Atari Portfolio Capacitor Replacement Guide
Revision as of 20:26, 29 March 2026 by Josh (talk | contribs) (Creating Atari Portfolio article)
Atari Portfolio palmtop computer
ManufacturerAtari Corporation
TypePalmtop Computer
CPUโ€”
Memoryโ€”
Storageโ€”
Displayโ€”
Soundโ€”
OS / Firmwareโ€”
This page provides a capacitor replacement guide for the Atari Portfolio palmtop computer. The Portfolio has a relatively small number of capacitors compared to desktop computers of the era, with most related to power regulation, voltage conversion, and the LCD bias supply. Capacitor failure can cause power instability, display problems, and data loss.
Overview
The Atari Portfolio's main board is a compact single-board design containing the Intel 80C88 CPU, RAM, ROM, and all support circuitry. The board uses a mix of SMD (surface-mount) and through-hole electrolytic and ceramic capacitors. The primary areas where capacitor failure causes issues are:
  • Power regulation โ€” Input filtering and voltage regulation for the 5V logic supply
  • LCD bias generator โ€” A small charge pump/DC-DC inverter circuit generates the negative voltage (~-15V to -20V) required to drive the LCD
  • Memory backup โ€” A capacitor (or supercapacitor) that maintains RAM contents during battery changes
  • Decoupling โ€” Standard ceramic decoupling capacitors near the CPU and support ICs
Disassembly for Capacitor Access
To access the main board capacitors:
  1. Remove batteries and AC adapter
  2. Warm the display window with a hair dryer and carefully peel it off (see Atari Portfolio General Maintenance#Display Window)
  3. Remove the two black screws beneath the display window
  4. Carefully separate the top case from the inner bezel โ€” release the plastic clips gently with a spudger
  5. Remove the silver screws securing the metal RF shield
  6. Mark the orientation of all ribbon cables before disconnecting
  7. Take extreme care with the power ribbon cable between the keyboard and display PCBs โ€” this is fragile and easily damaged
  8. The main board is now accessible for capacitor inspection and replacement
Capacitor List
The following table lists the electrolytic capacitors found on the Atari Portfolio main board. Due to PCB revision variations, exact reference designators may differ slightly between units. Always verify values against your specific board before ordering replacements.
Atari Portfolio Electrolytic Capacitor List
Ref. Value Voltage Rating Type Location / Function
C1 100 ยตF 10V Electrolytic (SMD or through-hole) Main power input filter โ€” smooths battery/adapter supply
C2 47 ยตF 10V Electrolytic (SMD) Secondary power filter โ€” post-regulator decoupling
C3 10 ยตF 16V Electrolytic (SMD) Voltage regulator output filter
C4 4.7 ยตF 25V Electrolytic (SMD) LCD bias charge pump โ€” negative voltage generator input
C5 4.7 ยตF 25V Electrolytic (SMD) LCD bias charge pump โ€” negative voltage generator output
C6 1 ยตF 50V Electrolytic (SMD) LCD bias filter capacitor
C7 0.47 F (470 mF) 5.5V Supercapacitor (through-hole) Memory backup โ€” maintains RAM during battery changes (~1โ€“2 minutes hold time)
Note: In addition to the electrolytic capacitors listed above, the board contains numerous small ceramic capacitors (typically 100 nF / 0.1 ยตF) for decoupling. These rarely fail but should be inspected if unexplained instability occurs.
Capacitor Functions and Failure Symptoms
Capacitor Failure Symptoms
Capacitor(s) Function Failure Symptom
C1, C2 Main power filtering Unit fails to power on, intermittent resets, unstable operation. May appear to work briefly then cut out.
C3 Regulator output Erratic behaviour, random crashes, peripherals not working correctly.
C4, C5, C6 LCD bias voltage generation Display appears blank even though the unit is running (key clicks audible). Contrast adjustment has no effect. If measured, the LCD bias voltage (normally ~-15V to -20V) will be absent or severely reduced.
C7 Memory backup (supercapacitor) C: drive data lost immediately upon battery removal (instead of the normal ~1โ€“2 minute grace period). If this capacitor has failed, battery changes will always result in data loss.
Replacement Procedure
Tools Required
  • Temperature-controlled soldering iron (suitable for SMD work โ€” fine tip recommended)
  • Solder (leaded 63/37 recommended for ease of work on vintage boards)
  • Flux (no-clean liquid flux)
  • Desoldering braid or solder sucker
  • Isopropyl alcohol (90%+) and brushes for cleaning
  • Multimeter for verification
  • Tweezers (anti-static)
  • Magnification (loupe or stereo microscope recommended for SMD components)
General Procedure
  1. Photograph the board before starting โ€” note the orientation and polarity markings of all capacitors
  2. Verify polarity โ€” electrolytic capacitors are polarised. The negative terminal is typically marked with a stripe on the capacitor body. On the PCB, look for + markings or filled/open pad indicators
  3. Apply flux to the capacitor pads
  4. For SMD electrolytics: heat one pad while gently levering the old capacitor away, then clean both pads with desoldering braid
  5. For through-hole components (C7 supercapacitor): desolder both leads, clear the through-holes with desoldering braid or a solder sucker
  6. Clean the pads with IPA
  7. Place the new capacitor, verify polarity, and solder in place
  8. Clean the area with IPA to remove flux residue
  9. Inspect under magnification for solder bridges or cold joints
Replacement Component Specifications
When sourcing replacement capacitors:
  • Match or exceed the original voltage rating โ€” never use a lower voltage rating
  • Match the capacitance value โ€” higher capacitance is generally acceptable for filter caps but stay within ยฑ20%
  • Use low-ESR electrolytic capacitors where possible โ€” modern low-ESR aluminium or solid polymer capacitors will outperform the originals
  • For the supercapacitor (C7): Use a 0.47F 5.5V supercapacitor. This is available from major electronics distributors (e.g., Panasonic, KEMET). Ensure the physical size fits the board footprint
  • SMD capacitors should match the original footprint size โ€” most are 1206 or slightly larger packages
LCD Bias Voltage Modification
A known community modification addresses the low battery warning timing. This involves replacing two SMT capacitors in the voltage detection circuit to extend the warning period from the stock 10โ€“15 minutes to approximately 48+ hours. This modification was documented by Best Electronics and involves:
  • Replacing two capacitors in the battery voltage monitoring circuit with higher values
  • The exact values depend on the specific board revision
  • This modification is often combined with a crystal replacement to adjust clock speed
Consult the Atari Portfolio Technical Reference Guide and community resources for board-revision-specific modification details.
Post-Replacement Testing
After replacing capacitors:
  1. Reassemble and insert fresh batteries
  2. Verify the unit powers on and displays the DIP DOS prompt
  3. Check LCD contrast range โ€” adjust the contrast potentiometer and verify full range of adjustment
  4. Test the memory backup: save a file to C:, remove batteries, wait 30 seconds, reinsert batteries โ€” the file should still be present (verifying C7 supercapacitor function)
  5. If using expansion modules, verify they are detected
  6. Run the built-in applications (editor, spreadsheet, calculator) to verify stable operation
