Macintosh Centris 610 Troubleshooting
Revision as of 11:44, 27 September 2026 by Josh (talk | contribs) (Remove the 'tantalum capacitors, logic board does not normally need recapping' paragraph - its own citation is a source for the Quadra 700/900 boards, not the Centris, and it contradicted the page's own capacitor section; add Apple's replace-below-3.2 V battery threshold)
Troubleshooting is essential for diagnosing and resolving issues with your Macintosh Centris 610 (or Macintosh Quadra 610). This guide covers the most common problems and their solutions.
Note: The Centris 610 and Quadra 610 share the same hardware. This guide applies to both models.
Preliminary Checks
  • Power cable is connected and outlet is working
  • All cables are securely connected
  • RAM and VRAM SIMMs are properly seated
  • PRAM battery is installed and not dead
No Power
Macintosh Centris 610. Source: Wikimedia Commons.
Power Issues
Completely dead, no LED Power supply failure Test outlet, try different power cable, check PSU capacitors
Dead after storage PRAM battery leakage Inspect battery area for corrosion damage
Clicks repeatedly PSU capacitor failure Replace power supply electrolytic capacitors
Powers on then dies PSU or logic board issue Check voltages, inspect for shorted capacitors
Front button unresponsive Switch or wiring fault Test switch continuity, check connections
Startup Issues
Startup Problems
Chime but no video VRAM issue, monitor problem Reseat VRAM, test with different monitor
No chime, no video RAM failure, logic board fault Reseat RAM, check for capacitor damage
Sad Mac icon Hardware failure (code indicates area) Decode error, check RAM first
Flashing question mark No bootable system found Check hard drive, reinstall system software
Chimes of death RAM or logic board failure Reseat RAM, test with known-good SIMMs
Sad Mac Error Codes
The Centris 610 displays Sad Mac icons with hexadecimal error codes when hardware failures are detected.
Common Sad Mac Codes
Code Meaning
0000000F RAM test failed (bad SIMM)
00000001 ROM test failed
00000002 Memory test failed
00000003 ROM checksum error
00000004 Bad RAM (first bank)
00000005 Bad RAM (second bank)
See Sad Mac Error Codes for a complete reference.
Intermittent Operation
Intermittent Issues
Random freezes Leaking capacitors Inspect and recap logic board
Intermittent startup Cold solder joints Reflow solder on capacitors and connectors
Crashes after warmup Thermal issue, bad cap Check cooling, inspect capacitors
SCSI errors Termination or cable issue Verify SCSI chain termination
Lost date/time Flat PRAM battery 3.6 V ยฝAA lithium; Apple's instruction is replace below 3.2 V[1]
Video Problems
Display Issues
No video, system runs VRAM failure Reseat or replace VRAM SIMMs
Garbled display VRAM or video circuit fault Test VRAM, check for cap leakage near video
Wrong resolution VRAM not detected Clean and reseat VRAM
Video cuts out Loose cable or connector Check video port and cable connections
Floppy Drive Issues
Floppy Problems
Won't eject Mechanical failure Manually eject with paperclip, lubricate mechanism
Can't read disks Dirty heads Use cleaning disk, check for debris
Disks not recognized Drive failure Test with known-good drive
Grinding noise Lack of lubrication Clean and lubricate mechanism
SCSI Problems
SCSI Issues
Drive not mounting Termination issue Ensure proper termination (internal and external)
Intermittent SCSI errors Bad cable or connector Replace SCSI cable, check connections
Slow SCSI performance ID conflict Verify unique SCSI IDs (0-6, avoid 7)
External drive issues Power or termination Check external device power, add terminator
Capacitor Failure
The Centris 610 logic board has 10 surface-mount electrolytic capacitors that fail with age.
Symptoms of Cap Failure
  • Random crashes or freezes
  • Audio distortion or no sound
  • Boot failures
  • Visible corrosion or residue on the logic board
Solution
Replace all 10 logic board capacitors. See Macintosh Centris 610 Capacitor Replacement Guide.
PRAM battery โ€” remove it now
The Centris 610 carries a 3.6 V 1/2AA lithium PRAM battery. These leak and can burst, spraying corrosive electrolyte across the logic board and destroying nearby components — often while the machine simply sits in storage. Remove the PRAM battery from any un-serviced unit. If one has leaked, neutralise and clean the residue and repair corroded traces and vias before troubleshooting.[2]
Logic board capacitors
The claim that this logic board needs no recapping came from a fact about a different machine. A paragraph previously on this page stated that the 68040-family board uses tantalum capacitors which do not leak, and that "the logic board does not normally need recapping" โ€” while the same page's capacitor section, and its own capacitor guide, describe surface-mount electrolytics that do. The citation attached to that paragraph says in its own text that it is a source for "Apple's use of tantalum (non-leaking) capacitors on the Quadra 700/900 logic boards". It was carrying a Quadra 700/900 fact onto a Centris page. It has been removed.
What is actually established here: no Apple parts list for this logic board is held on this wiki, and the capacitor complement given on Macintosh Centris 610 Capacitor Replacement Guide comes from a secondary reference and is labelled there as such. Treat a leaking or corroded board as a board that needs work, and a clean one as one that does not, rather than working from a rule about the family.
Reading the start-up sound
  1. โ†‘ Apple Computer, Macintosh Quadra 610/Centris 610/WS 60 Service Source (Macintosh Quadra 610/ Centris 610/WS 60 Service Source, File:Quadra.centris_610.ws_60.pdf), Specifications chapter and Additional Procedures โ†’ Battery Verification.
  2. โ†‘ "Warning! Exploding Maxell PRAM Batteries", 68kMLA; and MacDat — Macintosh II family. Source for the leaking/exploding lithium PRAM battery that destroys nearby components.
  3. โ†‘ "Compact/Desktop Power Supply Capacitor Lists (by make and model)", 68kMLA; and "Capacitor Replacement in a Vintage Power Supply", Big Mess o' Wires. Source for the shared desktop PSU form factor (IIci/IIcx/IIvi/IIvx/Performa 600/Quadra 650/Quadra 700), the electrolytic failure symptoms and the PSU capacitor lists.
