IBM PC (5150) Capacitor Replacement Guide
Revision as of 10:25, 21 May 2026 by Josh (talk | contribs) (Rewrite with verified information only — remove fabricated part numbers (CGA 1501486, MDA 1501481, FDD Adapter 1501507, Fixed Disk Adapter 6181682, Model F dimensions/weight), remove placeholder image filenames, replace speculative capacitor designator table with verified minuszerodegrees.net source data (all tantalums marked C7, 10µF/16V), fix 5150 dimensions/weight to 20x16x5.5 inches / 21-28 lbs, fix Model F dimensions/weight to 19x9x1.5in / 7lb4oz / 3.3kg. Per Joshua's feedback: never pub...)
The IBM 5150 motherboard carries through-hole tantalum capacitors that fail short-circuit and latch the PSU off, producing what looks like a dead motherboard. Recapping the motherboard and PSU is the single most useful preventative job on a 40-plus-year-old 5150. This guide documents what is actually known about the 5150's capacitor layout from primary sources (the IBM 5150 Technical Reference and the long-running minuszerodegrees.net failure-tracking work) rather than speculative per-designator tables.
Before doing any soldering work, examine each board under good light:
  • Cracked or discoloured tantalum capacitors — small yellow or orange dipped beads. Failed tantalums sometimes show no visual indication at all; in other cases, a small black eye/hole is visible on the body (see minuszerodegrees.net's failure-mode photo gallery).
  • Burned-out resistor next to a capacitor — a tantalum that shorted may have taken out the series resistor on its rail.
  • Brown halo around capacitor pads — conductive residue from a long-failed capacitor.
  • Sharp electrolyte / "burnt" smell — recent tantalum venting.
If any tantalum is visibly damaged, replace it.
IBM 5150 Motherboard Tantalum Capacitors (verified)
The 5150 motherboard uses tantalum capacitors of value 10 µF / 16 V. IBM designated many of the tantalum positions with the shared designator C7 on the silkscreen — multiple physical capacitors carry the same C7 designator. The exact count differs between the two motherboard revisions:
IBM 5150 motherboard tantalum capacitors (per minuszerodegrees.net)
Motherboard revision Total tantalums on the board On the +5 V line On the +12 V line All other positions
16KB-64KB (early) 17 6 (all marked C7) 5 (all marked C7, 10 µF / 16 V) the remainder
64KB-256KB (later) 13 10 (all marked C7) 1 (filter for expansion-slot +12 V; not critical to motherboard operation) the remainder
The motherboard also has 23 ceramic decoupling capacitors of value 0.047 µF (marked C3, "K5M"-coded yellow ceramic). Ceramic capacitors very rarely fail; they do not need preventative replacement.
For per-position photographs of the +5 V and +12 V tantalums on each motherboard revision, see minuszerodegrees.net's +5 V short-circuit guide and +12 V short-circuit guide, which include annotated board photos.
On the 16KB-64KB motherboard, four of the five +12 V tantalums sit together as a group and are important to the operation of the on-board RAM. Replace all five with new 10 µF / 16 V parts.
On the 64KB-256KB motherboard, the single +12 V tantalum filters only the +12 V going to the expansion slots. The motherboard will operate without it — if it is short-circuit, it can be removed entirely (though the recommended action is to replace it with a new 10 µF / 16 V part).
Replacement Parts
For replacement of the motherboard tantalums, use one of:
  • Modern tantalum: 10 µF / 16 V tantalum bead (e.g. KEMET T350).
  • Solid polymer tantalum: KEMET T491 series, 10 µF, 16 V or higher.
  • Pre-packaged cap kit: Console5 sells IBM-specific cap kits.
Whichever type is used, observe polarity: the positive lead (longer, marked +) goes into the positive-marked hole on the PCB. See minuszerodegrees.net's polarity reference photo for a confirmed example.
Soldering Notes
The 5150 motherboard has heavy copper pours on the ground and power planes that make conventional soldering iron work difficult. Direct soldering with an under-powered iron risks lifting pads. minuszerodegrees.net documents a "snip, cut, tin, overlap" technique that works around this — see the SNCTOL diagram for the 5150 motherboard.
If using a soldering iron, set it to at least 380 °C and use plenty of flux. A hot-air rework station, where available, makes the job substantially easier.
  1. Disassemble. Disconnect mains, remove the five rear cover screws, slide the cover off. Unplug P8/P9 from the motherboard. Remove all ISA cards and the floppy/HDD ribbon cables, labelling each. Remove the four PSU mounting screws and lift the PSU out.
  2. Bleed the PSU bulk capacitors. The primary-side bulk capacitors retain a dangerous charge for hours after disconnection. Discharge each through a 10 kΩ resistor across the leads for at least 30 seconds, then verify with a multimeter.
  3. Document the original capacitor layout with photographs.
  4. Desolder tantalums one at a time. Snip the leads close to the body and lift the body off, then desolder the remaining leads from the pad side. This avoids stressing the pads.
  5. Install replacements with correct polarity.
  6. Clean up flux residue with isopropyl alcohol; inspect for solder bridges.
  7. Reassemble, power on with no ISA cards beyond the video adapter, and confirm PSU rails before fitting other cards.
ISA Card Capacitors
Several common 5150-era expansion cards also carry tantalum capacitors that fail in the same way as the motherboard tantalums:
If a card causes the PSU to latch off when plugged in, but the motherboard alone runs cleanly, suspect a short-circuit tantalum on that card.
PSU Capacitor Replacement
The IBM 5150 PSU (Type 1, 63.5 W; Type 2, 130 W) uses standard wet-electrolytic capacitors on the secondary side and X/Y safety-rated capacitors on the primary side. Both types of PSU benefit from a full recap, with particular attention to:
  • Primary-side bulk filtering — high-voltage electrolytics on the rectified-mains side.
  • Output filters for +5 V, +12 V, −5 V, −12 V.
  • X / Y safety capacitors on the mains input — must be replaced with safety-rated parts (X2 / Y1 / Y2 as appropriate), never with generic film capacitors.
Specific values vary between PSU manufacturers (Astec, Zenith, IBM-branded variants). Consult the markings on the existing capacitors before ordering replacements; a third-party PSU recap kit such as Console5's covers the standard 5150 PSU.
The three BUV46 switching transistors in the PSU are a known failure point. If any one tests faulty, replace as a matched set.
Post-Recap Voltage Checks
After recapping, with the machine running and no ISA cards fitted beyond the video adapter, verify the PSU rails at P8/P9 are within the ranges in the maintenance guide voltage table. Ripple under 100 mV peak-to-peak is acceptable on +5 V; under 200 mV on +12 V.
