Macintosh 128K/512K Troubleshooting
Troubleshooting is crucial for diagnosing and resolving issues with your Macintosh 128K and Macintosh 512K. This comprehensive guide outlines common symptoms, advanced diagnostic procedures, and actionable repair strategies based on community expertise and service documentation.
Quick Diagnosis Reference
Use this table to quickly identify the most likely problem area and jump to the appropriate diagnostic section.
| What You See/Hear | What You Don't See/Hear | Most Likely Problem | Go To Section |
| Nothing (completely dead) | No fan, no CRT glow, no sounds | Power supply failure | Power Supply |
| CRT glow, fan running | No chime, no video | Logic board failure | Logic Board |
| Normal chime | Black screen, no image | Video/CRT circuit failure | Video Display |
| Horizontal black/white stripes | No chime (Simasimac pattern) | Severe logic board failure | Simasimac |
| Multiple chimes or odd tones | Various, often with Sad Mac | Memory/ROM failure | Chimes of Death |
| Normal boot, "?" disk icon | Disk won't insert or ejects immediately | Floppy drive mechanical failure | Floppy Drive |
| Partial boot, then freeze | Varies by how far boot progresses | Intermittent component failure | Intermittent Issues |
| Checkerboard pattern | May or may not chime | ROM failure or voltage issues | Logic Board |
| Wavy lines, geometry distortion | Normal boot sounds | Analog board capacitor failure | Capacitor Issues |
| Smoke, burning smell | Usually immediate shutdown | RIFA capacitor explosion | Capacitor Issues |
Logic Board Specific Issues
The logic board contains critical digital circuits that are prone to specific failure modes, particularly related to socketed components and aging semiconductors.
ROM Socket & ROM Failures
| Symptom | ROM Type | Diagnostic Test | Solution |
| Checkerboard pattern on startup | 64KB ROM set (4 chips) | Remove and clean ROM chips, test in programmer | Clean sockets, replace failed ROM chips |
| Sad Mac with 01xxxx error | ROM checksum failure | Verify ROM chips individually | Replace corrupted ROM, check socket connections |
| Random crashes, unstable operation | Intermittent ROM contact | Reseat ROMs, check socket pin tension | Clean with DeoxIT, replace sockets if loose |
| No boot, immediate Sad Mac | One or more ROM chips failed | Test each ROM chip separately | Replace failed ROM(s) with known good chips |
ROM Testing Procedure:[1]
- Remove all ROM chips (handle with anti-static precautions)
- Clean chip pins and socket contacts with DeoxIT
- Test each ROM chip in EPROM programmer or known-good Mac
- Check socket pin tension - pins should grip firmly
- Install ROMs ensuring proper orientation (notch alignment)
ROM Socket Restoration:
- Use quality machine-pin sockets for replacement
- Check continuity from socket pins to PCB traces
- Apply thin coat of DeoxIT to socket contacts before chip installation
PAL (Programmable Array Logic) Failures
The Logic Address Generator (LAG) PAL is a critical custom chip that frequently fails in 128K/512K systems.
| PAL Location | Function | Failure Symptom | Test Method |
| LAG (Logic Address Generator) | Address decoding, timing | Simasimac, no boot, address line stuck | Oscilloscope address lines, logic analyzer |
| ASG (Address Select Generator) | Memory bank selection | Memory access errors, wrong bank selected | Test with known-good RAM configuration |
| TSG (Timing Signal Generator) | Clock distribution | Timing-related crashes, intermittent operation | Scope clock signals at various test points |
PAL Testing Method:[2]
- Scope critical signals (e.g., RESLIN pin should be active, not stuck high)
- Compare signal patterns with known-good board
- Check input signals to PAL are valid
- If PAL is confirmed bad, source replacement from donor board (no reproductions available)
PAL Replacement Sources:
- Salvage from Macintosh Plus (compatible PALs)
- Other 128K/512K donor boards
- Rare NOS (New Old Stock) if available
VIA (Versatile Interface Adapter) Problems
The 6522 VIA chips handle I/O, timers, and system control functions.
| VIA Chip | Primary Functions | Failure Symptoms | Test Procedure |
| VIA 1 (U6D) | Real-time clock, sound, system timers | No sound, time not kept, system instability | Test timer outputs, sound generation |
| VIA 2 (U4D) | Keyboard, mouse, floppy control | No keyboard/mouse response, floppy issues | Test I/O port responses, handshake signals |
| Both VIAs | Interrupt handling, peripheral control | System freezes, peripheral malfunctions | Check interrupt acknowledge cycles |
VIA Testing Protocol:
- Check power supply to VIA chips (+5V, ground)
- Test clock input (1MHz derived from system clock)
- Verify interrupt lines are not stuck
- Test specific I/O functions (keyboard input, sound output)
- Replace with known-good 6522 VIA chip
Address/Data Buffer Failures
| IC Type | Location | Function | Failure Mode | Test Method |
| 74F244 | Address buffers | Drive address bus | Stuck address lines, memory access errors | Logic analyzer on address bus |
| 74F245 | Data buffers | Bidirectional data | Data corruption, read/write errors | Loop-back testing, data pattern tests |
| 74F258/74F253 | Memory mux | RAM bank selection | Wrong memory bank access | Scope select lines during memory access |
Buffer Testing Procedure:
- Remove suspect IC from socket
- Test in dedicated IC tester or substitute known-good part
- Check for proper signal propagation (input to output)
- Verify timing relationships with oscilloscope
- Replace with 74ACT series for improved reliability
Crystal Oscillator & Clock Issues
| Component | Frequency | Function | Failure Symptom | Test Point |
| Main crystal | 15.6672 MHz | System master clock | No boot, erratic timing | CPU pin 15, oscillator output |
| RTC crystal | 32.768 kHz | Real-time clock | Time not kept, VIA issues | VIA clock input |
| Clock divider | Various | Derive system clocks | Timing errors, sync issues | Clock distribution points |
Clock Testing Method:
- Use frequency counter or oscilloscope to measure clock signals
- Check crystal for physical damage (cracks, loose connections)
- Verify clock reaches all destination chips at proper levels
- Test load capacitors around crystal (typically 15-22pF)
Clock Troubleshooting Steps:
- Measure primary oscillator output (should be clean 15.6672 MHz)
- Check clock distribution to CPU, VIAs, and other ICs
- Verify clock duty cycle (should be approximately 50%)
- Test with substitute crystal oscillator module if suspect
RAM Socket & Address Decoding
| Problem Area | Symptoms | Diagnostic Focus | Common Solutions |
| RAM socket corrosion | Intermittent memory errors, boot failures | Visual inspection, continuity testing | Clean sockets, reseat RAM chips |
| Address line opens | Memory test failures, wrong data returned | Logic analyzer, continuity testing | Repair traces, replace address buffers |
| Data line problems | Data corruption, parity errors | Pattern testing, swap testing | Check data buffers, repair connections |
| Chip select logic | Wrong memory banks accessed | Scope chip select signals | Check address decoding logic, PALs |
Memory System Testing:
- Test each RAM chip individually in programmer
- Verify address line continuity from CPU to RAM sockets
- Check data line integrity with pattern tests
- Test memory decoding logic with address variations
Component-Level Logic Board Repairs
Socket Replacement Procedure:
- Remove old socket using desoldering wick or vacuum pump
- Clean PCB holes with desoldering braid
- Install new machine-pin socket (avoid cheap stampedpin types)
- Verify all connections with continuity tester
Trace Repair Techniques:
- Identify broken traces with continuity testing
- Clean corrosion with white vinegar, then IPA
- Repair with 30AWG kynar wire, routed along original trace path
- Secure repairs with UV-cure conformal coating
IC Replacement Guidelines:
- Always use anti-static handling procedures
- Match or exceed original IC specifications
- Prefer CMOS versions (74ACT series) over TTL when available
- Keep spare common ICs: 74F244, 74F245, 74F258, 6522 VIA
Power Supply Failures & Voltage Issues
The analog board power supply is notoriously failure-prone due to the lack of internal cooling fan—Steve Jobs objected to fan noise and preferred to risk component overheating.[3]
| Symptom | Voltage Reading | Primary Cause | Diagnostic Steps | Solution |
| No signs of life | 0V all rails | Blown fuse, shorted components | Check F2 fuse, inspect for burnt components | Replace fuse, identify and replace shorted parts |
| Ticking/chirping noise | Low voltage (3-4V on 5V rail) | Shorted 5V rail, failed flyback | Disconnect logic board, measure voltages | Replace shorted capacitors, test flyback transformer |
| Low voltage regulation | 9-10V on 12V, 3-4V on 5V | Failed feedback circuit, bad optocoupler | Test U3 optocoupler with multimeter | Replace U3 (4N25/4N26), check feedback resistors[4] |
| Voltage rises when powered off | Crowbar circuit activation | SCR Q10 triggering | Scope SCR gate signal | Replace Q10 SCR, check trigger circuit |
| Cannot adjust voltage | Fixed output regardless of R56 | Open feedback loop | Check continuity of R56, test U3 | Replace failed components in feedback path |
Detailed Voltage Testing Procedure
Equipment needed: Digital multimeter, oscilloscope (recommended), dummy load resistors
Test Points:[5]
- External floppy connector: Pins 7-8 (+12V), Pin 6 (+5V), Pin 1 (Ground)
- Internal floppy power: 4-pin Molex connector
- Logic board harness: J4 connector pins
Specification tolerances:
- +5V rail: 4.85V – 5.15V (must be within spec)
- +12V rail: 11.9V – 12.75V (measure at external floppy connector)
- -12V rail: -10.8V – -13.2V (used only for floppy drive in 128K/512K)
Load testing: Use 1-2A dummy load on 12V rail, 3-4A on 5V rail to test regulation under load.
Advanced Power Supply Diagnostics
Feedback Circuit Analysis:[6]
- Test U3 optocoupler: Pins 1-2 should show diode characteristics (LED side)
- Measure 6.2V reference voltage at op-amp input
- Scope PWM signal at optocoupler output (should vary with R56 adjustment)
- Check SCR Q10 triggering (30V, 0.8A fast recovery type)
Component Replacement Priorities:
- U3 Optocoupler (4N25/4N26) - Most common failure
- Filter capacitors C24, C29 (2200µF 16V) - Age-related failure
- Rectifier diodes CR20, CR21 - Thermal stress failures
- Horizontal output transistor Q3 - Runs very hot, prone to failure
"Simasimac" Pattern (Horizontal Stripes)
The infamous "Simasimac" pattern displays horizontal black and white stripes with no startup chime, indicating severe logic board failure.[7]
| Stage | Test Procedure | Expected Result | If Failed |
| Power Verification | Measure all voltage rails under load | +5V: 4.85-5.15V, +12V: 11.9-12.75V | Fix power supply first |
| Reset Circuit | Scope reset line (RESET pin on CPU) | Clean reset pulse on power-up | Check reset circuitry, capacitors |
| Clock Signal | Scope 16MHz clock at CPU | Stable 16MHz square wave | Replace crystal oscillator circuit |
| Address/Data Bus | Scope address lines A0-A15 | Activity during boot attempt | Check address buffers, CPU |
| Memory Test | Remove and test RAM chips | Chips test good individually | Replace failed RAM, check sockets |
Root Cause Analysis
Primary causes of Simasimac:[8]
- Capacitor leakage near reset circuit disrupting power-on reset
- RAM socket corrosion preventing proper memory access
- Address line failures due to corroded traces or failed buffers
- CPU failure (rare, but possible with severe voltage excursions)
Systematic repair approach:
- Clean all sockets with DeoxIT contact cleaner
- Replace all electrolytic capacitors on logic board
- Inspect for trace corrosion near PRAM battery area
- Test RAM chips individually in known-good system
- Replace 74F258 and 74F253 multiplexer chips if address lines test bad
Intermittent Failures & Temperature Issues
Intermittent problems are among the most challenging to diagnose, often requiring systematic temperature and environmental testing.
| Behavior Pattern | Likely Cause | Diagnostic Method | Environmental Factor |
| Works when cold, fails when warm | Temperature-sensitive component | Heat gun testing on individual components | Thermal expansion/contraction |
| Fails randomly, no pattern | Borderline component failure | Extended burn-in testing | Power line variations |
| Works for hours, then fails | Thermal buildup | Temperature monitoring during operation | Inadequate heat dissipation |
| Fails only with specific operations | Load-sensitive power supply | Load testing during specific operations | Current draw variations |
| Seasonal failures | Humidity-related corrosion | Climate-controlled environment testing | Moisture absorption |
Temperature Diagnostic Techniques
Heat Testing Procedure:
- Use heat gun or hair dryer on individual components
- Start with 60°C, increase gradually to 80°C maximum
- Monitor for changes in operation during heating
- Focus on semiconductors, electrolytic capacitors, connections
Cold Testing Method:
- Use component freeze spray (tetrafluoroethane)
- Apply to suspected components while system is running
- Look for temporary restoration of function
- Exercise caution - rapid temperature changes can crack components
Thermal Cycling Protocol:
- Operate system in cold environment (10-15°C) for 30 minutes
- Move to warm environment (35-40°C) and run for 30 minutes
- Repeat cycle while monitoring for failures
- Document temperature at which failures occur
Environmental Stress Testing
Humidity Testing:
- Operate in high humidity environment (>70% RH) for extended periods
- Look for corrosion acceleration on exposed metal
- Monitor for increased failure rate of socketed components
- Use desiccant packs to test effect of dry environment
Power Line Sensitivity:
- Test with various input voltages (±10% of nominal)
- Use line isolation transformer to test for ground loop issues
- Monitor with oscilloscope for power line noise effects
- Test with uninterruptible power supply (UPS) for clean power
The "Chimes of Death" indicate early boot failure before the system can display error codes.[9][10]
| Audio Pattern | Meaning | Primary Cause | Diagnostic Focus |
| No chime, no sound | Pre-boot hardware failure | Power, reset, or severe logic failure | Test power rails, reset circuit, basic clocking |
| Single normal chime | Successful POST, other issues | Video, keyboard, or peripheral problems | Focus on display circuits, I/O |
| Continuous chimes | RAM access failure | Memory or address decode problems | Test RAM, address buffers, memory controller |
| Arrhythmic tones | Intermittent hardware failure | Temperature-sensitive components | Heat/cool test components |
Memory Failure Analysis
128K/512K RAM Configuration:[11]
- 128K: 16 × 4164 DRAM chips (64K×1 bit each)
- 512K: 16 × 41256 DRAM chips (256K×1 bit each)
- Access time: 150ns or faster required
- Organization: Two 8-chip banks for 16-bit data bus
RAM Testing Protocol:
- Remove all RAM chips carefully (anti-static precautions essential)
- Test each chip individually in EPROM programmer or RAM tester
- Check socket pins for corrosion or bent contacts
- Verify address/data line continuity with multimeter
- Install known-good RAM in matched sets (same manufacturer/speed)
Video Display Issues
| Symptom | Circuit Area | Test Procedure | Common Causes |
| No video, CRT heater glow present | Video amplifier circuit | Scope video signal at base of video output transistor | Failed video output transistor, coupling capacitors |
| Single horizontal line | Vertical deflection failure | Check vertical yoke continuity, scope vertical drive | Failed vertical output IC, coupling capacitors |
| Single vertical line | Horizontal deflection failure | Test horizontal output transistor Q3, flyback primary | Q3 failure, flyback transformer short |
| Severe geometry distortion | Deflection circuit capacitors | Replace deflection coupling capacitors | Aged electrolytic capacitors in yoke drive |
| Rolling or tearing image | Sync circuit failure | Scope horizontal/vertical sync signals | Failed sync separator, coupling capacitors |
CRT Safety & Testing
⚠️ DANGER: CRT contains lethal voltages up to 16,000V even when unpowered!
Safe discharge procedure:[12]
- Use insulated probe connected to chassis ground
- Touch probe to anode cap under rubber cover
- Keep probe grounded while working
- Never work alone on CRT repairs
Flyback transformer testing:
- Visual inspection for cracks, carbonization, or ozone smell
- Continuity test of primary winding (should be ~3-5 ohms)
- Insulation test between primary and high-voltage secondary
- Check for internal arcing (high-pitched whine during operation)
Floppy Drive Diagnostics (400K Sony)
The 400K Sony floppy drives are prone to lubrication failure and mechanical wear.[13]
| Symptom | Mechanical Check | Electrical Check | Solution |
| "?" disk icon, no disk acceptance | Head positioning, rail lubrication | ±12V at drive connector | Re-lubricate mechanism, clean heads |
| Immediate ejection | Eject mechanism binding | Eject motor drive signal | Replace broken eject gear, adjust mechanism |
| Read errors, data corruption | Head alignment, dirty heads | Drive select, enable signals | Clean heads with IPA, realign if necessary |
| Drive not spinning | Spindle motor, belt tension | Motor drive voltage | Replace drive belt, lubricate spindle bearing |
| Grinding/clicking noises | Stepper motor, head positioner | Stepper drive signals | Clean and lubricate stepper mechanism |
Drive Lubrication Procedure
Required materials:
- White lithium grease (small amount)
- Isopropyl alcohol (>90%)
- Cotton swabs
- Precision screwdrivers
Critical lubrication points:
- Head positioning rails (wipe old grease, apply thin layer)
- Eject mechanism pivots and gears
- Spindle motor bearing (very light application)
- Stepper motor gear train
Head cleaning procedure:
- Remove drive from Mac chassis
- Access head through front slot
- Gently clean with IPA-soaked swab
- Allow to dry completely before reassembly
Advanced Diagnostic Equipment
| Equipment | Primary Use | Key Measurements | Recommended Models |
| Digital Multimeter | Voltage, continuity, component testing | DC voltages, resistance, diode testing | Fluke 87V, Keysight U1252B |
| Oscilloscope | Signal analysis, timing verification | Clock signals, data/address bus activity | Rigol DS1054Z, Siglent SDS1104X-E |
| Logic Analyzer | Bus analysis, protocol decode | Address/data bus timing | Saleae Logic 8, DSLogic Plus |
| ESR Meter | Capacitor condition testing | In-circuit ESR measurement | DE-5000, Peak ESR70 |
| EPROM Programmer | ROM/RAM chip testing | Chip verification, programming | TL866II Plus, Xeltec SuperPro |
Test Point Identification
Logic Board Critical Test Points:[14]
- CPU Reset: Pin 17 of 68000 (should pulse low on power-up)
- Clock: Pin 15 of 68000 (16MHz square wave)
- Address Bus: Pins 6-20 of 68000 (activity during boot)
- Data Bus: Pins 5,7,12,14,16,18,19,21,23 of 68000
Analog Board Test Points:
- R56 voltage adjust: Trimmer potentiometer
- Flyback primary: Transformer T1 pins 1-4
- High voltage: Anode cap (⚠️ LETHAL - discharge first!)
- Deflection circuits: Yoke connector pins
Capacitor Failure Diagnosis
Electrolytic capacitor failure is the most common cause of analog board problems in vintage Macs.[15][16]
| Location | Function | Failure Symptom | Diagnostic Method |
| C1 (3.9µF non-polar) | Horizontal deflection coupling | Narrow screen, H-sync loss | Scope horizontal drive signal |
| C24, C29 (2200µF) | Main filter capacitors | Low voltage, excessive ripple | ESR meter, ripple measurement |
| C25, C26, C31 (1000µF) | Secondary filtering | Voltage instability, regulation issues | Load testing, ESR measurement |
| C35, C36 (220µF) | Regulation filtering | Poor voltage regulation | Scope feedback loop signals |
| RIFA X2 capacitor | AC line filtering | Smoke, burning smell, immediate failure | Visual inspection, continuity test |
Capacitor Testing Methods:
- ESR (Equivalent Series Resistance) testing - Most reliable in-circuit method
- Visual inspection - Look for bulging tops, leakage, or corrosion
- Voltage ripple measurement - Excessive AC component indicates filter failure
- Load testing - Voltage sag under load suggests weak filtering
For complete capacitor replacement procedures, part numbers, and installation guides, see the dedicated Macintosh 128K/512K Capacitor Replacement Guide page.
Specialized Repair Techniques
Trace Repair Methods
PRAM battery corrosion damage:[17]
- Assess trace damage with continuity testing
- Repair broken traces with 30AWG wire jumpers
- Apply conformal coating to prevent future corrosion
Socket Restoration
RAM/ROM socket maintenance:
- Remove all socketed chips
- Clean socket contacts with DeoxIT and brush
- Test socket pin tension (should grip firmly)
- Replace sockets if pins are loose or corroded
Temperature Troubleshooting
Heat-sensitive failure diagnosis:
- Use heat gun or hair dryer to selectively warm components
- Use freeze spray to cool suspected components
- Monitor for changes in operation during temperature cycling
- Focus on semiconductors, electrolytic capacitors, and connections
Error Code Reference
| Error Code | Component | Specific Failure | Repair Action |
| 01xxxx | ROM | Checksum failure, bad ROM chip | Replace or reseat ROM chips |
| 02xxxx | RAM | Memory test failure in lower bank | Test/replace RAM chips 1-8 |
| 03xxxx | RAM | Memory test failure in upper bank | Test/replace RAM chips 9-16 |
| 04xxxx | RAM | Address line failure | Check address buffers, trace continuity |
| 05xxxx | RAM | Data line failure | Check data buffers, RAM socket pins |
| 0Fxxxx | Logic | Severe hardware failure | Check CPU, address decode logic |
See Sad Mac Error Codes for complete diagnostic procedures.
Component-Level Troubleshooting
| IC Function | Part Number | Common Failures | Test Method | Modern Replacement |
| Address Buffers | 74F244 | Stuck address lines | Logic analyzer | 74ACT244 |
| Data Buffers | 74F245 | Data corruption | Loop-back test | 74ACT245 |
| Memory Multiplexers | 74F258 | Memory access failure | Scope select lines | 74ACT258 |
| Clock Generator | MC68901 (MFP) | No system clock | Frequency counter | Direct replacement |
| Video RAM | 4164 DRAM | Video corruption | RAM tester | Compatible 4164 |
IC Testing Procedures:
- Test in dedicated IC tester or EPROM programmer
- Check for proper logic levels and timing
- Verify pin-to-pin continuity and isolation
- Replace with exact equivalent or improved specification
Professional Repair Resources
Recommended Reference Materials:
- Official Apple Service Source documentation
- "Dead Mac Scrolls" comprehensive repair database
- 68kMLA community forums for expert advice
- Classic Mac repair video series by tech specialists
Component Suppliers:
- Console5.com - Capacitor kits and replacement parts
- Mouser/Digikey - Electronic components
- Vintage computer specialty retailers
- Classic Mac enthusiast communities
Safety Reminders
⚠️ Critical Safety Requirements:
- Always discharge CRT before internal work
- Use proper ESD protection when handling logic boards
- Never work on powered analog boards
- Ensure adequate ventilation when soldering
- Keep fire extinguisher accessible when working with vintage electronics
First Aid for Component Failures:
- Capacitor explosion: Ventilate area, clean with IPA
- Flyback failure: Power off immediately, check for HV arcing
- Component overheating: Remove power, allow cooling before diagnosis
- ↑ Help needed with dead Mac 512K board, TinkerDifferent, 2022-05-10—link(accessed 2025-01-25)
- ↑ There and back again: a Macintosh 512K saga– Vlado Vince, 2024-10-06—link(accessed 2025-01-25)
- ↑ Mac Plus, analog board schematic and Tech Notes—link(accessed 2025-01-25)
- ↑ Macintosh Plus, Caps Wiki—link(accessed 2025-01-25)
- ↑ Mac Classic Analog Board - Low Voltage Problems, Vintage Computer Federation Forums—link(accessed 2025-01-25)
- ↑ Macintosh Plus analog board not regulating voltage, VOGONS—link(accessed 2025-01-25)
- ↑ SE/30 Very Unusual Screen Artifacts, Applefritter—link(accessed 2025-01-25)
- ↑ IIcx Chimes of Death, 68kMLA Forums—link(accessed 2025-01-25)
- ↑ Chimes of Death, Apple Wiki—link(accessed 2025-01-25)
- ↑ Mac Chimes of Death, 512 Pixels—link(accessed 2025-01-25)
- ↑ Help with Macintosh Classic II. Memory problems., Applefritter—link(accessed 2025-01-25)
- ↑ Apple 400k Floppy Drive Lubrication Repair, iFixit—link(accessed 2025-01-25)
- ↑ Macintosh 128K Analog Board & Logic Board Capacitor List, TinkerDifferent, 2022-02-10—link(accessed 2025-01-25)
- ↑ Vintage Computer Up In Smoke? Here's How to Fix It, 2021-11-23—link(accessed 2025-01-25)
Apple's own manuals for this machine on this wiki
- Macintosh 128K/512K Service Source - Apple's symptom charts for video, drives, peripherals and miscellaneous faults, and the Voltage adjustment measured at the external drive port with test cable 077-0135 (orange lead 11.90-12.75 V, red lead 4.85-5.15 V, both set on the power/sweep board regulator).
- Apple Macintosh Service Guide Volume 1 1990 - the condensed symptom/cure chart and parts list for the same machines.
