Atari PC3
Atari PC3
Atari PC3 system unit and keyboard
ManufacturerAtari Corporation (Atari Taiwan Manufacturing)
TypeIBM PC compatible (XT class)
ReleasedShown 2 November 1987 (Fall COMDEX); on sale in Western Europe from summer 1988[1]
Discontinued1990[1]
Intro pricePC3-DD with PCM124 £649.99, PC3-HD with PCM124 £949.99 (November 1988); £599.99 and £799.99 (May 1989)[1]
CPUIntel 8088-2 at 4.77 MHz or 8 MHz, switched from the keyboard or by software
Memory512 KB in Atari's 1988 manual, 640 KB with four extra DRAMs; 32 KB ROM
StoragePC3-DD one 5.25-inch 360 KB drive; PC3-HD the same and a Seagate ST238R 30 MB RLL hard disk
Display—
SoundPC speaker
GraphicsOnboard EGA, CGA, MDA and Hercules; 256 KB video RAM
FPU / coprocessorSocket for an Intel 8087, 8087-2 or 8087-1
Ports / interfaceKeyboard (5-pin DIN), Atari mouse (9-pin D), serial (25-pin D), parallel (25-pin D), digital monitor (9-pin D), external floppy (14-pin DIN), IEC C14 mains inlet and IEC C13 monitor outlet
ExpansionFive XT (8-bit ISA) slots on the main board
PowerInternal 130 W supply; 200 W maximum consumption[2]
Dimensions152 × 381 × 413 mm (H × W × D)[2]
Weight10.5 kg[1]
OS / FirmwareMS-DOS 3.2 with GW-BASIC and GEM Desktop, Write and Paint
PredecessorAtari PC2
SuccessorAtari PC4
The Atari PC3 is an XT-class PC compatible with five expansion slots on its main board. It was shown at the Fall COMDEX on 2 November 1987, sold in Western Europe from the summer of 1988 and built until 1990. atari-computermuseum.de describes it as the best-selling of Atari's desktop PCs.[1]
Its case was new with this model and was reused for the PC4 and PC5 and for the developer version of the ATW800 transputer machine. Early units have a dark grey plinth, later ones a lighter one.[1]
Atari PC3 specifications (Atari)[2]
Item Specification
Processor 8088; 4.77 MHz PC mode or 8.0 MHz turbo mode, switched from the keyboard or by software
Memory 512 KB standard; 640 KB with four extra 64K × 4 DRAMs (41464-15, 41464-12 or equivalent); 32 KB ROM
Power 130 W internal supply; 200 W maximum consumption
Expansion Five vertical XT-type slots; socket for an 8087 (5 MHz), 8087-2 (8 MHz) or 8087-1 (10 MHz)
Interfaces XT keyboard, quadrature mouse port, video monitor, RS-232C serial, parallel printer, floppy disk port, two internal drive connectors
Video EGA 640 × 350 in 16 of 64 colours; CGA; MDA; Hercules 720 × 348
Floppy drive 5.25-inch, 40 tracks, 360 KB, 300 rpm; controller supports two internal and two external drives
Dimensions 15.2 cm high, 38.1 cm wide, 41.3 cm deep
atari-computermuseum.de gives 640 KB as fitted and 256 KB of video RAM.[1]
Board revisions recorded by ataripc.net are C100812 Rev B and Rev B1 (1988), and C103272 with no revision letter and Rev B (1989). The later boards use an STMicroelectronics EGA device in place of the NSI Logic EVC315-S.[3]
The five XT slots are on the main board itself, not on a riser as in the PC2. A factory hard disk was normally a Seagate ST238R 30 MB RLL drive.[1]
The back panel carries an IEC C14 mains inlet and an IEC C13 outlet for the monitor. The monitor connector is a 9-pin D for digital CGA, EGA and MDA monitors; there is no analogue VGA output. The mouse port is a 9-pin male D without screw locks, for an Atari mouse.[1]
Speed, memory and coprocessor
The PC3 starts in turbo mode, shown by the "CPU" light on the front, unless an 8087 is fitted. Ctrl+Alt+keypad + selects turbo mode and Ctrl+Alt+keypad − returns to 4.77 MHz. A 5 MHz 8087 cannot run in turbo mode.[4] Extra memory is four 64K × 4 DRAMs rated 150 ns or faster, labelled 41464-15 or 41464-12.[5]
Monitor switches
The "Config" switches on the back panel are numbered 4, 3, 2, 1 from left to right, and on them up is on and down is off. With SMART on, an Atari EGA monitor can also be used in the MDA and Hercules modes; SMART must be off if a separate monochrome display adapter is fitted in a slot.[6]
PC3 monitor switches[6]
Monitor Switch 4 Switch 3 Switch 2 Switch 1
EGA, SMART on Off On Off Off
EGA, SMART off Off On On Off
Colour On Off Off On
Monochrome On Off On On
Real-time clock
The PC3 has a battery-backed real-time clock. Its lithium battery pack is held on a Velcro strip inside the case and connected by a wire; to replace it, remove the cover, disconnect the wire, and fit a new pack of the same type on the strip. A "CMOS RAM Error" message at start-up means the pack needs replacing, or that a newly fitted pack has not yet been recognised; press F1 to continue. A "Real-Time Clock Error" means the clock needs setting again with Atari's RTC utility.[7] See Battery Refurbishment.
Faults and diagnostics
Beep codes[7]
Beeps Problem area
One short beep Normal
No beep, continuous beep, or short repeating beeps Power supply
One long and one short beep System board
One long and two short beeps Monitor cable, display or video circuit
One short beep, drive light stays on Disk drive or floppy controller
The error-code ranges are the same as on the PC1, with 401–432 described as the monochrome video subsystem, 601–626 as the floppy drive or controller, and the 1400 series as printers.[7]
The supply is mains-powered and also feeds the monitor outlet.
  • Atari Atari PC3 Owner's Manual (1988): setting up, monitor switches, system speed, the clock and its battery, beep and error codes, fitting memory, the 8087, expansion cards and drives, preparing a hard disk, specifications and pinouts. It has no schematic or parts list.
  1. ↑ 1.0 1.1 1.2 1.3 1.4 1.5 1.6 1.7 1.8 "Atari PC3", atari-computermuseum.de, revised 14 July 2024, https://www.atari-computermuseum.de/pc3.htm. Secondary source for the show and release dates, the end of production, the best-selling description, the case and plinth colours, the slots, the 640 KB and 256 KB video RAM figures, the Seagate ST238R, the port list, the weight and the UK prices.
  2. ↑ 2.0 2.1 2.2 Atari Corporation, Atari PC3 Owner's Manual, 1988, appendix F, "Atari PC3 specifications", pp. 93–95. Hosted as File:Atari PC3 Owner's Manual (1988).pdf.
  3. ↑ "Atari PC3 8088" and its motherboard pages, ataripc.net, https://www.ataripc.net/pc3-8088/. Secondary source for the board numbers and revisions and the later EGA device.
  4. ↑ Atari Corporation, Atari PC3 Owner's Manual, 1988, chapter 2: key functions and "Changing system speed", pp. 14 and 30. Hosted as File:Atari PC3 Owner's Manual (1988).pdf.
  5. ↑ Atari Corporation, Atari PC3 Owner's Manual, 1988, appendix B, "Installing extra RAM and the numeric data processor", p. 65 onwards. Hosted as File:Atari PC3 Owner's Manual (1988).pdf.
  6. ↑ 6.0 6.1 Atari Corporation, Atari PC3 Owner's Manual, 1988, chapter 1, "Setting up", pp. 8–9, and the monitor display mode commands, pp. 52–53. Hosted as File:Atari PC3 Owner's Manual (1988).pdf.
  7. ↑ 7.0 7.1 7.2 Atari Corporation, Atari PC3 Owner's Manual, 1988, "Setting the real-time clock", p. 29, and appendix A, "System maintenance", pp. 61–63. Hosted as File:Atari PC3 Owner's Manual (1988).pdf.
