Atari Portfolio General Maintenance
This page covers general maintenance procedures for the Atari Portfolio palmtop computer. Regular maintenance helps preserve this vintage palmtop and prevent common age-related failures.
Battery Care
editThe Atari Portfolio is powered by three AA alkaline batteries which provide approximately 100 hours of use under normal conditions.
Battery Installation and Handling
edit- The battery compartment is located on the underside of the unit, secured by a sliding cover
- Insert three AA batteries observing correct polarity as marked inside the compartment
- Always use high-quality alkaline batteries — avoid cheap zinc-carbon cells which may leak more readily
- Remove batteries if the unit will be stored for more than a few weeks to prevent leakage
- The Portfolio's internal memory (C: drive contents) is preserved during battery changes thanks to a small internal backup capacitor that maintains RAM for approximately 1–2 minutes — change batteries promptly and do not leave the compartment empty
Rechargeable Batteries
editNiCd and NiMH rechargeable batteries can be used, but with important caveats:
- Rechargeable cells have a steeper voltage drop-off curve than alkaline batteries
- The Portfolio's low battery warning may not trigger in time before power loss
- Keep all important data on memory cards rather than the internal C: drive when using rechargeables
- NiMH cells provide 1.2V nominal versus 1.5V for alkaline — the Portfolio will still function but may show lower battery life readings
AC Adapter
editFor extended desktop use, the optional AC adapter is recommended:
- HPC-401 — 120V (US)
- HPC-402 — 230V (International)
Always use the AC adapter when using the serial or parallel port — these peripherals draw significant additional current and will drain batteries rapidly.
Battery Leakage Damage
editIf battery leakage has occurred:
- Remove the batteries immediately
- Clean the battery contacts with white vinegar or isopropyl alcohol (IPA) on a cotton swab
- For heavier corrosion, use a fibreglass pen or fine abrasive to restore the contact surfaces
- Inspect the battery compartment wiring — corroded traces or broken wires may need resoldering
- Check that the power ribbon cable connecting the battery compartment PCB to the main board has not been damaged by leakage migrating along the cable
Memory Card Maintenance
editThe Portfolio uses Mitsubishi Bee Card format memory cards with battery-backed RAM.
Memory Card Battery Replacement
edit- RAM cards contain a small coin-cell battery (typically CR2016 or CR2025) that maintains stored data
- This battery lasts approximately one to two years
- Write the replacement date on the card or set a diary alarm as a reminder
- To replace the card battery without losing data:
- Insert the memory card into the Portfolio
- Turn the Portfolio ON
- While the Portfolio is powered on, carefully remove and replace the coin-cell battery in the card
- Do not let the Portfolio auto-sleep (it powers down after ~2 minutes of inactivity) — press a key periodically during the process
- If the card battery dies completely, all data on the card will be lost
Contact Cleaning
editMemory card contacts can develop oxidation over time, leading to read errors or detection failures:
- Clean the card's edge connector contacts with isopropyl alcohol (90%+) on a lint-free cloth
- For stubborn oxidation, use a pencil eraser (white vinyl type) to gently polish the gold contacts, then clean with IPA
- Clean the card slot inside the Portfolio using compressed air to remove dust and debris
- Never use abrasive materials on the card slot contacts
- If cards are intermittently detected, the internal card slot spring contacts may need gentle re-tensioning — this requires disassembly (see Atari Portfolio Troubleshooting Guide)
LCD Maintenance
editThe Portfolio's 240 × 64 pixel supertwist monochrome LCD is generally robust but requires care.
Display Window
editThe LCD is protected by an outer clear/grey plastic window adhered to the inner bezel:
- Clean the outer window with a soft microfibre cloth and mild glass cleaner
- Never use solvents (acetone, thinners) on the plastic window — they will cause hazing or cracking
- If the window is badly scratched, replacement OEM windows are available (e.g., Best Electronics part CB102207). To replace:
- Warm the old window with a hair dryer on medium heat until warm to the touch (not hot enough to deform the plastic bezel)
- Starting from one corner, carefully peel off the old window
- Before applying the new window, adjust the LCD contrast if needed (see below) — you will not want to remove the new window once applied
- Peel the adhesive backing and apply the new window, pressing firmly from centre outward to avoid air bubbles
LCD Contrast Adjustment
edit- There is a small slotted contrast adjustment screw (potentiometer) on the LCD PCB
- On most Portfolios, this screw is accessible through a small hole in the inner plastic bezel (near the speaker on the left side) when the display window is removed
- Some early production units lack this access hole — contrast adjustment requires partial disassembly
- Use a small flathead screwdriver to adjust: turning clockwise typically darkens both text and background; find the balance that provides clear text against a light background
- Make contrast adjustments before applying a new display window
LCD Line Dropout
editMissing horizontal lines on the display are a known issue caused by poor contact between the LCD glass and the driver board flex connector. Repair requires disassembly — see the Atari Portfolio Troubleshooting Guide for detailed procedures.
Keyboard Maintenance
editGeneral Cleaning
edit- Power off the Portfolio and remove batteries before cleaning
- Use compressed air to blow debris from between the keys
- Clean key surfaces with a cloth lightly dampened with isopropyl alcohol
- For deeper cleaning, the keyboard membrane/mylar layer can be accessed after disassembly — clean with IPA and allow to dry completely before reassembly
Keyboard Mylar Membrane
editThe Portfolio uses a mylar membrane layer between the key caps and the PCB contact points:
- Over time, the conductive traces on the mylar can develop cracks or wear
- Symptoms include non-responsive keys or keys that register intermittently
- Replacement mylar membranes are available from specialist suppliers
- When disassembling, photograph the cable routing before removing anything — the flat cables connecting the keyboard to the main board are routed in specific directions
Hinge and Case Maintenance
editHinge Cover Cracking
editThe most common physical failure on ageing Portfolios is cracking of the plastic hinge covers. When the hinge covers break:
- The LCD half may no longer hold its position and will either slowly close on its own or flop flat
- The hinge mechanism uses small roll pins — these can be removed for repair but require great care not to damage
- Replacement inner LCD bezel/hinge covers and outer top case pieces are available from specialist suppliers such as Best Electronics
- When removing roll pins, use an appropriately sized pin punch — do not use pliers which will deform the pins
Case Disassembly Notes
edit- Beneath the display window, there are two small black screws (visible when the window is removed) that secure the top case to the inner bezel
- The metal RF shield is secured with silver screws — mark the orientation of all cables before disconnecting
- The power ribbon cable connecting the lower (keyboard) PCB to the upper (display) PCB is fragile and must not be pulled or stressed — disconnection during disassembly is a common cause of failure
- Plastic clips hold the case halves together — use a thin blade (Swiss army knife or spudger) to release them gently
Storage Recommendations
editFor long-term storage of an Atari Portfolio:
- Remove all batteries (both AA cells and any memory card coin cells if cards are stored separately)
- Store in a cool, dry environment away from direct sunlight
- Keep memory cards in anti-static bags
- Place silica gel packets in the storage container to prevent moisture damage
- Periodically (every 6–12 months) power up the unit to verify functionality
