Power Macintosh 5260
The Power Macintosh 5260 is an all-in-one Macintosh with a PowerPC 603e processor and a built-in 14-inch monitor. Apple introduced the 100 MHz Power Macintosh 5260/100 on April 15, 1996 and the 120 MHz 5260/120 on October 1, 1996.[1][2] EveryMac gives March 10, 1996 and September 19, 1996 as the introduction dates, and says the Power Macintosh 5260 was sold only to education buyers in North America, while the same machine was sold to consumers as the Macintosh Performa 5260CD and Performa 5260/120.[3][4] Apple's service manual says the Power Macintosh 5260/120 was sold in the United States and Canada, the Performa 5260/120 in Canada and Australia, and the otherwise similar Performa 5280 in Japan.[5]
| Macintosh Performa 5260/120, the consumer version, in the same case. Photo: Stephen Edmonds, Wikimedia Commons, CC BY-SA 2.5 | |
| Type | All-in-one desktop personal computer |
| Released | April 15, 1996 (5260/100); October 1, 1996 (5260/120) |
| Discontinued | March 1, 1997 (EveryMac) |
| CPU | PowerPC 603e at 100 or 120 MHz; 40 MHz bus |
| Memory | 16 MB, expandable to 64 MB (two 72-pin SIMMs) |
| Storage | 800 MB, 1.2 GB or 1.6 GB IDE hard drive; 4× or 8× CD-ROM; 1.4 MB floppy (manual insert) |
| Display | Built-in 14-inch shadow-mask CRT; 640 × 480 at 16-bit |
| Sound | 16-bit stereo output, 16-bit mono input |
| ROM | 4 MB |
| Dimensions | 445 × 406 × 383 mm (17.5 × 16 × 15.1 in) |
| Weight | 45 lb (20.4 kg) |
| OS / Firmware | System 7.5.3; supported to Mac OS 9 |
| Predecessor | Power Macintosh 5200 LC |
| Successor | Power Macintosh 5400 |
| Model no. | M3457 |
The 5260 replaced the Power Macintosh 5200 LC and looks the same from outside, but it has its own logic board, power supply, analogue board and a 14-inch tube in place of the 5200's 15-inch one. Apple wrote a separate service manual for it, and the 5200/5300 manual is titled "(not 5260, 5280)" on its cover.[5][6]
Models
| Model | Introduced (Apple) | Introduced / discontinued (EveryMac) | Order number (EveryMac) | Processor | RAM | Hard drive | CD-ROM |
| 5260/100 | April 15, 1996[1] | March 10, 1996 / December 1, 1996[3] | M4982LL/A | 100 MHz | 16 MB (Apple); 8 or 16 MB (EveryMac) | 800 MB | 4× (AppleCD 600i) |
| 5260/120 | October 1, 1996[2] | September 19, 1996 / March 1, 1997[4] | M5233LL/A | 120 MHz | 16 MB | 1.2 GB | 8× (AppleCD 1200i) |
Drive models are from Apple's service manual (p. 30); the manual also lists a 1.6 GB drive.[5] Apple's specification pages give 16 MB as the minimum for both models, as does the Specifications chapter of the service manual (p. 29), but the manual's model overview lists "16 MB of DRAM minimum" as one of the ways the 5260/120 differs from the 5260/100 (p. 4).[1][5] Apple's developer note for the 5260 gives 8 MB installed in a SIMM slot (Table 1-1, p. 3).[7]
| Item | Figure |
| Processor | PowerPC 603e at 100 MHz (5260/100) or 120 MHz (5260/120); integrated FPU and PMMU; 32 KB level-1 cache; 64-bit data path, 40 MHz bus |
| RAM | 16 MB minimum; two 72-pin SIMM sockets, 80 ns or faster, fitted singly; 64 MB maximum |
| ROM | 4 MB |
| Level-2 cache | 256 KB on a card in its own slot on the logic board; Apple's specification pages list it as standard on the 5260/100 and optional on the 5260/120 |
| Video | 1 MB DRAM frame buffer on the logic board; 640 × 480 at 16-bit |
| Display | 14-inch shadow-mask CRT, 12.8-inch viewable; 0.28 mm dot pitch; 66.7 Hz; active raster 240 × 185 mm; 9,300 K white point |
| Storage | IDE hard drive (800 MB, 1.2 GB or 1.6 GB); tray-loading CD-ROM on the internal SCSI bus (ID 3); 1.4 MB SuperDrive, manual insert |
| Ports | One ADB; two serial (mini DIN-8, LocalTalk); external SCSI (DB-25, up to seven devices); sound input; front headphone jack and rear stereo output |
| Expansion | LC processor-direct slot (96/114-pin); 112-pin communications slot for a modem or Ethernet card; 60-pin video-in slot; 10-pin TV tuner connector; 22-pin external video connector slot |
| Sound | 16-bit stereo output, 16-bit mono input; records at 11 or 22 kHz, plays at 22 kHz |
| Electrical | 100–240 V AC, 47–63 Hz; 240 W maximum; 4.0 A maximum; 40 A peak inrush |
| PRAM battery | 4.5 V alkaline pack on a plug and hook-and-loop base; replace below 3.0 V |
Sources: service manual pp. 9–11, 19, 28–43, 65, 171, 174–177;[5] processor, bus, cache, RAM grouping and battery type from Apple's specification pages.[1][2]
The processor-direct slot takes many cards made for the Macintosh LC family, but Apple says it is not a true PDS: cards that work with the main processor, such as cache or FPU cards, do not work in it (p. 11).[5] The external video connector is an optional module that mirrors the built-in screen on a second monitor; it cannot drive a separate desktop (pp. 19, 32).[5] EveryMac says a second display can be driven through an LC PDS video card.[3]
EveryMac says that 1 MB of system RAM is dedicated to video. Apple's specification pages and service manual give a separate 1 MB of DRAM on the logic board for the frame buffer.[3][1][5]
Where Apple's documents disagree
- Power: the service manual gives 240 W maximum, 4.0 A, and in the same table "220 W maximum for all line and load conditions" (p. 42). Apple's specification pages give 125 W and 4 A.[5][1]
- Weight: the specification pages give 45 lb. The service manual prints 17 lb without CD-ROM and "19 lb. (21.15 kg)" with it (p. 43); 21.15 kg is about 46.6 lb, close to the specification-page figure.[5][2]
- Dimensions: the service manual gives 16 in wide and 15.1 in deep (p. 43); the specification pages give 15.1 in wide and 16 in deep.[5][1]
Known faults
These come from Apple's symptom charts for the 5260 and 5280.[5]
- A 5260/100 with the 1.6 GB ATA drive (661-1107) that shows a flashing question mark at startup, sometimes cleared by a restart: Apple says to replace the drive if its serial number is in the range XXX6 0 9 9 XXXXX to XXX6 1 3 1 XXXXX (p. 63).
- A computer that will not start from the keyboard but starts from the rear power switch, or restarts after Shut Down: after checking the keyboard, Apple's cure is a new analogue board (p. 49).
- A rattling noise at startup with the Apple External Video Connector fitted: the external video cable is touching the fan blades and should be pressed or folded out of the way (p. 71).
- Crackling from sounds other than system beeps: if the static changes with the Sound control panel volume, install Audio Volume Extension 1.1 or later; otherwise the logic board (p. 52).
- MPEG card faults: distorted sound needs the modified MPEG board, identified by a jumper from U5 pin 2 to D1 pin 1 (p. 51); video that will not play needs a card whose U12 is marked 341S0205, printed "341SO205" in the manual (p. 54).
See Power Macintosh 5260 Troubleshooting for the full charts.
Adjustments
Apple's adjustments for the 5260 and 5280 are light meter setup, geometry, video and power supply (pp. 184–214). The power-supply adjustment must be done whenever the analogue board or power supply has been taken out: connect a DC voltmeter between the metal chassis and pin 3 of P805 on the power supply, and set R828 for 110 V DC (pp. 213–214).[5] The 5200 and 5300 high-voltage adjustment (29.5 V at D713 or D703) is marked "not for 5260, 5280" and does not apply.[6]
The power supply and analogue board carry mains and CRT voltages, and the power-supply adjustment is made with the machine running. Discharge the CRT before working near it; see CRT Discharge Procedure.
Maintenance and repair
- Power Macintosh 5260 General Maintenance: access, SIMMs, battery, resets and the adjustment controls
- Power Macintosh 5260 Troubleshooting: Apple's symptom charts
- Power Macintosh 5260 Capacitor Replacement Guide: board part numbers and what to check after a recap
- Power Macintosh 5260 Specifications: the full specification tables from the service manual
Service documentation
Apple's Power Macintosh/Performa 5260, 5280 Series Service Source (216 pages) covers the Power Macintosh 5260/100 and 5260/120 and the international Performa 5260/120 and 5280. It is module-level: take-apart, symptom charts, adjustments and an exploded view with part numbers, but no schematics.[5]
Apple's owner's manual, the Power Macintosh User's Manual for Power Macintosh 5260 series computers (1996), covers setup, troubleshooting and reinstalling software, and its Appendix B shows how to open the computer and fit LC-PDS and communication cards, SIMMs and the level-2 cache module (pp. 133–149).[8] Its technical appendix gives a 12 MB minimum and 70 ns SIMMs, which differ from the service manual.[8] Download: Power Macintosh 5260 Series User's Manual.pdf.
Apple's developer note for the machine describes its architecture, I/O and expansion slots for card designers, with mechanical drawings of the I/O expansion cards: Power Macintosh 5260 Computer Developer Note (1996).pdf.[7]
- ↑ 1.0 1.1 1.2 1.3 1.4 1.5 1.6 Apple, "Power Macintosh 5260/100: Technical Specifications".
- ↑ 2.0 2.1 2.2 2.3 Apple, "Power Macintosh 5260/120: Technical Specifications".
- ↑ 3.0 3.1 3.2 3.3 EveryMac, "Power Macintosh 5260/100 Specs".
- ↑ 4.0 4.1 EveryMac, "Power Macintosh 5260/120 Specs".
- ↑ 5.00 5.01 5.02 5.03 5.04 5.05 5.06 5.07 5.08 5.09 5.10 5.11 5.12 5.13 Apple Computer, Service Source: Power Macintosh/Performa 5260, 5280 Series (1997), File:Powermac.perf 5260.5280.pdf; see Power Macintosh/Performa 5260, 5280 Series Service Source. Page numbers are PDF pages.
- ↑ 6.0 6.1 Apple Computer, Service Source: Power Macintosh/Performa 5200 and 5300 (not 5260, 5280) (1997), File:Powermac.perf 5200.5300.pdf; cover (p. 1), Specifications pp. 40 and 47. Page numbers are PDF pages.
- ↑ 7.0 7.1 Apple Computer, Developer Note: Power Macintosh 5260 Computer (1996), Table 1-1, printed p. 3. Hosted as File:Power Macintosh 5260 Computer Developer Note (1996).pdf.
- ↑ 8.0 8.1 Apple Computer, Power Macintosh User's Manual: for Power Macintosh 5260 series computers (1996), Appendix B (pp. 133–149) and Appendix D, Technical Information (pp. 159–166), printed page numbers. Hosted as File:Power Macintosh 5260 Series User's Manual.pdf.
