Related changes
Enter a page name to see changes on pages linked to or from that page. (To see members of a category, enter Category:Name of category). Changes to pages on your Watchlist are in bold.
List of abbreviations:
- N
- This edit created a new page (also see list of new pages)
- m
- This is a minor edit
- b
- This edit was performed by a bot
- (±123)
- The page size changed by this number of bytes
30 September 2026
23:26 | Apple IIe 2 changes history 0 [Josh (2×)] | |||
23:26 (cur | prev) +1 Josh talk contribs (Undo whitespace change from the emoji sweep (page had no emoji)) Tag: Manual revert | ||||
23:22 (cur | prev) −1 Josh talk contribs (Remove emoji) Tag: Reverted | ||||
23:26 | Macintosh Performa 630 2 changes history 0 [Josh (2×)] | |||
23:26 (cur | prev) +4 Josh talk contribs (Undo whitespace change from the emoji sweep (page had no emoji)) Tag: Manual revert | ||||
23:24 (cur | prev) −4 Josh talk contribs (Remove emoji) Tag: Reverted | ||||
| 18:54 | Power Macintosh 6500 diffhist −1,104 Josh talk contribs (Rewrite on the 6400/6500 SS, Apple spec pages and the newly hosted developer note and user's manual: battery now states Apple spec 4.5 V alkaline vs SS lithium warning (was lithium/never vinegar); 140 W SS vs 220 W spec; add Apple's jitter, blur and OPC L2 cache faults with serial ranges, part numbers, voltage switch; remove duplicated tables and puffery) | ||||
| 18:51 | Power Macintosh 6300 diffhist −721 Josh talk contribs (Rewrite on Apple's 6300/120 and 6300/160 spec pages and the Performa 6200/6300 SS: two models (was 100/120 MHz); frame buffer is 1 MB DRAM, not system RAM; 4.5 V alkaline battery, 3.0 V test; logic board upgrade and reset button; remove Performa-6360 boilerplate block; Power Macintosh-badged Commons photo) | ||||
| 18:51 | Power Macintosh 6200 diffhist +826 Josh talk contribs (Rewrite on Apple's 6200/75 spec page and the newly hosted 5200/6200 developer note: frame buffer is separate 1 MB DRAM (not system RAM); L1/L2/ROM layout, 37.5 MHz bus, sound per dev note, 4.5 V alkaline battery (3.0 V test); state Apple vs EveryMac dates; Console5 820-0685-B cap list; credit Commons photo) | ||||
| 18:48 | Macintosh XL diffhist −12,159 Josh talk contribs (Rewrite on Apple's Lisa/Macintosh XL Technical Procedures: dimensions 13.8 H x 18.7 W x 15.2 D in (Lisa 2 Owner's Guide), Screen Kit is three CPU-board ROMs (341-0346/0347/0348) plus a transformer, not 'yoke coil'; XL boards 661-93170/93171; remove Wikipedia/uncited history, invented doc part numbers, Widget/Sun Remarketing/market sections; add infobox photo (Commons, CC BY 2.0)) | ||||
18:45 | Power Macintosh 6100 DOS Compatible 2 changes history −1,235 [Josh (2×)] | |||
18:45 (cur | prev) −71 Josh talk contribs (Drop price EveryMac does not tie to this configuration) | ||||
18:44 (cur | prev) −1,164 Josh talk contribs (Rewrite on Apple's 6100/66 DOS Compatible spec page and the 6100 SS: it is a 66 MHz model (Jan 1995-May 1996), not 60 MHz; card sits in the PDS slot via adapter, not NuBus; add install procedure, J10 jumper, fault charts; add card photo (Commons, CC BY-SA 2.0)) | ||||
| 18:43 | Power Macintosh 6100 diffhist +1,787 Josh talk contribs (Rewrite on the 6100/WS 6150 SS, Apple spec pages and Apple developer notes: all five models with Apple dates, bus clocks, 601 unified cache (Motorola), Apple service notes; remove duplicated service-data block; Commons photo with credit) | ||||
18:40 | Power Macintosh 5400 2 changes history +5,270 [Josh (2×)] | |||
18:40 (cur | prev) +569 Josh talk contribs (Cite and link the newly hosted Power Macintosh 5400 developer note (40 MHz 64-bit memory bus)) | ||||
18:30 (cur | prev) +4,701 Josh talk contribs (Rewrite on the 5000 Series SS and Apple spec pages: frame buffer is 1 MB on-board DRAM (not system RAM); weight 47 lb (SS lb figures misprinted); add 5400/200, Apple dates, Ethernet per model, DIMM interleaving, Rev. B, service part numbers, HV adjustment, 4.5 V alkaline battery; infobox photo was a PM 5500/275, now the 5200 enclosure with honest caption) | ||||
18:40 | Power Macintosh 5260 4 changes history +3,327 [Josh (4×)] | |||
18:40 (cur | prev) +600 Josh talk contribs (Cite and link the newly hosted Power Macintosh 5260 developer note (8 MB RAM, Table 1-1)) | ||||
18:35 (cur | prev) +842 Josh talk contribs (Cite and link the newly hosted Power Macintosh 5260 user's manual) | ||||
18:27 (cur | prev) +34 Josh talk contribs (MPEG U12 part number as printed) | ||||
18:25 (cur | prev) +1,851 Josh talk contribs (Rewrite on the 5260/5280 Service Source and Apple spec pages: frame buffer is 1 MB on-board DRAM (not system RAM); add 4.5 V alkaline battery, R828 PSU adjustment, Apple dates, known faults; state SS vs spec-page power/weight conflicts; size infobox image) | ||||
| 18:35 | Macintosh TV diffhist −8,096 Josh talk contribs (Rewrite on Apple's Service Source: fix RAM (4 MB on board, not '5 MB soldered'), 120 W / 100-240 V (not 60 W / 90-264 V), SIMM speed, FPU socket conflict stated; drop Wikipedia cites, uncited successor, Sony remote, Performa 5420 and caddy claims; duplicate spec tables merged; board numbers from Recap-a-Mac photos; infobox image link fixed) | ||||
| 18:13 | Macintosh Quadra 700 diffhist −3,176 Josh talk contribs (Rewrite on the IIcx/IIci/Quadra 700 Service Source, Apple spec page, EveryMac and Ars Technica: restore VRAM table (512 KB to 2 MB, six VRAM SIMM sockets) that Apple's spec page documents; Ethernet is AAUI-15 per Apple (SS says AUI-15), not 'not AAUI'; add upgrade kits, 80 ns SIMM warning; remove self-referential 'formerly published here' text, uncited codenames, clock and case-history claims; photo credited) | ||||
| 18:11 | Macintosh Quadra 660AV diffhist −6,060 Josh talk contribs (Rewrite on Apple spec page, 840AV/660AV developer note and Service Source: one GeoPort (modem port), 2 MB ROM (SS misprints 1 MB), DSP 55.5 MHz, dates per Apple/EveryMac; remove uncited codename, SuperMario, benchmark, upgrade-price and key-combination claims and Wikipedia cite; CC0 photo of an actual Quadra 660AV replaces the Centris photo) | ||||
18:09 | Macintosh Quadra 650 2 changes history −1,565 [Josh (2×)] | |||
18:09 (cur | prev) +18 Josh talk contribs (Unlink missing Power Macintosh 7100 page; link its Service Source) | ||||
18:09 (cur | prev) −1,583 Josh talk contribs (Rewrite on the Centris 650/Quadra 650 Service Source, developer note and Apple spec pages: power is 112 W per the Service Source (Apple's spec pages list 230 W for base and upgrade-card configs; both stated); sound input is mono, not stereo; serial 230.4 kbit/s; remove uncited benchmark table, interleaving and drive-sled claims; photo credited) | ||||
| 18:01 | Macintosh Quadra 630 diffhist −3,114 Josh talk contribs (Rewrite on the LC 630/Quadra 630/Performa 640 Service Source and Apple spec page: Quadra 630 is a 68040 with FPU (page also said 68LC040); one ADB port; video memory not expandable; 8-bit sound via DFAC-era spec, not 16-bit ASC; battery 4.5 V alkaline; price, weight per Apple/EveryMac; Apple photo of a Quadra 630 replaces LC 630 photo; remove uncited codename and 'first/last Quadra' claims) | ||||
| 17:57 | Macintosh Quadra 610 DOS Compatible diffhist −5,671 Josh talk contribs (Rewrite on Apple's Service Source and spec page and Byte (Apr 1995 p. 165): state Apple's 68LC040/68040 and 32/64 MB DOS-RAM disagreements instead of asserting one; remove uncited Y-cable, hot-switching, sound, NuBus-adapter and troubleshooting claims, Wikipedia and Edible Apple cites; codename is Houdini (the card), not Speedbump) | ||||
| 17:56 | Macintosh Quadra 610 diffhist −3,967 Josh talk contribs (Rewrite on the Quadra 610/Centris 610/WS 60 Service Source and Apple's spec page: audio was reversed (output is stereo, input mono); serial 230.4 kbit/s per Apple; 112 W (SS) and 210 W (Apple spec) both stated; discontinued date per Apple; remove uncited codename, heatsink and VRAM-speed claims; add part numbers, upgrades, CPU procedure; convert bold lists; photo credited) | ||||
| 17:56 | Macintosh Quadra 900 diffhist −851 Josh talk contribs (Rewrite from Service Source, Apple tech specs, LEM and EveryMac: Q900 photo; fix 'no symptom charts' (SS has them), SS height misprint, VRAM table; add SCSI termination, keyswitch, upgrades, tantalum board (Recap-a-Mac); drop Wikipedia-only and uncited upgrade prices and 'first to run OS 8') | ||||
| 17:55 | Macintosh Plus diffhist −1,710 Josh talk contribs (Rewrite on Plus Service Source, Guide to the Macintosh Family Hardware and The Dead Mac Scrolls: remove edit-history paragraphs and uncited/irrelevant citations (BYTE 1983, 1984 book, dead LEM URL); sound path corrected (RAM buffer and Sony chip, not VIA/LM380); keyboard is RJ-11; add memory resistor table, power limits, voltage/video adjustments with R56, known faults with page cites; Compact Macintosh cat) | ||||
| 17:53 | Macintosh Quadra 950 diffhist −3,261 Josh talk contribs (Rewrite on the Quadra 900/950/AWS 95 Service Source with PDF pages; fix cache contradiction, Apple's 16.8 in / 473 mm height misprint (473 mm = 18.6 in), ADB and Ethernet conflicts stated; video table cited to LEM/EveryMac; remove duplicate PDF embed and tables, apple-history home-page cite, 'most powerful' puffery and wrong 'no symptom charts' claim) | ||||
17:51 | Macintosh Quadra 605 2 changes history −971 [Josh (2×)] | |||
17:51 (cur | prev) +276 Josh talk contribs (Add J18 jumper on the shared LC 475/Quadra 605 service board (Service Source Logic Board pp. 23-24)) | ||||
17:49 (cur | prev) −1,247 Josh talk contribs (Rewrite on the Service Source and LC 475/Quadra 605 Developer Note: Gestalt ID is 94 (89 is the LC 475); slot is accessible via a rear knock-out, not a PDS, 4 W budget; Processor Upgrade is Apple's; ROM and HD discrepancies stated; VRAM table from dev note; remove duplicate spec tables and uncited claims; Quadra 605 photo replaces LC 475 photo) | ||||
| 17:49 | Macintosh Performa 6400CD diffhist −8,122 Josh talk contribs (Redirect to Macintosh Performa 6400: Apple's spec sheets and Service Source list no Performa 6400CD; page described itself as an alternate name with uncited claims) | ||||
| 17:49 | Macintosh Performa 6420 diffhist −4,592 Josh talk contribs (Rewrite on Apple spec sheet 112382 (24 MB minimum, 256K L2), 6400/6500 Service Source and EveryMac; voltage switch; battery chemistry per both Apple documents; Commons photo of a 6420; Navbox) | ||||
| 17:49 | Macintosh Performa 6410 diffhist −5,002 Josh talk contribs (Rewrite on Apple spec sheet 112386, 6400/6500 Service Source and EveryMac: markets per Apple (Japan, Australia, Europe); was not the first mini-tower Performa (the 6400 came first); video RAM is separate; voltage switch; battery chemistry per both Apple documents; Navbox) | ||||
| 17:48 | Macintosh Quadra 840AV diffhist −2,789 Josh talk contribs (Rewrite from Developer Note and Service Source: 840AV photo (was a Quadra 800), fix price, GeoPort count, VRAM table (DN Table 2-13), no PDS, ADB breaker; drop Wikipedia cites, uncited codename and 'first Mac' claims, SCSI budget editorial; add logic board gallery) | ||||
| 17:48 | Macintosh Performa 6400 diffhist +2,806 Josh talk contribs (Rewrite on Apple spec sheets and the 6400/6500 Service Source: video RAM is separate (not system RAM); DIMM types by model; voltage switch and its CD-ROM symptom; modem identification; chassis/board/PSU part numbers; battery: Apple sheets say 4.5 V alkaline, SS warns lithium, both stated; symptom charts; Commons photo; Navbox) | ||||
| 17:47 | Macintosh SE/30 diffhist +3,280 Josh talk contribs (Rewrite: cite GtMFH, Service Source, LEM/EveryMac/Recap-a-Mac by page/URL; correct video RAM address ($FE000000 is the VRAM, not the declaration ROM), codenames per LEM (Fafnir uncited), state the 1990/1991 discontinuation conflict; add SE/SE30 PSU limits, fix 'no rail tolerances'; fix BOMARC SE schematic mislabelled 'Fan and CRT board'; remove puffery and duplicate section) | ||||
| 17:44 | Macintosh Performa 640CD DOS Compatible diffhist +4,727 Josh talk contribs (Rewrite on Apple spec sheet 112351, LC 630/Quadra 630/Performa 640 Service Source and LC 630 DOS user's guide: Mac CPU is 68LC040 (SS spec table misprints 68040); DOS board sits in the CPU socket, adapter in PDS; take-apart, sound card fix; OS 7.5.1; not-sold-in-US claim belongs to the 630CD DOS; battery; Navbox) | ||||
| 17:42 | Macintosh Quadra 800 diffhist −1,568 Josh talk contribs (Rewrite from Service Source and Developer Note: dedupe spec tables, cite case, SCSI, PSU (661-1687/614-0012), slots; fix price/date; drop uncited codename, 8200/9500 case claims, dead Road Apples link; add navbox) | ||||
| 17:42 | Macintosh Performa 638CDV diffhist +1,569 Josh talk contribs (Rewrite on Apple 638CD spec sheet 112041, 630 Series Service Source, LEM and EveryMac: Apple's name is 638CD; remove uncited Sony remote, price and bundle; UHF video-in card fix; battery; Navbox) | ||||
| 17:42 | Macintosh Performa 637CD diffhist +1,832 Josh talk contribs (Rewrite on Apple spec sheet 112350 (8 MB minimum, not 4), 630 Series Service Source (TV tuner and video-in cards fitted), EveryMac price; UHF video-in card fix; battery; drop uncited price and bundle; Navbox) | ||||
| 17:42 | Macintosh Performa 636CD diffhist +2,181 Josh talk contribs (Rewrite: citation pointed at Apple's Quadra 605 sheet (SP221); now Apple 112348, Macworld Sep 1994 (8 MB, 14-inch monitor), EveryMac and LEM; not in the 630 Series SS configuration list; battery; Navbox) | ||||
| 17:42 | Macintosh Performa 636 diffhist +2,517 Josh talk contribs (Rewrite: citation pointed at Apple's Quadra 605 sheet (SP221); now Apple 112348, 630 Series Service Source and Macworld Sep 1994. 636 shipped with a 14-inch display per Apple and Macworld (page said none); conflicting EveryMac/LEM config stated; battery; Navbox) | ||||
| 17:42 | Macintosh Performa 635CD diffhist +1,397 Josh talk contribs (Rewrite on Apple spec sheet 112347, 630 Series Service Source, Macworld Sep 1994 and EveryMac: configuration (15-inch Performa Display, TelePort), 5 MB = 4 MB + 1 MB SIMM; battery 4.5 V alkaline, vinegar; drop uncited bundle; Commons photo; Navbox) | ||||
| 17:40 | Macintosh SE FDHD diffhist +1,244 Josh talk contribs (Rewrite from SE Service Source and GtMFH: infobox photo of an actual SE FDHD (Commons), successor Classic, OS 6.0.3+; remove wrong 'first compact with HD drive' claim (SE/30 came first); add upgrade kit part numbers and procedure, board identification; drop 'no rail tolerance' claim) | ||||
| 17:39 | Macintosh Performa 631CD diffhist −145 Josh talk contribs (Rewrite on Apple spec sheet 112349, EveryMac and 630 Series Service Source: second SIMM slot limits, original system 7.5.1, battery 4.5 V alkaline with vinegar; remove uncited price, discontinued date and software bundle; Commons photo; Navbox) | ||||
| 17:39 | Macintosh SE diffhist +3,836 Josh talk contribs (Rewrite: cite Service Source, Guide to the Macintosh Family Hardware and Dead Mac Scrolls by page; add SE/SE30 PSU output limits (GtMFH Table 6-15), board and schematic notes; fix 'no rail tolerances' claim; merge duplicate documentation section; cite LEM/EveryMac with URLs) | ||||
| 17:38 | Macintosh Performa 630CD diffhist +1,886 Josh talk contribs (Rewrite on Apple spec sheet 112345, 630 Series Service Source and Macworld Sep 1994: battery is 4.5 V alkaline (5.4 is a misprint), vinegar not bicarbonate; one ADB port not two; 8 MB configuration; price from Macworld; remove uncited software bundle; CD-ROM notes; Commons 630 photo; Navbox) | ||||
| 17:36 | Macintosh Performa 6360 diffhist +3,858 Josh talk contribs (Rewrite from Apple spec sheet 112380, EveryMac and 6200/6300 Service Source: L2 is an optional module, not standard; EDO board check, PCI fitting, reset, symptom charts, part numbers; Alchemy claim attributed to Wikipedia; 6360 photos from Commons; guides point to Performa 5400; Navbox) | ||||
| 17:34 | Macintosh Performa 6320CD diffhist +192 Josh talk contribs (Rewrite from Apple spec sheet 112379, EveryMac and 6200/6300 Service Source: discontinued 1 Sep 1996 (was 1 Oct); price; 6320-specific part numbers and Cuda reset procedure; not covered by REA; frame buffer is separate DRAM; remove boilerplate block; Navbox) | ||||
| 17:33 | Macintosh Performa 6310CD diffhist −832 Josh talk contribs (Rewrite from Apple spec sheet 112377, EveryMac and 6200/6300 Service Source: Apple date 14 Feb 1996, not sold in US; frame buffer is separate DRAM; battery 4.5 V alkaline with Apple's test; remove boilerplate Apple-errors block and bold lists; Navbox) | ||||
