Atari Portfolio Troubleshooting Guide
Atari Portfolio with a 32 KB Atari memory card
Fault-finding for the Atari Portfolio, from the supply up. The supply lines, power modes and display description come from Atari's Portfolio Technical Reference Guide.[1] Routine care is on Atari Portfolio General Maintenance and the board's capacitors on Atari Portfolio Capacitor Replacement Guide.
How the Portfolio is powered
A switching regulator steps the voltage of three AA cells up to 5 V, and the regulator can be switched off.[2] When cells and an external supply are both connected, the machine runs from whichever is at the higher voltage, which Atari calls the "initial source". Atari defines four power modes: NO POWER (no source connected, as during a cell change, with the system RAM held up by an internal capacitor), OFF (the custom chip and RAM run directly from the initial source), STANDBY (everything on the 5 V regulator with the processor clock stopped while waiting for a key) and RUN.[1]
Supply lines (all are on the expansion connector)
Line Expected Notes
Cells 4.5 V nominal, three AA cells in series Below the logic rail; the regulator steps it up
5VS 5 V in STANDBY and RUN; floats low at any other time Can supply up to 40 mA at 5 V ±5% to a peripheral
VCC Follows 5VS Memory-card supply, separate so that inserting or removing a card does not put spikes on 5VS
VRAM 4.5 V in STANDBY and RUN; initial source minus 0.5 V in OFF; the voltage across a capacitor, decaying, in NO POWER System RAM supply. Take no current from it in NO POWER mode or the RAM can be corrupted
VEXT The external supply voltage, straight from the jack socket The adaptor is 6 V DC, 300 mA, centre positive[3]
BATD Normally carries the initial source; pulled to ground when the cells are removed Isolates the system RAM from the rest of the circuit
Source for the table, except where marked: Atari, section 2.5.[1] Atari's guide gives no LCD bias voltage.
Power faults
The machine will not start
Symptom Likely cause Action
Nothing at all Flat cells, or corroded contacts Fit fresh alkaline cells. Clean the contacts and look for corrosion on the small power board and its white ribbon cable[4]
Nothing on the adaptor, works on cells Faulty adaptor or jack Measure the adaptor's output and check that it is centre positive.[3] Then check the jack on the power board[4]
Nothing on cells, works on the adaptor Cell contacts, power-board wiring or the step-up regulator Check the cells under load and the contacts before suspecting the regulator
Dead after the case has been opened Display ribbon or keyboard ribbon not seated in its connector Reopen and reseat both. The display ribbon locks into a brown connector with a sliding part[5]
With the machine switched on, 5VS should be at 5 V. If it is and the screen is blank, look at the display and its ribbon before the supply.[1]
Best Electronics sells a set of three dummy AA cells, one with leads (CB102638), which it says was designed for Atari's service centres to run a Portfolio from an external 4.5 V DC supply through the battery compartment for burn-in and current tests.[4] A bench supply set to 4.5 V with a current limit, wired the same way, shows whether a dead machine draws current at all.
Low battery behaviour
The Portfolio checks the cells during disk access, tone generation, the timer tick and every press of the Return key. If they are low it shows a low battery message and powers down, and it shows the same message at the next power-up to say why it shut down. Software can stop that power-down through Int 61h function 26h; Atari says this must only be used if absolutely necessary, because it may run the machine outside its electrical specification and damage it.[6]
With rechargeable cells the voltage falls so steeply at the end of discharge that the warning may not appear in time.[7]
Display faults
Blank or unreadable display
Blank, key clicks audible Contrast set too light Contrast is a software setting held in a control register.[8] Adjust it from the keyboard first. Most machines also have a contrast trimmer on the LCD board, reached through a hole at the left of the inner bezel once the window is off[4]
Blank, no key clicks Power See the power section above
Missing horizontal rows, or bands Poor connection between the LCD glass and its driver board, or a cracked display ribbon See below
Missing rows
Lewin Edwards described missing LCD lines as one of the most annoying Portfolio faults to fix, caused by a bad connection between the LCD and its driver board. His method, as quoted on Applefritter:[9]
  1. Prise the window (faceplate) off the display half to reveal two screws, and remove them. Best Electronics recommends warming the window with a hair dryer first.[4]
  2. Ease the display case apart. It is held by plastic clips.
  3. Unscrew the LCD controller board.
  4. Bend open the metal retaining tabs that hold the LCD to the driver board and separate them.
  5. Clean and reseat the connection, then close the tabs.
The tabs work-harden: they survive being bent only a couple of times before they break off.[9]
The flat ribbon between the main board and the display half, which also carries the speaker, can crack. One repairer found it cracked on a machine that had also suffered battery leakage and fitted the display from a donor machine instead of bridging the broken tracks.[10]
Memory and storage faults
Drive C: loses its contents
While the cells are out the internal RAM is held up by a capacitor, and the voltage on VRAM decays.[1] Atari gives neither a hold time nor a value for the capacitor.
  • Contents that survive a quick cell change but not a long one are normal.
  • Contents lost at once on a cell change point at the hold-up circuit. Measure VRAM with the cells fitted (4.5 V in STANDBY and RUN) before replacing anything.[1]
  • A crash also loses everything on C:. The 1992 FAQ suggests setting C: to about 8 KB with FDISK and keeping files on memory cards, which leaves about 100 KB for applications.[7]
Memory Expander not recognised
The 256 KB Memory Expander plugs onto the 60-pin expansion connector, has a pass-through connector for a second expander or an interface, and adds a card drive B:. Installing or removing one needs a cold boot, which erases the Portfolio's memory, so back everything up first.[4] Check that it is fully seated and clean the contacts on both connectors.
Memory card faults
Memory card problems
Card not readable Card not fully home, dirty contacts, or a flat cell in the card Reseat the card; clean its contacts with isopropyl alcohol; replace the card's cell
Contents lost whenever the card is removed Flat cell in the card Each Atari RAM card has its own lithium cell, which Atari says keeps the data "for a year or more" out of the machine.[11] The cell is a CR2016[4]
Card from another palmtop not recognised Not compatible Atari warns that similar cards from other makers may damage both the card and the Portfolio;[11] the FAQ names HP, Poqet and Sharp PC-3000 cards[7]
To change a card cell without losing data, insert the card, switch the Portfolio on so that it powers the card through the slot, change the cell, and press a key every so often so that the machine does not power down part-way through.[7] Atari puts the keyboard time-out at 128 to 256 seconds.[6]
Interface faults
Smart Parallel Interface (HPC-101)
  • File transfer to a PC uses the FT program supplied with the interface and a male-to-male DB25 cable with all lines straight through; Atari's cable is the HPC-406.[7] A printer needs a DB25 to Centronics cable instead.[4]
  • The transfer protocol times out after 500 ms with no answer. On a failure each end waits 500 ms, so that the other end times out too, and retries the block. Every block carries a checksum.[12]
  • The interfaces draw about as much power as the Portfolio. Run from the adaptor.[7]
Serial Interface (HPC-102)
  • The interface has a 9-pin D plug with the PC/AT pin-out, so the cable needs a female DB9 at the Portfolio end.[13][7] Atari's null-modem cable for the ST and other machines is the HPC-409 (female DB9 to female DB25) and its Macintosh cable the HPC-407.[7]
  • The UART is an 82C50A with the same registers as the PC/AT, but the Portfolio has no 8259 interrupt controller. The interrupt number for the serial port is written to the Serial Interrupt Vector Register (SIVR) at I/O address 807Fh, which is write-only and must be set before the 82C50A's interrupts are enabled.[13] Ordinary PC communication programs do not work for this reason, and the Portfolio has no terminal program built in; one has to be loaded first.[7]
  • A terminal program that waits for a key with Int 16h service 00h lets the Portfolio power down mid-session. Atari recommends polling with service 01h.[13]
Resets
The FAQ lists three, in order of severity:[7]
  1. Ctrl+Alt+Del.
  2. The reset switch in the hole on the underside above the Atari label, pressed with a straightened paper clip.
  3. The cold reset: the small metal tab under the battery cover. It returns the machine to its factory state, asks for the language again and erases drive C:. It works by pulling VRAM to ground through a small resistor.[1]
FDISK, which repartitions the internal RAM, also erases drive C:.[7]
Things that are not faults
  • The screen flashes while the machine is off. It wakes about every two minutes to check the diary alarms.[7]
  • The machine switches itself off after two to four minutes without a key press.[6]
  • A low battery message at power-up explains why it shut down last time.[6]
  • Some PC software does not run. Programs that address the hardware directly fail because the Portfolio's I/O addresses differ, it has no interrupt controller or dedicated keyboard controller, and its timer tick is different; Atari names BASIC, XTALK and Sidekick.[14]
Diagnostic board
Atari produced an expansion-port diagnostic board with its own diagnostic ROM and 16 status LEDs. Its menus test the CPU board (system, video RAM, RAM disk, memory card, keyboard lines), the LCD board (checkerboard, rectangle, all pixels, all characters, contrast, speaker) and the keyboard, and an LED mode tests a machine whose screen does not work. Best Electronics, which sells the board, says it was never issued to Atari service centres.[4]
Common failure points
  • Cracked hinge covers. Best Electronics calls this the most common failure on old machines; the display then closes by itself or falls flat.[4]
  • Missing LCD rows from the glass-to-driver connection.[9]
  • A cracked display ribbon.[10]
  • Corrosion from leaked cells, on the contacts and, in one repairer's machine, on the keyboard circuit.[10]
  1. ↑ 1.0 1.1 1.2 1.3 1.4 1.5 1.6 1.7 Atari Corporation, Atari Portfolio Technical Reference Guide, first edition, September 1989 (copyright Distributed Information Processing Ltd.), section 2.5, "Power Supply Unit", pp. 2-9 to 2-10. Hosted here: File:Atari Portfolio Technical Reference Guide.pdf.
  2. ↑ Atari Corporation, Atari Portfolio Technical Reference Guide, first edition, September 1989, section 2.1.10, "Power Supply Unit", p. 2-3. Hosted here: File:Atari Portfolio Technical Reference Guide.pdf.
  3. ↑ 3.0 3.1 "Atari Portfolio / Atari PC Folio / DIP Pocket PC", atari-computermuseum.de, https://www.atari-computermuseum.de/hpc004.htm (retrieved 2026-10-01). Source for the adaptor rating and polarity.
  4. ↑ 4.00 4.01 4.02 4.03 4.04 4.05 4.06 4.07 4.08 4.09 "Portfolio", Best Electronics, https://www.best-electronics-ca.com/portfoli.htm (retrieved 2026-10-01). Atari parts dealer's catalogue page; source for the power board, the diagnostic board, the dummy battery set, the Memory Expander notes, the hinge-cover failure and the contrast screw.
  5. ↑ cosi, "The incomplete Atari Portfolio disassembly guide", Vintage Palmtops, 28 September 2013, http://palmtop.cosi.com.pl/2013/09/28/atari-portfolio-disassembly-guide/ (retrieved 2026-10-01).
  6. ↑ 6.0 6.1 6.2 6.3 Atari Corporation, Atari Portfolio Technical Reference Guide, first edition, September 1989, section 3.8, "Power Management", pp. 3-31 to 3-32. Hosted here: File:Atari Portfolio Technical Reference Guide.pdf.
  7. ↑ 7.00 7.01 7.02 7.03 7.04 7.05 7.06 7.07 7.08 7.09 7.10 7.11 BJ Gleason, Portfolio Frequently Asked Questions (PORT.FAQ), edition of 26 February 1992, questions 2, 3, 6–10, 15, 41 and 42, blinkenlights.com (retrieved 2026-10-01).
  8. ↑ Atari Corporation, Atari Portfolio Technical Reference Guide, first edition, September 1989, sections 2.4.5, "Soft Contrast for LCD", p. 2-8, and 2.8, "LCD Display", p. 2-21. Hosted here: File:Atari Portfolio Technical Reference Guide.pdf.
  9. ↑ 9.0 9.1 9.2 Thread "Atari Portfolio", Applefritter forums, posts of 1–16 August 2006, quoting Lewin Edwards' Portfolio repair notes, https://www.applefritter.com/node/18858 (retrieved 2026-10-01).
  10. ↑ 10.0 10.1 10.2 Arnaud, "Complete Atari Portfolio disassembling and repairing", Consulting Daylights, 23 April 2019, https://consultingdaylights.wordpress.com/2019/04/23/complete-atari-portfolio-disassembling-and-repairing/ (retrieved 2026-10-01).
  11. ↑ 11.0 11.1 Atari Corporation, Atari Portfolio Technical Reference Guide, first edition, September 1989, section 2.3, "Memory Cards", pp. 2-6 to 2-7. Hosted here: File:Atari Portfolio Technical Reference Guide.pdf.
  12. ↑ Atari Corporation, Atari Portfolio Technical Reference Guide, first edition, September 1989, section 4.2, "Smart Parallel Interface", p. 4-3. Hosted here: File:Atari Portfolio Technical Reference Guide.pdf.
  13. ↑ 13.0 13.1 13.2 Atari Corporation, Atari Portfolio Technical Reference Guide, first edition, September 1989, section 4.1, "Portfolio Serial Communications", pp. 4-1 to 4-2. Hosted here: File:Atari Portfolio Technical Reference Guide.pdf.
  14. ↑ Atari Corporation, Atari Portfolio Technical Reference Guide, first edition, September 1989, section 3.1.3, "Troubleshooting", p. 3-3. Hosted here: File:Atari Portfolio Technical Reference Guide.pdf.
