Macintosh IIvx Capacitor Replacement Guide
Revision as of 16:12, 11 February 2026 by Josh (talk | contribs) (Added Capacitor_Replacement_Guides category)
The Macintosh IIvx logic board contains surface-mount electrolytic capacitors that leak after 30+ years. This guide provides capacitor specifications and replacement procedures.
The IIvx, Macintosh IIvi, and Performa 600 share the same logic board design, so capacitor specifications are identical.[1]
Why Recap?
Electrolytic capacitors contain liquid or gel electrolyte that leaks over time. The leaked electrolyte is:
  • Conductive — creates short circuits between traces
  • Corrosive — destroys copper traces and attacks solder joints
Proactive recapping prevents irreversible damage.
Logic Board Capacitors
The IIvi/IIvx/Performa 600 logic board contains SMD electrolytic and axial capacitors:[2][3]
IIvi/IIvx/Performa 600 Logic Board Capacitors
Capacitance Voltage Qty Package Recommended Replacement
47 µF 16V 6 SMD electrolytic KEMET T491D476K016AT (tantalum)
220 µF 16V 2 Axial electrolytic Vishay MAL213825221E3
Macintosh IIvi/IIvx logic board capacitor locations. Source: Recap-a-Mac
Replacement Options
Tantalum (recommended for SMD):
  • Solid electrolyte — cannot leak
  • Available from Mouser, Digi-Key
  • Note: stripe marks positive terminal (opposite of electrolytic)
Axial electrolytic:
  • Use 105°C rated, low-ESR types
  • Match original footprint
  • Stripe marks negative terminal
Power Supply Capacitors
The IIvx uses a 230W power supply shared with the IIci, IIcx, IIvi, Performa 600, Centris 650, and Quadra 700. Power supply capacitors vary by manufacturer (Sony, Astec, Delta).[4]
Consult the specific power supply label for capacitor values. Common values include high-voltage primary capacitors (200V–400V) and secondary filter capacitors.
Warning: Power supplies contain high-voltage capacitors. Discharge before servicing.
Tools Required
  • Soldering iron with fine tip (for SMD) and chisel tip (for axial)
  • Hot air rework station (optional but helpful for SMD)
  • Solder (60/40 or 63/37, 0.5-0.8mm)
  • Flux (no-clean or rosin)
  • Solder wick and desoldering pump
  • Isopropyl alcohol (>90%) and brushes
  • Multimeter
  • Safety glasses
Removal Procedure
SMD Capacitors
  1. Apply flux to capacitor terminals
  2. Heat one terminal while gently tilting the capacitor
  3. Alternate terminals until capacitor releases
  4. Or use hot air at 350-380°C
Axial Capacitors
  1. Heat one lead while applying gentle pressure
  2. Remove solder with wick or pump
  3. Repeat for second lead
  4. Remove capacitor
Cleaning
After removal:
  1. Remove all electrolyte residue with isopropyl alcohol
  2. Inspect traces for corrosion
  3. Check continuity on damaged-looking traces
  4. Repair with conductive pen or jumper wire if needed
Installation
Polarity
Critical: Capacitors are polarized. Installing backwards causes:
  • Electrolytic: bulging, popping, or fire
  • Tantalum: short circuit, fire
SMD electrolytic: stripe marks negative Tantalum: stripe marks positive Axial electrolytic: stripe marks negative
Soldering
  1. Tin one pad
  2. Position capacitor (verify polarity)
  3. Tack one terminal
  4. Solder second terminal
  5. Reflow first terminal
  6. Clean flux residue
Testing
Before reassembly:
  1. Visual inspection — verify all polarities
  2. Continuity test — check for shorts
  3. Power-on test — verify startup chime and operation
Purchasing Kits
Pre-made kits available from:
  • Console5 (console5.com)
  • Various eBay sellers
  1. Macintosh IIvi, Recap-a-Mac—link(accessed 2026-02-09)
  2. Macintosh IIvi, Recap-a-Mac—link(accessed 2026-02-09)
  3. Macintosh IIvx / IIvi / Performa 600 Cap Kit, Console5—link(accessed 2026-02-09)
  4. Compact Desktop Power Supply Capacitor Lists, 68kMLA—link(accessed 2026-02-09)
