IBM Monochrome Display Adapter
Revision as of 10:25, 21 May 2026 by Josh (talk | contribs) (Rewrite with verified information only — remove fabricated part numbers (CGA 1501486, MDA 1501481, FDD Adapter 1501507, Fixed Disk Adapter 6181682, Model F dimensions/weight), remove placeholder image filenames, replace speculative capacitor designator table with verified minuszerodegrees.net source data (all tantalums marked C7, 10µF/16V), fix 5150 dimensions/weight to 20x16x5.5 inches / 21-28 lbs, fix Model F dimensions/weight to 19x9x1.5in / 7lb4oz / 3.3kg. Per Joshua's feedback: never pub...)
IBM PC Original Monochrome Display and Parallel Printer Adapter (MDA)
Manufacturer IBM
Type 8-bit ISA video display adapter (text only) with integrated parallel printer port
Release date 1981 (with the original IBM PC)
Interface 8-bit ISA
Compatible IBM PC (5150), IBM PC XT (5160), IBM PC AT (5170), PC-compatible clones
Connectivity DB-9 TTL monochrome (drives the IBM 5151); DB-25 Centronics parallel (LPT1)
The IBM Monochrome Display Adapter (MDA) is the original 8-bit ISA monochrome text adapter IBM released alongside the IBM PC (5150) in 1981. Unlike the CGA, the MDA has no graphics modes — it produces only 80 × 25 text in a 9 × 14 character cell — but the larger cell yields a 720 × 350-pixel image that is noticeably crisper for office work. The card also carries the IBM PC's parallel printer port on its back-panel DB-25 connector, an idiosyncratic combination that means removing the MDA also removes the printer port.
  • Motorola MC6845 CRTC — same timing chip as CGA, programmed for 18.432 kHz horizontal / 50 Hz vertical.
  • 4 KB video RAM.
  • Character ROM carrying the IBM MDA font in a 9 × 14 cell.
  • TTL output on DB-9 (drives the IBM 5151).
  • Centronics parallel port on DB-25 — LPT1 by default.
Video Mode
  • Mode 7 — 80 × 25 text, monochrome.
  • Per-character attribute byte selects: normal, bright, underline, reverse video, blink, invisible.
  • No graphics mode.
Common Faults
  • No video, beep code 1 long + 2 short — reseat the MDA card first.
  • Garbled text — bad character ROM. Replace with a known-good donor.
  • Missing or duplicated columns — bad VRAM chip.
  • Smoke from a tantalum — replace the failed tantalum.
  • Printer port dead but video fine — the 74-series latch or buffer on the parallel side has failed.
Hercules Compatibility
The Hercules Graphics Card from Hercules Computer Technology (1982) added 720 × 348 graphics on top of MDA's text mode. A genuine IBM MDA does not have these graphics modes — it is text-only.
