Macintosh Performa 5400 Capacitor Replacement Guide
Revision as of 21:52, 21 September 2026 by Josh (talk | contribs) (Verification drive: flag unverified component data pending check against a primary source)
Replacing electrolytic capacitors (recapping) in your Macintosh Performa 5400 series computer is essential for long-term reliability. The Performa 5400 uses the Alchemy logic board, shared with the Power Macintosh 5400 and Performa 6400 series.
Capacitor Inspection
Signs that your Performa 5400 needs recapping:
  • Bulging Tops – Capacitors with domed or swollen tops indicate internal failure
  • Leaking Electrolyte – Brown or orange residue around capacitor base
  • Corrosion or PCB Staining – Discoloration on the PCB near capacitors
  • Audio distortion – Crackling, low volume, or missing audio
  • Boot failures – Intermittent startup or random crashes
  • Visual artifacts – Display anomalies caused by power rail instability
Macintosh Performa 5400 Capacitor List
Logic Board Capacitors
The Alchemy logic board uses primarily surface-mount electrolytic capacitors.
Logic Board Capacitor Specifications
Reference Capacitance Voltage Type Notes
C1 100µF 16V SMD Electrolytic Audio section
C2 100µF 16V SMD Electrolytic Audio section
C3 47µF 16V SMD Electrolytic Power filtering
C4 47µF 16V SMD Electrolytic Power filtering
C5 10µF 16V SMD Electrolytic Decoupling
C6 10µF 16V SMD Electrolytic Decoupling
C7 100µF 10V SMD Electrolytic Power filtering
C8 100µF 10V SMD Electrolytic Power filtering
C9 22µF 16V SMD Electrolytic Audio section
C10 22µF 16V SMD Electrolytic Audio section
Note: Capacitor designations may vary. Always verify values before ordering replacements.
Power Supply Capacitors
The power supply contains larger through-hole electrolytic capacitors that may also need replacement:
Power Supply Capacitor Specifications (Typical)
Capacitance Voltage Type Quantity
680µF 200V Radial 2
1000µF 25V Radial 2
470µF 25V Radial 2
220µF 25V Radial 2
100µF 16V Radial 4
47µF 50V Radial 2
10µF 50V Radial 4
Warning: Power supply capacitors store dangerous voltages. Discharge fully before servicing.
  1. Discharge CRT – Follow the CRT Discharge Procedure before any internal work
  2. Remove Logic Board – Disconnect all cables and remove mounting screws
  3. Document Capacitor Positions – Photograph the board before removal
  4. Desolder Old Caps – Use a temperature-controlled iron (300–350°C) and desoldering braid or pump
  5. Clean Pads – Remove old solder and any leaked electrolyte with isopropyl alcohol
  6. Install Replacements – Observe correct polarity; negative stripe aligns with board marking
  7. Solder Securely – Use quality 60/40 or 63/37 leaded solder for best results
  8. Trim Leads – Cut flush to avoid shorts (through-hole only)
  9. Inspect Work – Check for solder bridges and cold joints
  10. Clean Board – Remove flux residue with isopropyl alcohol
  • Temperature-controlled soldering iron (Hakko FX-888D or similar)
  • Fine soldering tip (chisel or conical, 1–2mm)
  • Desoldering pump or braid
  • Fine leaded solder (0.5–0.8mm diameter)
  • Isopropyl alcohol (90%+) and ESD-safe brush
  • Multimeter with continuity function
  • Safety glasses
  • Anti-static wrist strap
For replacements, use quality brands:
  • Nichicon – UPW, UHE, or UPJ series
  • Panasonic – FR or FC series
  • Rubycon – ZLH or YXF series
  • United Chemi-Con – KZE or KY series
Avoid generic or unknown brand capacitors for reliability.
Voltage Checks After Recap
After recapping, verify power supply voltages:
  • +5V rail: 4.85V – 5.15V
  • +12V rail: 11.9V – 12.7V
  • +3.3V rail: 3.2V – 3.4V
If voltages are out of spec, recheck your work and PSU capacitors.
Additional Tips
  • Take photos before and after for reference
  • Work in a well-ventilated area when soldering
  • Don't overheat SMD pads – they can lift from the PCB
  • Consider recapping the power supply at the same time as the logic board
  • Test the system thoroughly after recapping before reassembly
