Commodore 64, p. 148
  • 7: Peripheral Support, p. 175
  • 8: 6500 Chips in General and the 6566 in Particular, p. 201
  • 9: The 6581 Sound Interface Device, p. 229
  • 10: The 6510 and 6526 Input/Output Chips, p. 250
  • Appendixes, p. 273 (A: Commodore 64 Memory Maps; B: The Basic Language; C: Machine Code Instruction Set; D: Miscellaneous, including screen display codes; E: Pinouts for Input/Output)
  • Index, p. 327
What this book does not contain
Apart from the connector pinouts in Appendix E it is a programming book. It has no schematic, parts list or component values; for those use the Commodore 64 / 64C Service Manual. The same author's Sprites & Sound on the 64 is in the same series.
Download: Duckworth Using the C64.pdf
  1. ↑ Peter Gerrard, Using the 64 (Duckworth, 1983), title page and copyright page (PDF pp. 5-6).
  2. ↑ Gerrard, Using the 64, Index, pp. 327-328 (PDF pp. 337-338).
  3. ↑ Gerrard, Using the 64, Preface (PDF p. 9).
  4. ↑ 4.0 4.1 Gerrard, Using the 64, Contents (PDF p. 7).
  5. ↑ Gerrard, Using the 64, Appendix E: Pinouts for Input/Output, pp. 323-325 (PDF pp. 333-335).
