IBM PS/2 Model 30 Capacitor Replacement Guide
Revision as of 10:48, 22 May 2026 by Josh (talk | contribs) (Update inline references to split per-model PS/2 pages)
This guide documents capacitor diagnosis and replacement procedures for the IBM PS/2 Model 30 (machine type 8530, both 8086 and 286 generations), covering the planar, the proprietary 70 W / 80 W PSU, the proprietary PS/2 single-cable floppy and hard-drive logic boards, and ISA expansion cards.
The Model 30 uses the same family of 10 µF / 16 V tantalum capacitors as the rest of the PS/2 line for planar decoupling, the same aluminium electrolytic family as the Model 25 for PSU smoothing, and the same drive-logic-board electrolytics as other PS/2 models. The Model 30 is generally less prone to capacitor failure than the IBM PS/2 Model 70 and IBM PS/2 Model 80 (whose surface-mount cap leakage is famous), but failed planar tantalums and aged drive-board caps are well documented in field service.
Safety Warning
The Model 30 PSU contains mains-rectified bulk capacitors that can hold a lethal charge after power-off. Before any PSU work:
  1. Power off and unplug the mains lead.
  2. Wait at least 30 seconds.
  3. Discharge the bulk capacitor through a 1 kΩ / 5 W resistor.
  4. Verify with a multimeter.
The Model 30 has no CRT — there is no anode-discharge step for the system unit (only for the matching IBM PS/2 monitor).
Capacitor Families on the Model 30
  • Tantalum capacitors (10 µF / 16 V, marked "106 16V") on the planar +5 V and +12 V rails. Fail short-circuit; pull rails into PSU fold-back. Same family as Model 25.
  • Aluminium electrolytic capacitors in the PSU primary and secondary; in the drive logic boards; and small bypass values on ISA cards. Dry out with age, increase ESR, leak electrolyte.
  • X2-class line suppression capacitors on the PSU primary — if RIFA-branded, prone to cracking and fuming after 30+ years.
  • Battery-backed RTC module (Model 30 286 only) — the Dallas DS1287 / DS12887 contains a lithium cell that fails after 10–15 years and is not capacitor-related but is replaced using similar desolder/resolder skills.
Planar Capacitors
The Model 30 8086 planar carries fewer tantalums than the AT-class planars and even fewer than the Model 70 / 80, because the proprietary PS/2 single-cable interface routes drive power through the planar with limited filtering and the system runs on a single 70 W PSU. The Model 30 286 planar adds bypass caps near the VLSI VL82C100–104 chipset.
This guide does not enumerate each tantalum's reference designator on the Model 30 planar because IBM did not publish a unified silkscreen reference for the Model 30, and the 8086 and 286 planars differ. Treat every orange or yellow bead tantalum on the planar as a candidate for inspection if the system will not start.
Failure Mode
Tantalums on the Model 30 are commonly marked "106 16V" (10 µF, 16 V working voltage). Polarised. Two failure modes:
  • Short circuit — pulls +5 V or +12 V down. The PSU folds back; system shows "click then nothing" or continuous click retry cycle.
  • Open circuit — no immediate symptom; decoupling degraded; system noise-sensitive.
Diagnostic Procedure
  1. Discharge the PSU bulk capacitor.
  2. Remove the planar from the chassis (release the captive plastic push-pin tabs holding the drive cage; the planar then lifts free).
  3. Set multimeter to diode test or 200 Ω resistance.
  4. Probe each tantalum in-circuit: black probe to ground, red probe to the rail side. A good cap reads as an open / high resistance after a brief charge pulse; a failed (shorted) cap reads close to 0 Ω.
  5. Where a short is found, remove the cap to confirm out-of-circuit; other components on the same rail can give false-short readings.
  6. Replace with a fresh 10 µF / 16 V tantalum or a 10 µF / 25 V low-ESR ceramic.
Removal and Replacement
  1. Mark polarity with a paint pen or photograph.
  2. Apply fresh solder + flux to both leads from the underside.
  3. Heat one pad, lever the cap up with tweezers. Heat the other pad and lift clear.
  4. Clean both holes with solder wick.
  5. Insert the new cap matching the silkscreen polarity (+ on cap to + on silkscreen).
  6. Solder both leads. Inspect for a clean fillet.
  7. Trim leads flush.
Power Supply Recap
The Model 30 PSU is rated 70 W (early production) or 80 W (later production). Internally it contains:
  • Primary side: mains rectifier, X2 line suppression capacitor on the mains input, bulk capacitor (typically 100 µF / 200 V or 220 µF / 200 V), switching transistor, switching transformer.
  • Secondary side: rectifier diodes, smoothing electrolytics (1000 µF / 16 V on +5 V; 470 µF / 35 V on +12 V; smaller values on −5 V and −12 V), output filter chokes, optocoupler.
After 30+ years the secondary electrolytics commonly need replacement. Symptoms:
  • Reduced or sagging rails under load.
  • PSU whine.
  • System resets under heavy disk activity.
  • PSU refuses to start when hot.
Recap procedure (same as Model 25):
  1. Discharge the bulk capacitor; verify with a multimeter.
  2. Remove the PSU from the chassis.
  3. Open the PSU housing (typically screws on the Model 30 PSU; some welded variants exist).
  4. Photograph the board before any work. Mark each electrolytic's polarity.
  5. Desolder each electrolytic. Use solder wick.
  6. Fit replacements: low-ESR, 105 °C rated, equal capacitance, equal or higher voltage rating.
  7. Inspect the X2 mains suppression capacitor — if cracked, bulged, or leaking, replace with a fresh X2 cap. RIFA-branded X2 caps from IBM PSUs of this era are well known to vent and smoke.
  8. Reassemble; verify rails on the bench with a multimeter under a 1 A resistive load before refitting.
Drive Logic Board Recap
PS/2 floppy drives (ALPS, Mitsubishi, Sony, YE-Data) commonly fail by aged electrolytics on the drive logic board. Typical values:
  • 47 µF / 16 V near the motor driver — most common to leak.
  • 10 µF / 25 V near the read-write amplifier.
Symptoms: drive does not seek, drive seeks but cannot read or write, slow seek (timing cap leaked), or drive belt slip (rubber belt aged separately).
Procedure: remove the drive from the chassis, remove the drive logic board, inspect for leaked electrolyte (brown crust around cap bases or on the PCB), clean with IPA, replace each electrolytic with a low-ESR equivalent. The drive belt is replaced at the same time (Mitsubishi MF355C family) with a 54×1 mm flat rubber belt.
ISA Card Capacitors
ISA cards in the Model 30 (memory expansion, network, modem, third-party VGA on the Model 30 8086) carry small numbers of tantalums and electrolytics. The standard 10 µF / 16 V tantalum failure mode applies. If the planar tests clean off-system but the system will not start with the cards installed, pull each card and re-test.
Replacement summary — planar + drive logic board
Value Voltage Replacement type Where used
10 µF 16 V Tantalum or low-ESR ceramic Planar bypass caps
22 µF 16 V Tantalum Planar bypass
47 µF 16 V Aluminium electrolytic, low-ESR, 105 °C Drive logic board motor driver
100 µF 16 V Aluminium electrolytic PSU secondary +5 V
470 µF 16 V Aluminium electrolytic Drive supply / PSU secondary +12 V
1000 µF 16 V Aluminium electrolytic, low-ESR PSU secondary +5 V smoothing
Polarity Reference
The PS/2 planar silkscreen marks the + side of each electrolytic with a small "+". The cap body shows the negative side with a stripe and "−". Match these conventions.
Polarity reference for IBM motherboard tantalum capacitors — the same convention applies to the Model 30 planar. (Image: minuszerodegrees.net)
A failed tantalum often shows no visible damage.
A failed tantalum capacitor on an IBM motherboard. The small black hole on the body is the only visual indication of failure — in most cases there is no visual sign at all. (Image: minuszerodegrees.net)
Post-Recap Verification
  1. Power up on the bench with a known-good PSU and no peripherals.
  2. Verify the boot screen appears.
  3. Insert a known-good Reference Diskette and boot.
  4. Run Advanced Diagnostics (Ctrl-A from the main menu).
  5. Test each subsystem.
If any test fails after a recap, re-inspect the polarity of every replaced cap before suspecting another fault.
When Not to Recap
A blanket recap is not always necessary. If the Model 30 boots, POSTs cleanly and runs reliably, the caps are within tolerance.
Always recap if:
  • Fluid leak visible from any electrolytic on planar, PSU or drive board.
  • PSU smoke, fishy odour or audible whine.
  • Diagnostic procedure identifies a shorted tantalum.
  • Drive will not read after a fresh belt.
