Apple LaserWriter
Revision as of 19:27, 1 October 2026 by Josh (talk | contribs) (Update links to Service Support Training Programs LaserWriter Technical Procedures Jan 1985 after page move)
The Apple LaserWriter is Apple's first laser printer. It uses a Canon LBP-CX print engine at 300 dpi and 8 pages per minute, driven by an I/O board with a 68000 processor and Adobe PostScript.[1] Read the Safety section before working on one: the printer contains an invisible laser, a hot fuser and a high-voltage supply.
Apple LaserWriter
Apple LaserWriter
Type Laser printer
Interface AppleTalk (DB-9), RS-232-C (DB-25)
Compatible Macintosh over AppleTalk; other computers over RS-232-C
Dimensions 11.5 in high × 18.5 in wide × 16.2 in deep (28.2 in with trays)
Weight 77 lb
Power 100-115 V AC 60 Hz (domestic); 220-240 V AC 50 Hz (international)
Print engine specifications (Apple Service Guide, Tab 2, p. 7)
Marking engine Canon LBP-CX laser xerographic
LaserWriter I/O board 12 MHz 68000 microprocessor; 1.5 MB RAM; 512K ROM (LaserWriter) and 1 MB ROM (LaserWriter Plus); AppleTalk and RS-232-C interfaces
Print resolution 300 dots per inch
Speed 8 pages per minute
Paper feed Automatic from the paper input cassette; manual single-sheet feed
Print materials Best results with 16-20 lb single-sheet photocopy bond; most letterhead and coloured stock from 8 to 34 lb; standard medium-weight overhead transparency material; envelopes and labels by manual feed
Paper capacities Letter, Legal, A4 and B5. Input cassette 100 sheets; output tray 20 sheets
Printable surface Letter 8.0 × 10.92 in; Legal 6.75 × 13.0 in; A4 7.41 × 10.86 in; B5 7.69 × 10.16 in
Physical dimensions Height 11.5 in; width 18.5 in; depth 16.2 in (body only), 28.2 in with trays; weight 77 lb
Operating environment 50 to 90.5 °F (printed as 10 to 34 °C); humidity 20 to 80 per cent
Power requirements 100 to 115 V AC, 60 Hz (domestic); 220 to 240 V AC, 50 Hz (international)
[1]
The Celsius figure in Apple's table does not match the Fahrenheit one: 90.5 °F is 32.5 °C, the figure Apple's pre-power-on checklist uses.[1]
Safety
Apple's warnings for the LaserWriter family:[1]
  • The printers operate at high voltages. Switch off and unplug the power cord before servicing, and never work on a LaserWriter under power except when making live adjustments. With the covers off and the power on, do not touch the high-voltage power supply or the DC power supply.
  • Never disconnect the optical fibre cable or open the laser access hatch with the printer switched on. The beam is infrared: it cannot be seen and can permanently damage the eyes. When servicing or adjusting the optical system, keep screwdrivers and other shiny objects out of the beam, whose reflection is just as dangerous. Warning labels are fitted inside the covers where exposure is possible.
  • The fuser rollers become very hot. Switch the printer off for at least five minutes before servicing the fuser assembly.
  • Do not be grounded when working on plugged-in equipment or making live adjustments, and remove all jewellery before starting.
  • The I/O boards contain CMOS parts that are very sensitive to static and skin acid. Handle chips, ROMs and SIMMs by their edges, do not touch anyone working on integrated circuits, and keep polyester clothing, plastic, vinyl and polystyrene out of the work area.
  • Apple's safety section gives LaserWriter printers as weighing from 32 to 60 pounds; its specification table gives this model as 77 lb. Take care when lifting.
  • Toner is a non-toxic mixture of plastic, iron and a little pigment. Remove it from skin and clothing with a dry tissue and wash with cold water; hot water makes it gel and fuse into fabric. Toner attacks vinyl.
Apple's guide also cautions against ammonia-based cleaners on the LaserWriter II and Personal LaserWriter, because they discolour the plastic, and its LaserWriter checklist asks whether the printer is exposed to ammonia gas.[1]
Status lights
The LaserWriter has three status lights on the front display panel and a Test light on the rear I/O connector plate.[1]
LaserWriter status lights
Light Position Behaviour
Ready/Wait (green) Front panel Flashes during warm-up; on continuously when ready to print
Paper-Out (yellow) Front panel On and steady when out of paper or when the cassette is not installed; flashes while the printer prepares to print a page. In manual feed mode, on steadily if there is no paper on the manual feed tray
Paper Jam (red) Front panel On when paper jams inside the printer, until the jam is cleared
Test Rear I/O connector plate On, steady or flashing, if there is an error condition on the I/O board. With a working I/O board it flashes once at switch-on and then goes out
[1]
Test prints
The two test prints check different halves of the printer.[1]
The service test print checks the print engine alone. Produce it by jumpering pins J205-1 and J205-2 on the DC controller PCB; it separates print-engine faults from I/O board faults.[1]
The user test print is produced each time the printer is switched on, unless the protocol switch is set to "Special" or the print has been turned off with PostScript software. It confirms that the I/O board works and shows the revision of the PostScript ROMs, the selected mode (PostScript or Diablo 630 emulation) and the number of pages the I/O board has produced.[1]
A fault that appears on the service test print is in the engine. A fault that appears only on the user test print, or only when printing from a computer, is in the I/O board or beyond it.[1]
Ports and switches
The rear panel has a 9-pin connector, a 25-pin connector and a four-position mode switch marked AppleTalk, Special, 9600 and 1200.[1]
AppleTalk connector, DB-9
Pin Signal Description
3 SG Signal ground
4 TXD+ Transmit data +
5 TXD− Transmit data −
8 RXD+ Receive data +
9 RXD− Receive data −
[1]
Setting the mode switch to AppleTalk selects this port.[1]
RS-232 connector, DB-25
2 TD Transmit data
3 RD Receive data
4 RTS Request to send
7 SG Signal ground
20 DTR Data terminal ready
[1]
Setting the switch to 1200 or 9600 selects the RS-232 port at that rate. The AppleTalk cable is Apple's LocalTalk Connector Kit, DB-9, part number 590-0254 or 630-8272, model M2065.[1]
Pre-power-on checklist
Apple's checklist before chasing a fault:[1]
  • Line voltage 115 V AC ±10%
  • Printer on a solid, level surface
  • Room temperature 50-90 °F (10-32.5 °C) and humidity 20% to 80%
  • Printer not in an excessively hot, humid or dusty place or near open flames
  • Printer not exposed to ammonia gas (produced by diazo copiers or cleaning solutions)
  • Printer out of direct sunlight and in a well-ventilated area
  • Cables and connectors OK
  • Toner cartridge installed and OK; replace it if the indicator is red
  • Fuser roller cleaner felt in place and not dirty
  • Print density dial set correctly
  • Protocol selector switch on the back set to AppleTalk
  • Paper cassette loaded to no more than 10 mm high
  • Paper 16-21 lb standard photocopier paper
  • Transfer corona wire clean and unbroken
  • Separation belt free of nicks and not broken
Diagnostic sequence
Apple's order is the pre-power-on checklist, then the LaserWriter Functional Check, then the LaserWriter Print Engine Check, then the lettered troubleshooting tables.[1] The functional check starts by switching the printer off, waiting one minute, switching it on and waiting three minutes for a user test print; if that is good, it sends a file from a Macintosh over AppleTalk.[1]
The tables cover: A, no power; B, delivery rollers do not rotate; D, heater bulb does not operate; E, cannot feed paper manually; F, jams detected when there are none; G, paper jams not detected; H, Paper-Out light on when there is paper; J, preconditioning lamps do not light; K, laser/scanner malfunction; L, erroneous low-toner indication; M, print quality problems; N, paper transport problems.[1]
Adjustments
Laser power adjustment
This needs a laser power checker and a digital multimeter.[1]
  1. Remove the top cover, the I/O board and the card cage.
  2. With the power off, open the laser access hatch and insert the laser power checker with the detector facing the laser diode. Insert it fully so that no laser light can escape from the hatch.
  3. Connect the checker's black lead to the meter's common socket and the red lead to volts, and set the meter to the 200 mV range.
  4. Disconnect J209 from the DC controller board and jumper J209-5 to J209-6.
  5. Turn VR202 on the DC controller board fully anticlockwise.
  6. Switch on and wait until the green Ready/Wait light stops flashing.
  7. Briefly jumper J209-6 to J209-7, remove the jumper and record the reading. Repeat twice more.
  8. Average the three readings and compare the result with the voltage printed next to "300" on the laser label; it should be within ±1 mV.
If the output is low, remove the J209-6/J209-7 jumper, turn VR202 slightly clockwise and repeat; if it is high, turn VR202 slightly anticlockwise and repeat.[1]
Image skew adjustment
To check the skew, produce a user test print and measure from the top left and right corners of the test pattern to the top edge of the paper. The two measurements should differ by no more than 1 mm.[1]
To adjust it:[1]
  1. Remove the top cover and the I/O board. Switch on and wait for the green Ready/Wait light to stop flashing.
  2. Produce a service test print by briefly jumpering J205-1 to J205-2.
  3. Loosen the four large mounting screws on the scanner unit and the two sealed screws closest to the laser unit.
  4. Rotate the scanner unit around screw A. Clockwise inclines the horizontal line anticlockwise; anticlockwise inclines it clockwise.
  5. Reprint and remeasure until the difference is 1 mm or less.
  6. If you run out of travel, tighten the two sealed screws nearest the laser unit, loosen the two on the other side and rotate around screw B.
Preventive maintenance
Reading the page count
The user test print gives the number of pages printed since the I/O board was installed, which is the machine's page count only if that board has never been replaced or upgraded.[1] Otherwise, remove the top cover, the I/O board and the DC controller board, and find the page counter in the middle of the preconditioning exposure assembly, just below the DC controller board. It looks like a small thermometer, and each mark represents about 10,000 pages.[1]
Apple's schedule
Preventive maintenance schedule
Pages Procedure
0 to 50,000 Standard Maintenance
50,000 to 100,000 Standard Maintenance, and replace the ozone filter
100,000 to 150,000 100,000-Page Service, and replace the separation belt
[1]
Standard Maintenance: open and close the toner cartridge's light-blocking shutters to check they are not jammed or broken; clean the cartridge's primary corona wire with the wire brush supplied with the printer; clean the protective shield with a damp cloth; clean the photosensitive drum only if absolutely necessary, with a soft cloth saturated with toner powder; replace the fuser roller cleaner felt if it is dirty; clean the separation claws, delivery guide, separation guide and paper guide with isopropyl alcohol; clean the transfer corona assembly and separation belt with a cotton swab; clean the feeder rollers, separation rollers, transfer guides and feeder guide with isopropyl alcohol; and replace the ozone filter every 50,000 pages.[1]
The 100,000-Page Service adds cleaning the fan with a small brush and the registration shutter rollers with isopropyl alcohol, and replacing the preconditioning exposure assembly, the grounding spring, the paper pickup rollers, the paper feed rollers and lower paper feed guide, the fuser assembly, the ozone filter and the separation belt.[1]
Before starting, switch off and unplug the printer, let the fuser rollers cool, take ESD precautions and lay a drop cloth to protect the floor from grease and toner.[1]
Parts
Selected entries from Apple's parts list:[1]
Part Number
DC controller PCB 661-0267
DC power supply/motor drive PCB, 110 V 661-0273
DC power supply/motor drive PCB, 220 V 661-0274
High-voltage power supply 661-0266
Laser unit 661-0277
Scanner unit, 300 dpi 661-0278
LaserWriter I/O PCB 661-0436
Fuser assembly, 115 V 661-0450
Fuser assembly, 220 V 699-0318
Power interlock assembly, 110 V 699-0324
Power interlock assembly, 220 V 699-0325
AC driver PCB, 110 V 661-0268
AC driver PCB, 220 V 661-0269
Paper separator belt 970-1005
Ozone filter 970-1001
Transfer corona assembly 970-1021
Fan, 110 V 60 Hz 720-0502
Fan, 220 V 50 Hz 970-1074
Main drive motor 970-1009
Preconditioner exposure PCB 970-1020
Registration shutter assembly 699-0323
Separation/feed roller assembly 970-1019
Display panel assembly 970-1109
LaserWriter configuration block 750-0102
The DC power supply, AC driver PCB, power interlock, fuser assembly and fan all have different part numbers for 110 V and 220 V machines.[1]
Service manual
Other documentation on this wiki
  • Service Support Training Programs LaserWriter Technical Procedures Jan 1985: Apple's LaserWriter Printer Technical Procedures, the earliest service document for this printer held here, marked on its contents page as "a preliminary version ... for internal use only", with sections stamped rev. Jan 85 and rev. Feb 85. It gives the two adjustments above under their Apple procedure numbers (Laser Power Adjustment, P/N 011-7052; Image Skew Adjustment, P/N 011-7051), a theory of operation (300 dpi, 6.8 million dots per page; the I/O board is a 68000 with 1.5 MB of RAM and 500 KB of ROM), a full take-apart including the fuser assembly, part 699-0306, image-defect and electromechanical troubleshooting tables, and an appendix of DC controller board signals and connectors.[2] The same binder also contains Apple's Macintosh Office (AppleTalk), DuoDisk and UniDisk technical procedures, ImageWriter and Scribe parts lists, and extracts from the Lisa troubleshooting guide.[2]
  • Envelope Feeder Service Source: Apple's service manual for the LaserWriter envelope feeder. The Pro 600/630 feeder fits only that printer; the 16/600 PS feeder fits both. The manual gives three ways to tell them apart (two-piece or one-piece roller shafts, controller board RG5-0576 or RG1-3437, serial prefix JXC or LBK) and the 1.5 mm separation-guide gap to reset after a strip-down.
  • Service Training Introduction To Laser Printer Service Version 1.0.1 1996: Apple's technician course on the diagnostic method for laser printers. The 1992 edition includes the final test.
  • The Laser Writer Family 1992: Michael Fraase's Rapid Reference Guide to The LaserWriter Family (Business One Irwin, 1992), a third-party user guide to the Personal LaserWriter LS and NT and the LaserWriter IIf and IIg, with no schematics, parts list or FRU numbers.
  • Inside The Apple Laserwriter 1989: Roger Hart, Scott, Foresman and Company, 1989, 313 pages. A third-party book on using and programming the LaserWriter (PostScript, fonts, page description), with no service procedures, parts or schematics.
  • Apple Laserwriter Reference 0-201-19258-6 1988: Apple's reference for the LaserWriter, LaserWriter Plus, II NT and II NTX, including the printer switch settings and font behaviour.
  1. ↑ 1.00 1.01 1.02 1.03 1.04 1.05 1.06 1.07 1.08 1.09 1.10 1.11 1.12 1.13 1.14 1.15 1.16 1.17 1.18 1.19 1.20 1.21 1.22 1.23 1.24 1.25 1.26 1.27 1.28 1.29 1.30 1.31 Apple Service Guide for LaserWriter Printers, Volume I, Apple Computer, Inc., January 1992 (072-0631-B), hosted on this wiki as Apple LaserWriter Printers Volume I (PDF). Covers the LaserWriter, LaserWriter Plus, LaserWriter II SC/NT/NTX/IIf/IIg and Personal LaserWriter SC/NT/LS. Introductory safety section: the high-voltage, optical-fibre, fuser-cooling, ESD, not-being-grounded and lifting warnings; the LaserWriter Safety Rules; the toner-safety paragraph; the laser-safety paragraph and the three laser warning labels. Tab 2, LaserWriter/LaserWriter Plus: parts list with part numbers (pages 3-4); print engine specifications (page 7); status lights (page 8); service test print and user test print (page 9); the pre-power-on checklist and troubleshooting flowcharts and tables (pages 10-51); the LaserWriter Plus ROM upgrade (pages 52-53); the laser power adjustment (page 54); the image skew adjustment (pages 55-56); and preventive maintenance including the page counter, the maintenance schedule and the Standard Maintenance and 100,000-Page Service checkpoint tables (pages 57-60). Tab 3, LaserWriter II: parts list (pages 4-5); controller-I/O board specifications (page 10); print engine specifications (page 11); status LEDs (page 12); test pages (page 13); the pre-power-on checklist, the IIf/IIg status-LED diagnostic chart and the troubleshooting tables (pages 14-54); the laser power output check (page 55); the NTX memory and ROM upgrades (pages 56-57); the IIf/IIg memory upgrade (page 58); and preventive maintenance (pages 59-60). Tab 6, Ports and Cables: the peripheral cable table, external connector diagrams, connector pin-outs and switch configurations.
  2. ↑ 2.0 2.1 Apple Computer, Apple LaserWriter Printer Technical Procedures, preliminary version for internal use only, sections stamped rev. Jan 85 and rev. Feb 85. Held on this wiki inside the Service Support Training Programs binder scan, described at Service Support Training Programs LaserWriter Technical Procedures Jan 1985 (File:Service_Support_Tranning_Programs_Laserwriter_Technical_Procedures_Jan_1985.pdf).
