Macintosh Floppy Drive Maintenance
The internal floppy disk drives fitted to vintage Macintosh computers are 3.5-inch mechanisms made by Sony and Mitsubishi, used from 1984 into the late 1990s. Three generations matter:
- 400 KB โ single-sided, Sony 3.5-inch (128K and 512K)
- 800 KB โ double-sided, Sony 3.5-inch (Plus, SE and others)
- 1.4 MB โ high-density Apple SuperDrive, Sony and Mitsubishi mechanisms (later models)
They fail with age from dust, hardened grease in the eject mechanism, dried lubricant on the carriage rails, worn or dirty heads and cracked plastic gears. Cleaning and re-greasing recover most drives. Alignment does not โ see What cannot be adjusted below.
These drives have no belt
The Apple SuperDrive and its 400 KB and 800 KB predecessors are direct drive. The spindle is coupled straight to a DC brushless motor; there is no belt, no pulley and no belt part number.[1]
The word "belt" does not appear anywhere in Apple's service documentation for these drives โ not in the Apple 3.5 Drive, Apple 400K Drive, Apple 800K Drive, Apple SuperDrive or Macintosh HDI-20 1.4 MB Drive Service Source volumes.[2][3]
Advice to "check the drive belt" on a Macintosh floppy drive is wrong and has propagated from this page to several machine pages. Belt-driven floppy mechanisms are a 5.25-inch full-height phenomenon (Tandon TM100, CDC/MPI and similar) โ see Floppy Drive Repair.
Specifications you can measure against
Apple publishes a real specification for the 800 KB Apple 3.5 Drive, and it converts directly into bench checks.[2]
| Parameter | Apple's figure |
| Tracks per inch | 80 |
| Recording surfaces | 2 |
| Seek time, track to track | 6 ms maximum |
| Settle time | 30 ms maximum |
| Drive start-up time | 600 ms maximum |
| Head position accuracy | ยฑ0.035 mm |
| Formatted capacity | 800 K (certified double-sided media) |
| Unformatted capacity | 1,246 K |
| Operating temperature | 5โ50 ยฐC (40โ122 ยฐF) |
| Relative humidity | 5โ90%, no condensation |
| Rail | Standby | Typical | Peak |
| +12 V | 10 ยตA | 120 mA | 600 mA, during eject only, 2 seconds maximum |
| +5 V | 10 mA | 360 mA | โ |
A drive that pulls far more than this, or that drags a rail down when it spins up, has a shorted motor driver or a seized mechanism. A drive that pulls nothing at all is not being powered โ check the cable before opening the drive.
Disassembly and cleaning
Before you start
- Power off and unplug the Macintosh.
- Work on a static-free surface with an anti-static wrist strap.
- Most compact Macintosh cases need a Torx T15 driver (a long-shaft one for the case screws inside the handle well).
To remove the drive:
- Open the case.
- Disconnect the ribbon cable and, on drives that have one, the power connector.
- Remove the mounting screws and slide the drive out.
Cleaning the mechanism
- Blow the dust out with compressed air, or lift it with a soft anti-static brush.
- Clean the carriage rails and gears with isopropyl alcohol (>90%) and a lint-free cloth.
- Clean the read/write heads with a cotton bud dipped in isopropyl alcohol, moving along the head rather than across it. Support the upper head arm โ do not let it snap down onto the lower head.
- Apple's own first remedy for "drive is unable to read; many file transfer errors occur" and for "drive fails to format" is, in both cases, clean drive.[3]
Re-greasing
- Re-grease the carriage rails, the eject gears and the worm drive with a plastic-safe synthetic grease. Hardened forty-year-old grease is the single most common cause of a drive that will not eject or that grinds.
- Do not use WD-40 or any other penetrating oil: it creeps, attracts dust and degrades the plastics.
- Do not over-apply. Grease on the head or on the media path will ruin disks.
Common failures and repairs
Eject mechanism
Mechanical eject systems fail through:
- Eject motor failure
- Hardened grease on the gears
- Cracked or broken plastic gears โ the eject worm gear is a known casualty, and 3D-printed replacements are widely available
- Dirty eject switches
Fixes: clean and re-grease with a plastic-safe grease, replace broken gears, clean the switches.
Drive will not read
- Clean the heads thoroughly and inspect them under magnification for wear or a scored surface.
- Check that the spindle turns freely by hand and that the stepper moves the carriage the whole way.
- Verify the disk-insertion and write-protect sensors โ a blocked write-protect sensor makes every disk read-only, and a blocked insertion sensor makes the drive ignore disks entirely.
- Try known-good media. Forty-year-old disks shed oxide, and a shedding disk will contaminate a freshly cleaned head in one pass.
Drive reads but will not write
Apple's chart sends this straight to "verify that drive is 1.4 MB SuperDrive", then to replacing the mechanism.[3] In practice, check the write-protect shutter and sensor first โ that accounts for most of them.
Stepper and carriage
- Symptoms: no movement, failure to seek, tracking that drifts.
- Clean and lightly lubricate the guide rails; check the stepper coil continuity with a multimeter.
- A stepper that buzzes without moving is usually mechanically jammed rather than electrically dead.
Three procedures circulate for these drives: re-tensioning the head spring, aligning the track-zero sensor by loosening its screws, and aligning the heads by loosening the stepper motor and rotating it. None of them is in Apple's documentation, and all three are wrong for these mechanisms:
- There is no felt pressure pad in a double-sided 3.5-inch drive. The felt pad belongs to single-sided 5.25-inch drives. A Sony or Mitsubishi 3.5-inch mechanism has an upper head on a sprung gimbal that loads against the lower head, and bending that spring changes the head load force away from the manufacturer's figure โ which is not recoverable without the manufacturer's jig.
- Head alignment on these drives needs an alignment disk and an oscilloscope, not trial and error against known-good disks. Moving the stepper by hand destroys the drive's compatibility with every disk written elsewhere, including the ones that used to work.
- Apple's own service documentation contains no adjustment procedure of any kind for these drives. Every symptom in the Apple SuperDrive and Apple 3.5 Drive charts ends in "clean drive" or "replace drive mechanism".[3][2]
If a cleaned, re-greased drive still misreads disks from other machines, the realistic options are a known-good donor mechanism or a modern replacement, not an alignment attempt.
Things that are not faults
- A disk formatted on a 1.4 MB SuperDrive that a PC will not read. Apple's answer is to format all disks on the MS-DOS drive first, and then both drives can read and write them.[3]
- A SuperDrive that reads 800 K disks but not high-density ones. Check it really is a 1.4 MB SuperDrive and not an 800 K mechanism in a later machine; Apple's chart asks this first.[3]
- A single click on insertion. That is the mechanism clamping the hub, and it is normal.
Testing
- Disk Copy verifies that a disk reads end to end and is the quickest way to prove a repair.
- A known-good disk written on a different machine is the only test that distinguishes a dirty head from an alignment problem.
- Apple HD SC Setup is a hard disk utility and has no role in floppy testing, despite being listed as one in several places.
Apple's own drive manuals on this wiki
- Macintosh HDI-20 1.4 MB Drive Service Source โ the HDI-20 external drive, 18 pages,
Troubleshooting and Take Apart only. Apple printed no specifications chapter for it at all, so there is no capacity, data rate or current figure in it; what it does carry is the removal of the cable interface board and the HDI-20 external cable.
Apple's DuoDisk and UniDisk technical procedures, with the DuoDisk chip-swapping chart and both illustrated parts lists.[4]
- Macintosh II Repair and Upgrade Secrets โ Larry Pina's chapter 8 covers 400K, 800K and
1.4 MB drives, formatting rules, building an external drive adapter, fitting a second internal drive, the FDHD/ROM upgrade and 800K drive troubleshooting. Secondary source.
- Apple 3.5 Drive Service Source - the only Apple external floppy volume with a full Specifications chapter, and therefore the source for the 800K mechanism's seek, settle, startup and current figures.
- Apple SuperDrive/HDI-20 Service Source - the symptom chart for the external 1.4 MB drive.[5]
- Apple 400K Drive Service Source and Apple 800K Drive Service Source - Take Apart procedures only; the 800K volume also carries Apple's Restoring Mouse Eject procedure.
- Apple PC 5.25 Drive Service Source - the 360K 5.25-inch drive, with its 300 rpm and current figures.
Additional Resources
- Macintosh HDD Maintenance
- Macintosh SE General Maintenance
- Apple Service Source
- Macintosh SE/30 Troubleshooting Guide
- Floppy Drive Repair (general)
- โ Mitsubishi Electric, MF355C 3.5-inch Diskette Drive Specifications, UGD-0527A, February 1987: "The drive uses a DC brushless, direct-drive motor"; the disk rotation mechanism "uses a DC brushless direct-drive motor to directly rotate the spindle". Hosted on this wiki as File:Mitsubishi MF355C 3.5 inch Diskette Drive Specifications (UGD-0527A, Feb 1987).pdf.
- โ 2.0 2.1 2.2 Apple Computer, Inc., Apple 3.5 Drive Service Source (Specifications, Troubleshooting, Take Apart). Hosted on this wiki as File:Apple 3.5 drive.pdf.
- โ 3.0 3.1 3.2 3.3 3.4 3.5 Apple Computer, Inc., Apple SuperDrive Service Source (Troubleshooting → Symptom Charts; Take Apart). Hosted on this wiki as File:Apple superdrive.hdi 20.pdf.
- โ Apple Computer, Apple LaserWriter Printer Technical Procedures, preliminary version for internal use only, sections stamped rev. Jan 85 and rev. Feb 85. Held on this wiki inside the Service Support Training Programs binder scan, described at Service Support Tranning Programs Laserwriter Technical Procedures Jan 1985 (File:Service_Support_Tranning_Programs_Laserwriter_Technical_Procedures_Jan_1985.pdf).
- โ Apple SuperDrive, Apple Service Source, 21 pages - hosted on this wiki as Apple SuperDrive/HDI-20 Service Source. Its symptom chart is the only one Apple published for an external Apple floppy drive, and it records two normal behaviours that get misdiagnosed: an MS-DOS machine will not read a disk formatted on a 1.4 MB SuperDrive unless the disk was formatted on the MS-DOS drive first, and a drive that handles 800K media but refuses high-density disks is usually an 800K drive rather than a faulty SuperDrive.
