VT320 Documentation
VT320 Documentation describes the Digital Equipment Corporation documents for the VT320 video terminal, with the PDF of each.
VT320 Pocket Service Guide (EK-VT320-PS-001)
[edit | edit source]DEC's field service guide, order number EK-VT320-PS-001, first edition, July 1987. The scan, from VT100.net, has 62 pages and no text layer; printed page numbers run six behind the PDF page numbers.[1]
Contents: "About This Guide", with the models and tools (pp. v to vi); 1 troubleshooting and testing: flowchart (Figure 1-2, p. 3), troubleshooting table (Table 1-1, pp. 4 to 6), self-tests (Table 1-2, p. 10), printer problems and error codes (Table 1-3, p. 18); 2 removal and replacement of the access cover, power supply assembly, CRT/bezel/yoke assembly with anode discharge (p. 25) and CRT disposal, the monitor and logic with arc protection assembly (with the CRT maker jumpers, p. 33) and the keyboard; 3 aligning the video monitor (pp. 35 to 40); 4 using set-up; appendices A options and documentation, B models and recommended spares (pp. 47 to 48), C physical/functional diagrams.[1]
It works at the level of replaceable units and has no component data.[1]
Download: VT320 Pocket Service Guide (EK-VT320-PS-001).pdf
Installing and Using the VT320 Video Terminal (EK-VT320-UU-001)
[edit | edit source]The user's manual for the international model, order number EK-VT320-UU-001, first edition, June 1987, 122 pages with a text layer. DEC published a separate edition, EK-VT320-UG, for the North American model.[2][1]
Contents: 1 installation; 2 a look at the terminal, including the CRT saver (p. 11); 3 the keyboard; 4 set-up; 5 composing characters; 6 printing; 7 solving problems and getting service (operating problems and screen error messages, pp. 56 to 57); appendices A specifications (p. 60), B options and documentation, C communication, D keyboards, E control function summary.[2] VT100.net has an HTML edition.[3]
Download: Installing and Using the VT320 Video Terminal (EK-VT320-UU-001).pdf
VT320 Field Maintenance Print Set (MP02509-01)
[edit | edit source]DEC's print set, order number MP02509-01, contents sheet K-TC-VT320-0-0 at revision E (July 1987), 58 pages. It covers the VT320-A2 to VT320-J2 and later variations.[4]
Contents (from the contents sheet): drawing directory and unit assembly; monitor and logic control modules 5417189 and 5417277 (schematics, unit assemblies, parts lists); power supplies 5417191 and 5417279; arc protection module 5417339; CRT/bezel/yoke assembly 7024240; power supply assembly 7024244; cover and bottom assemblies; and the monitor and logic with arc protection assembly 7024577.[4] The 5417191 power supply parts list is on PDF pp. 25 and 26. The text layer is OCR of poor quality; read values from the page images.
Download: VT320 Field Maintenance Print Set (MP02509-01 rev E).pdf
Other documents
[edit | edit source]The VT320 uses the LK201 keyboard, whose print set is on VT220 Documentation. DEC also published a VT320 Programmer Reference Manual (EK-VT320-RM) and a VT320 Video Terminal IPB (EK-VT320-IP) with part numbers for the replaceable units.[1] Bitsavers holds an earlier April 1987 set of VT320 engineering drawings, a July 1987 issue of MP02509 before revision E, and a separate VT320 schematic scan.[5]
Pages that cite these documents
[edit | edit source]- VT320: specifications, models, replaceable units
- VT320 General Maintenance: opening the case, power supply, capacitor list, keyboard
- VT320 Troubleshooting Guide: flowchart, symptom table, self-tests, error codes
- VT320 CRT Service Guide: anode discharge, CRT replacement, alignment
[edit | edit source]- ↑ 1.0 1.1 1.2 1.3 1.4 Digital Equipment Corporation, VT320 Pocket Service Guide, EK-VT320-PS-001, title page, contents and Appendix A. Source: vt100.net.
- ↑ 2.0 2.1 Digital Equipment Corporation, Installing and Using the VT320 Video Terminal, EK-VT320-UU-001, title page and contents. Source: bitsavers.org.
- ↑ Installing and Using the VT320 Video Terminal, HTML edition, VT100.net, vt100.net/docs/vt320-uu/.
- ↑ 4.0 4.1 Digital Equipment Corporation, VT320 Field Maintenance Print Set, MP02509-01, contents sheet K-TC-VT320-0-0 revision E. Source: bitsavers.org.
- ↑ Bitsavers directory listing, bitsavers.org/pdf/dec/terminal/vt320/.
