Sega Master System II
Revision as of 09:51, 12 May 2025 by Josh (talk | contribs)
European PAL “SMS II” (Model 3000-07) with integrated Alex Kidd in Miracle World'
Type8-bit home video-game console
ReleasedOctober 1990 (Europe)
1990 (North America)
1991 (Brazil, TecToy)
Discontinued1996 (JP/NA/EU) • 2003 (Brazil)
Intro priceUS US$99 (1990 pack-in) • UK £79.99
CPUZilog Z80 (clone) @ 3.579545 MHz (NTSC) / 3.546894 MHz (PAL)
Memory8 KB Work RAM • 16 KB Video RAM
StorageROM cartridges (‘‘Mega Cartridge’’ 128 KB – 512 KB; a few 1 MB with mapper)
Integrated ROM game or BIOS
Display256 × 192 (NTSC) / 256 × 224 (PAL) • 32 colours onscreen from 64-entry palette • 64 sprites
SoundTexas Instruments SN76489 PSG (3 tone + 1 noise) • 8-bit mono
Dimensions225 mm W × 215 mm D × 70 mm H
Weight≈ 0.8 kg
OS / FirmwareNone – game ROM executes directly
PredecessorSega Master System (Model 1)
SuccessorMega Drive / Genesis
CodenameMK-2000 / Model 3000
Model no.VA0 – VA1 motherboard revisions
The Sega Master System II (SMS II) is a low-cost redesign of Sega’s 8-bit Master System, launched in 1990 to extend the life of the platform alongside the 16-bit Mega Drive. Sega’s engineers removed costly interfaces (card slot, A/V RGB, expansion port) and shrank the PCB to reduce bill-of-materials to under US$40, allowing aggressive pricing against Nintendo’s NES.
Internal Architecture
Sub-system Specification (Model 3000-07, PAL VA1)
CPU Custom Sega 315-5685 (Z80 core) @ 3.546 MHz (PAL)
VDP Sega 315-5246 (derived from Yamaha V9938) • 2 scroll planes, 64 sprites, 16 KB dual-ported VRAM
Audio TI SN76489AN PSG clocked by VDP / 16 (≈ 357 kHz)
(Left & Right tied → mono output on RF/composite)
Memory 8 KB SRAM @ 3.5 MHz (6116)
16 KB VRAM (2 × 8 KB TMS4416 or built-in VRAM in 315-5713 ASIC)
Bus I/O Cartridge port 50-pin edge, I/O port (controllers), RF modulator, linear PSU
Z80 Memory Map
SMS II Address Space
Range Size Function
0000–BFFF 48 KB Cartridge ROM / BIOS; 8 KB per-page via mapper
C000–DFFF 8 KB Work RAM
E000–FFFF 8 KB Mirror of C000–DFFF
FFFC–FFFF Bank-control registers (mapper)
Boot priority:
  1. Internal BIOS (8 KB or 128 KB) – shows “SEGA” splash + built-in game.
  2. If BIOS disabled (JP pads), control jumps to cartridge vector $0000.
Video Modes & Timing
Region Active area Master clock Lines/frame Refresh
NTSC 256 × 192 53.693175 MHz ÷15 = 3.579 MHz (VDP) 262 59.922 Hz
PAL 50 Hz 256 × 224 53.203424 MHz ÷15 = 3.5469 MHz 313 49.701 Hz
VDP can output composite and RGB; SMS II only routes composite + mono audio to an RF modulator, necessitating A/V modding for RGB.
Cartridge / Edge Bus (50-pin)
The SMS II retains the 50-pin “Mega Cartridge” connector used by the original console:
Selected Pins
Pin Signal Direction Notes
1 GND Ground
2 D7 CPU data
3 D6
43 /WR Controls SRAM writes on mapper carts
44 /MREQ Memory request
45 /M0-5 Slot select (low when cart area $0000–$BFFF accessed)
46 /IORQ Unused by ROM, active for My Card adapter
47 +5 V 500 mA max
48 T_CE Sega mapper paging
49 RESET Resets cartridge mapper / SRAM
50 GND
Full table on Sega Master System Cartridge Pin-out.
Historical Context & Sales
  • Announced July 1990 as a cost-reduced successor; included *Alex Kidd* or *Sonic the Hedgehog* in ROM to stimulate sales.
  • Europe & Brazil remained the Master-System strongholds: by 1993 > 6 million SMS II units shipped in EU territories; TecToy sold an additional 2 million (1991-2003).
  • In North America it served as a US$50 budget console beside the Genesis (approx. 300 k units).
Motherboard Revisions & Known Errata
Rev ASIC Notable features / quirks
VA0 (1990) 315-5246 VDP + discrete PSG Separate SN76489; composite jail-bars; BIOS 1.3 (Alex Kidd)
VA1 (1992) 315-5713 “One-Chip” Integrates VDP + PSG + mapper; 64-pin QFP; some units have audio buzzing due to missing 10 µF cap at C31
  • Early VA0 boards omit 33 Ω series resistors on RGB lines ⇒ over-driven when modded.*
Audio Path
Z80 → SN76489 square/noise → low-pass RC (33 k/3.3 nF) → CXA1145 composite encoder → RF can; stereo mods tap pre-RF and split PSG tone channels.
Common Faults (SMS II)
  • No RF / distorted video – cracked solder on CXA1145 or corroded RF shield.
  • Low audio volume / buzzing – dried C31 10 µF coupling cap (VA1).
  • Power LED flicker – 5 V rail ripple; replace 2200 µF filter cap (C8).
  • Controller port failures – broken traces to 315-5237 I/O decoder.
Detailed procedures: Master System II Troubleshooting Guide & Master System II Capacitor Replacement Guide.
Maintenance & Mods
  • Composite/RGB A/V mod: lift RF modulator pin 11, route CXA1145 RGB → mini-DIN 8; add 75 Ω/220 µF caps. Step-by-step on SMS II AV Output Guide.
  • Pause-button cap fix: add 100 nF across reset-pause lines to avoid random resets on VA0.
  • FM-Sound board: installs YM2413 + logic; requires decoder ROM patch or EverDrive.
Trivia & Pop-culture
  • European advertising used the slogan “The Leader of the 8-Bit Revolution” even after the Mega Drive launched.
  • Brazilian TecToy versions included *Mônica no Castelo do Dragão* (a comic-book reskin of *Wonder Boy II*).
  • An SMS II appears in Netflix series Stranger Things S4-E1, but incorrectly wired to a US CRT with PAL console shell.
See also / further reading
