IBM PS/2 Model 30 Maintenance Guide
Routine maintenance on the IBM PS/2 Model 30 (machine type 8530) covers two machines: the original 8086 Model 30 (8530-001, -002, -021) and the Model 30 286 (8530-E01 to E41). Both are desktop system units with no built-in display, so the work is on the planar, the riser card, the power supply and the drives.
Safety
[edit | edit source]The power supply rectifies the mains, and its reservoir capacitor can hold at least the peak mains voltage (about 325 V on 230 V mains) after the plug is pulled. Before working inside the supply, unplug it, discharge that capacitor through a resistor and confirm with a meter that it has fallen to a few volts.
On a Model 30 286, set the voltage switch on the rear to 100–125 V or 200–240 V before plugging in the power cord.[1] The 8086 Model 30 supply accepts 120 V or 220/240 V without a switch.[2]
There is no CRT in the system unit. For a PS/2 display, see CRT Discharge Procedure.
Identifying your model
[edit | edit source]The machine type and submodel are on the rear label, for example "Type 8530-E21".
| Model 30 | Model 30 286 | |
| Submodels | 001, 002, 021 | E01, E21, E31, E41 (E0R, E2R with a 50-key keyboard) |
| Processor | 8086-2 at 8 MHz, U10 | 80286 at 10 MHz, ZM36 |
| Video | MCGA | VGA |
| Clock | MM58167AN at U16; 3 V cell soldered to the riser | DS1287 clock module in a socket at ZM35 |
| Diskette drive | 720 KB | 1.44 MB, "1.44" on the eject button |
| Power supply | 70 W, no voltage switch | 90 W, voltage switch on the rear |
Sources: IBM's announcement letters and Hardware Maintenance Manual,[3][4] the HMR[1] and the planar maps.[5][6]
Planar layout
[edit | edit source]The 8086 planar was built as P/N 61X8823 and in two later Greenock versions, P/N 33F4888 and FRU 33F8474. The reference designators are largely the same on all three and on the 8086 Model 25.[5]
| Designator | Device |
| J1, J2 | Mouse and keyboard connectors |
| J3 | Parallel port |
| J4 | Video connector (HD-15) |
| J5 | Serial port (DB-25) |
| J6 | Riser slot |
| J7, J9 | Power connectors |
| J10 | Two-pin keylock header |
| J11 | 44-pin fixed-disk connector |
| J12 | 40-pin diskette connector |
| J13 | Dual 30-pin memory socket |
| F1, F2 | Probably the mouse and keyboard fuses (F2 absent on the second Greenock board) |
| U10 | Intel 8086-2 |
| U13 | 8087 socket |
| U16 | MM58167AN real-time clock |
| U17, U20 | ROM BIOS |
| SP1 | Speaker |
| Y4 | 32.768 kHz clock crystal |
On the 286 planar, IBM's HMR locates J3 parallel, J5 serial, J6 bus adapter (riser), J1 pointing device, J2 keyboard, J9 and J10 memory packs, J11 fixed disk, J7 and J14 power, J4 display, J13 password override, ZM36 processor, ZM35 clock module, ZM1 coprocessor and J12 diskette.[1]
Opening the system unit
[edit | edit source]Tools: a screwdriver and an anti-static wrist strap. IBM's steps for the Model 30 286:[7]
- Turn off the system unit and every external device.
- Unplug the system unit's power cord, then the cords of any external devices.
- Remove all cables from the rear.
- If there is a cover lock, unlock it and remove the key.
- Loosen the two cover screws and remove the cover.
IBM's removal order for the system board is adapters, bus adapter (riser), memory packs and coprocessor, then all cables. The power supply comes out after the cover, the rear cover and the bus-adapter support.[1]
Cleaning
[edit | edit source]- Brush and blow dust out of the planar, riser, drives and supply vents with low-pressure air. Hold any fan still while doing so.
- Clean the keyboard and mouse sockets and the DB-25 connectors with contact cleaner on a foam swab.
- Check the planar for leaked electrolyte, and the diskette drive board more closely: PS/2 drives have no dust shutter and collect dirt, and their surface-mount electrolytics leak.[8][9] See IBM PS/2 Model 30 Capacitor Replacement Guide.
Power supply checks
[edit | edit source]The supply connects to the planar through two 6-pin connectors, P3 and P4; P3 is nearer the rear.[2][4]
| Pin | P3 | P4 |
| 1 | Power Good | Ground |
| 2 | Ground | Ground |
| 3 | +12 V | −5 V |
| 4 | −12 V | +5 V |
| 5 | Ground | +5 V |
| 6 | Ground | +5 V |
Measure with the system switched on and running, with the meter leads on the pins in the table. The negative rails are measured with the leads reversed, so they read positive.[10]
| Rail | − lead | + lead | Minimum | Maximum |
| +5 V | P3-5 | P4-4 | +4.8 V | +5.2 V |
| −5 V | P4-3 | P3-6 | +4.6 V | +5.5 V |
| +12 V | P4-1 | P3-3 | +11.5 V | +12.6 V |
| −12 V | P3-4 | P4-2 | +10.8 V | +13.2 V |
The supply withholds Power Good unless every rail is above its minimum under-voltage sense level: +4.5 V on +5 V, −4.3 V on −5 V, +10.8 V on +12 V and −10.2 V on −12 V. After the machine has been off for five seconds or more, Power Good resets the system logic at switch-on and POST begins.[2][1]
Power Good at P3-1 should read +3.5 to +5 V with the system running. If it does not, remove all adapters, cables and extra memory and try again. If Power Good then appears, one of those items was shorting a rail; refit them one at a time to find it.[10] IBM's specification for the signal is 2.4 to 5.25 V active, 0.0 to 0.4 V inactive, with a turn-on delay of 100 to 500 ms.[2]
The supply FRU numbers are 61X8905 for the Model 30 and 27F4166 for the Model 30 286.[4] The 8086 Model 25 uses a different power connector from the 8086 Model 30, so its supply does not fit.[9]
Clock and battery
[edit | edit source]Model 30
[edit | edit source]The clock is a National Semiconductor MM58167AN at U16 with a 32.768 kHz crystal at Y4.[5] IBM lists it among the system board functions as "real-time clock with battery", at I/O addresses hex 00B0–00BF and 00E0–00EF.[2]
The cell is on the riser card (P/N 61X8864 or 61X8910), not the planar: a 3 V lithium Panasonic BR-2/3A soldered at B1.[5] IBM gave the cell no FRU number and replaced the whole riser. A direct replacement is a 2/3A (17 × 33.5 mm) cell with solder tabs, one pin on the negative tab and two on the positive: Panasonic BR-2/3A, Sanyo CR-2/3A or CR17335SE. A 3 V holder for two AA cells, or a BH2/3A holder, can be wired in instead.[11]
IBM retain tip H067282 corrects the early 8530 Hardware Maintenance Service manual. On its system board map (page 0100-4) the bus adapter pins labelled "0" and "39" are really pins 1 and 40. Measure the battery voltage between pins 38 and 39, the second and third pins from the right-hand edge, and replace the bus adapter if it is below 2.5 V.[5]
Model 30 286
[edit | edit source]The clock and its CMOS RAM are in a Dallas DS1287 module with the lithium cell sealed inside, IBM FRU 8509237.[4][11] The module plugs into a connector at ZM35. IBM's instructions are to remove it carefully without bending the pins or prying against the socket or board, and to fit it with the white dot towards the rear of the system unit.[1]
The DS1287 is obsolete. Replacements that work in a PS/2 are the DS12887, the lead-free DS12887+, the DS1287A and DS12887A, and the Benchmarq bq3287MT. The DS12C887 handles the century byte differently and does not work. The original module can also be reworked with an external cell.[11]
Error codes and setup
[edit | edit source]IBM's PS/2 Hardware Maintenance Manual has a separate symptom index for the AT-bus models, including the Models 30 and 30-286. Its entries for the clock and configuration codes:[4]
| Code | IBM action and FRU order |
| 161, 163, 165 | Set the time and date; bus adapter; clock module; battery; system board |
| 162 | Run Setup and Automatic Configuration; clock module; system board |
| 162, with Advanced Diagnostics unable to run | Diskette drive; system board; diskette drive cable |
| 164 | Run Setup and Automatic Configuration (check memory); system board |
For a clock that loses time, IBM lists the bus adapter, the clock module and the system board, and notes that it is not always a hardware fault: the time-of-day count is interrupt-driven and drifts with interrupt activity.[4] On the 8086 Model 30 the bus adapter is the riser that carries the cell.[5] IBM's caution with code 161 is that the lithium battery presents a fire, explosion or severe burn risk. A weak battery loses all the setup information; if only part of it is lost, the battery is probably not the cause.[4][12] See Battery Refurbishment and Battery Explosion, Capacitor or Corrosion Damage.
After replacing the battery or module, start the Starter Diskette and let Automatic Configuration run, or restore a customised configuration from the backup copy of the Starter Diskette. Then set the date and time.[1]
Power-on password
[edit | edit source]To clear a forgotten power-on password on a Model 30 286, find the J13 jumper on the system board. If it covers the first and second pins, move it to the second and third; if it covers the second and third, move it to the first and second. Leave it in the new position until the password next needs resetting.[7][1]
Connector care
[edit | edit source]- The keyboard and pointing-device sockets use the same interface logic. On the Model 30 either device can plug into either socket.[2] On the Model 30 286 the keyboard socket is marked "1" and the pointing device "2".[1]
- The ports are fused on the planar. Code 305 is a keyboard voltage error, and IBM's first FRU is the keyboard port fuse, then the keyboard cable, then the system board.[12][5][6]
- The parallel and serial ports are 25-pin D connectors.[5]
Drive interface
[edit | edit source]Each drive takes power and signals through one cable from the planar; there are no separate drive power connectors.[13] On the Model 30 planar IBM gives:
- diskette connector J12 (40 pins): pin 38 +5 V, pin 40 +12 V, all odd pins and pin 36 ground;[2]
- fixed-disk connector J11 (44 pins): pins 30 and 32 +5 V, pins 40, 42 and 44 +12 V.[2]
Because the supply rails share the connector with the signal lines, check that each cable is aligned and fully seated before switching on. On the Model 30 286's 1/3-height diskette cable, IBM notes that pins 35 to 40 at the system-board end are not used.[1]
Diskette drives
[edit | edit source]- The 8086 machines shipped with 720 KB drives (FRU 96F7678). The Model 30 286 uses 1.44 MB drives: FRU 72X8523 (half height) or 64F0162 (one-third height).[4]
- A 1.44 MB drive has "1.44" on its eject button. It reads and writes both 1 MB (720 KB) and 2 MB (1.44 MB) diskettes; a 720 KB drive cannot use 2 MB diskettes.[1]
- The 8086 Model 30 has undocumented high-density support. Sony drives are the ones likely to work; other makes are seen as low density or not at all, and later planars accept more drives.[9][13]
- Code 604 means an unsupported drive or cable (the drive must be a media-sense type). Codes 662 and 663 report the wrong drive type or the wrong media and are information only.[12]
- Mitsubishi's MF355C specification describes a direct-drive brushless spindle motor at 300 rpm, so drives of that design have no belt.[14] The common faults are dirt on the Mitsubishi head actuator spindle, a detached head-damper pad on ALPS drives, and leaking capacitors on the drive board.[8] See IBM PS/2 Model 30 Capacitor Replacement Guide and Floppy Drive Repair.
Fixed disk
[edit | edit source]The Model 30's fixed-disk connector is a dedicated I/O channel, not an ST-506, ESDI or IDE interface. It carries I/O channel signals with IRQ 5 and DMA channel 3, a card-select decoded at hex 032x, a "disk installed" line and three address lines that select registers inside the controller, which is part of the drive.[2][3] Only IBM's drives for this interface work, and the drive sits in a caddy.[13] IBM's parts lists give 20 MB drives FRU 6128285 and 61X8929, a 30 MB drive 6128279 and, for the 286, a 45 MB drive 92F0016.[4]
- Before removing a fixed disk from a Model 30 286, IBM says to park the heads with the Advanced Diagnostics diskette.[1]
- A drive that will not spin up after long storage may have stiction, the heads stuck to the platters. Peter Wendt's options are power cycling, or unplugging the unit and rotating it sharply a few times; he warns never to lift and drop the front of the case. Copy the data off at once if it starts.[15]
- An XT-IDE card on the ISA bus is the storage upgrade Ardent Tool suggests for the related 8086 Model 25, and it bypasses the planar interface.[9]
IBM retain tip H007157 says that fixed-disk operation on the 8530-001 and -021 depends on the right combination of system board, fixed disk and Advanced Diagnostics version, and that formatting with the wrong version causes fixed-disk errors:[5]
| Machine | System board | Fixed disk | Advanced Diagnostics |
| 8530-021 below serial 2500000 | 61X8907 | 61X8929 | 8530, any version |
| 8530-021 above serial 2500000 | 33F8474 | 6128285 | 8530, version 1.05 |
| 8530-001, all | 33F8474 | 6128285 or 6128279 | 8530, version 1.05 |
| 8530-E21 only | 27F4069 | 6128285 | 8530-286, version 1.02 |
| 8530-E31 and E01 | 34F0046 | 6128285 or 6128279 | 8530-286, version 1.02 |
Drives 6128285 and 6128279 must not be fitted to an 8530-021 below serial number 2500000. Version 1.05 of the 8530 Advanced Diagnostics was IBM publication S15F-2153.[5]
IBM service notices
[edit | edit source]IBM retain tip H043664 covers some 8530-001 and -021 machines on which the cursor keys put unexpected characters on the screen and a 501 appears with two or more option cards fitted, such as the 3270 and Token-Ring adapters. Advanced Diagnostics may not detect it. Check the modules at U9 (next to the coprocessor socket, P/N 72X8203) and U15 (next to the speaker, P/N 61X8965): good ones have "Japan" printed on them. IBM's fix was system board FRU 64F3453; machines with serial numbers above 55-00HV000 already have it.[5]
Retain tip H094152 states that the 8086 models 001, 002 and 021 do not support the 8515 or 8516 and show compressed, distorted video on them. They support the 8503, 8504, 8507, 8512, 8513 and 8514. The 286 models support the 8503, 8504, 8512, 8513, 8514, 8515 and 8516.[5]
Retain tip H036143 covers Model 30 286 machines shipped after 1 August 1989, on which a 4717 printer attached directly gives an 8602 error and does not work, because a planar change grounded pin 2 of the pointing-device port. IBM supplied interposer cable P/N 31F6759 (RPQ S82021).[6]
Things that are not faults
[edit | edit source]- Distorted video on an 8515 or 8516 connected to an 8086 Model 30 (H094152 above).
- A 162 after a device has been added or removed. IBM's first action is to run Setup and Automatic Configuration.[4]
- False errors, or a false power-on password prompt, after warm-booting the Starter Diskette. Switch on with the diskette already in the drive.[12]
- Codes 662 and 663, which report the wrong drive or media type.[12]
Recommended tools
[edit | edit source]- Screwdriver and anti-static wrist strap.
- Digital multimeter.
- Isopropyl alcohol and foam swabs.
- Soldering iron and solder wick for riser-battery and capacitor work.
- A 2/3A 3 V lithium cell with tabs (Model 30) or a DS12887-type module (Model 30 286).
- Copies of the Starter Diskette and Advanced Diagnostics diskette for the model.
See also Recommended Tools.
[edit | edit source]- IBM PS/2 Model 30
- IBM PS/2 Model 30 Troubleshooting Guide
- IBM PS/2 Model 30 Capacitor Replacement Guide
- IBM PS/2 Model 25 Maintenance Guide
- Hard Drive Maintenance and Repair
- Floppy Drive Repair
[edit | edit source]- ↑ 1.00 1.01 1.02 1.03 1.04 1.05 1.06 1.07 1.08 1.09 1.10 1.11 IBM, IBM PS/2 Model 30 286 Hardware Maintenance Reference, S64F-3988-00, March 1990. Hosted on this wiki as IBM PS2 Model 30 286 Hardware Maintenance Reference (PDF). Sections 1.1.2 (power-on password, J13), 1.2.2 (CMOS RAM and battery), 1.2.6 (keyboard and pointing-device connectors), 2.2 (diskette drive identification and media compatibility), 3.1 (power supply switch and under-voltage sense levels), 3.2 (POST), 6.3 (park the heads before removing a fixed disk), 6.14 (1070 clock module), 7.4 (system board locations), 7.6 (1/3-height diskette cable).
- ↑ 2.0 2.1 2.2 2.3 2.4 2.5 2.6 2.7 2.8 IBM, IBM Personal System/2 Model 30 Technical Reference, January 1987. Hosted on this wiki as IBM PS2 Model 30 Technical Reference (January 1987) (PDF). Keyboard and pointing device controller, p. 1-9; interrupt listing, Figure 1-9; I/O address map, Figure 1-12; diskette drive connector, Figure 1-97, p. 1-105; fixed disk connector, pp. 1-106 and 1-107; Section 3, "Power Supply", pp. 3-3 to 3-6 (input, outputs, sense levels, power-good signal, P3 and P4 pin assignments).
- ↑ 3.0 3.1 IBM Announcement Letter 187-048, IBM Personal System/2 Model 30, 2 April 1987, text at ardent-tool.com. Models 002 and 021 with 720 KB drives, the 70 W "Universal ... power supply, with internal sensing", and the Starter Diskette.
- ↑ 4.00 4.01 4.02 4.03 4.04 4.05 4.06 4.07 4.08 4.09 IBM, IBM Personal System/2 Hardware Maintenance Manual, S52G-9971-02, October 1994. Hosted on this wiki as IBM Personal System 2 Hardware Maintenance Manual (S52G-9971-02, October 1994) (PDF). Symptom-to-FRU index for AT-bus models: "Real Time Clock loses time", p. 14, and numeric error codes 161–165, p. 15; lithium battery caution with code 161, p. 36; "Real-Time Clock Problems", p. 150; Models 30 and 30-286 power connector pin assignments, p. 138; Model 30 parts, p. 228; Model 30-286 parts, p. 230; system specifications for 8530-001 to E41, p. 435.
- ↑ 5.00 5.01 5.02 5.03 5.04 5.05 5.06 5.07 5.08 5.09 5.10 5.11 Louis Ohland, Tomáš Slavotínek et al., "8530 Planar (8086)", Ardent Tool of Capitalism. Designator maps of planars 61X8823, 33F4888 and 33F8474 (F1 "Mouse fuse?", F2 "Keyboard fuse?", F2 missing on the second Greenock board); riser card P/N 61X8864 and 61X8910 with the B1 BR-2/3A cell; and the full text of IBM retain tips H007157, H043664, H067282 and H094152.
- ↑ 6.0 6.1 6.2 Louis Ohland, Tomáš Slavotínek et al., "8530 286 Planar", Ardent Tool of Capitalism. Designator maps of the PGA and PLCC (FRU 34F0046) planars, including F1, J13 password override and ZM35 DS1287, and IBM retain tip H036143.
- ↑ 7.0 7.1 IBM, Personal System/2 Model 30 286 Guide to Operations, first edition, September 1988. Hosted on this wiki as IBM PS2 Model 30 286 Guide to Operations (PDF). "Cover Removal", p. 2-2; "Power-on Password Reset", pp. 3-4 and 3-5.
- ↑ 8.0 8.1 "60, 65 SX, and 80 – Common Devices", Ardent Tool of Capitalism. Peter Wendt on ALPS and Mitsubishi PS/2 diskette drives: both collect dust through the slot, which has no shield; the Mitsubishi 355 collects dirt on the head actuator spindle; ALPS drives lose the head-damper pad; Mitsubishi drives have capacitors that cause 6xx errors.
- ↑ 9.0 9.1 9.2 9.3 Louis Ohland, William R. Walsh, Tomáš Slavotínek et al., "8525 Planar", Ardent Tool of Capitalism. William Walsh on PS/2 diskette drives (dust, and replacing every surface-mount electrolytic on the drive board), the undocumented 1.44 MB support of the 8086 Model 25 and Model 30 with Sony drives, XT-IDE as the storage upgrade, and the Model 25 8086 using a different power connector from the Model 30 8086.
- ↑ 10.0 10.1 Louis Ohland, Tomáš Slavotínek et al., "8525 / 8530 Power", Ardent Tool of Capitalism. P3/P4 measurement limits for the Model 30 and 30-286, the minimum under-voltage sense levels, the Power Good reading of +3.5 to +5 V with the system running, and the procedure of removing adapters, cables and extra memory when Power Good is absent.
- ↑ 11.0 11.1 11.2 Ardent Tool of Capitalism, "PS/2 RTC/CMOS Batteries", based on content by Bob Eager and Peter H. Wendt. Model 30 (8086): 3 V battery, soldered, no FRU; the through-hole cell "was to be replaced with the entire riser board"; BR-2/3A, CR-2/3A and CR17335SE equivalents and the tab arrangement; AA and BH2/3A holders. Model 30-286: Dallas module FRU 8509237 (DS1287), replaced by the DS12887, DS12887+, DS1287A, DS12887A or bq3287MT, not the DS12C887; reworking the module with an external cell.
- ↑ 12.0 12.1 12.2 12.3 12.4 "PS/2 Error Codes", Ardent Tool of Capitalism, with the code tables for 160–199 and 300–999. The warm-boot warning, the battery note, 305 (keyboard voltage error; keyboard port fuse, keyboard cable, system board; "If no fuse in system replace system board"), 604 (unsupported drive or cable, drive must be media sense type) and 662 and 663 (wrong drive type, wrong media type; information only).
- ↑ 13.0 13.1 13.2 "IBM PS/2 Model 30", DOS Days. The drive fitting with no Molex connectors, the Model 30 fixed-disk interface being neither ESDI nor standard MFM, the drive caddy, and the Sony 1.44 MB drive that works in the 8086 machine.
- ↑ Mitsubishi Electric, 3.5 inch Flexible Disk Drive Standard Specifications, MF355C, UGD-0527A, February 1987. Hosted on this wiki as File:Mitsubishi MF355C 3.5 inch Diskette Drive Specifications (UGD-0527A, Feb 1987).pdf. Section 1.1 (p. 3) and section 2.3, "Rotation Mechanism" (p. 9): brushless DC direct-drive spindle motor at 300 rpm.
- ↑ "Known Problems – Experience, RETAIN Tips, ECAs", Ardent Tool of Capitalism. Peter Wendt on hard-disk stiction and ways to free a stuck drive.
