Macintosh 512K
| File:Macintosh512K.jpg | |
| Type | Personal Computer |
| Release Date | September 10, 1984 |
| Discontinued | April 14, 1986 |
| Introductory Price | US$3,195 |
| CPU | Motorola 68000 @ 7.83 MHz |
| Memory | 512 KB RAM (not expandable) |
| Storage | 400 KB 3.5" floppy drive |
| Display | 9" monochrome CRT (512ร342 pixels) |
| Sound | Monaural 8-bit, 22 kHz (4-voice) |
| Dimensions | 13.6" H ร 9.6" W ร 10.9" D |
| Weight | 16.5 lbs (7.5 kg) |
| OS | System 1.0 โ System 4.1 |
| Predecessor | Macintosh 128K |
| Successor | Macintosh Plus |
| Codename | Engine, Hero |
| Model | M0001W |
Historical Background
The Macintosh 512K, released on **September 10, 1984**, was an improved version of the Macintosh 128K. It featured **four times the RAM (512 KB)**, allowing for improved multitasking and compatibility with a wider range of software. It retained the same **Motorola 68000 processor running at 7.83 MHz** and the **9-inch monochrome display** with a **400 KB floppy disk drive**.
Due to its increased memory, the Macintosh 512K could run more advanced applications, including **MacDraw**, **MacProject**, and **Microsoft Multiplan**. However, it still lacked built-in support for an internal hard drive, relying on external floppy drives for additional storage. The 512K model was succeeded by the Macintosh Plus, which introduced **expandable RAM and an external SCSI port**.
For detailed general maintenance practices including cleaning, PRAM battery handling, connector corrosion prevention, and voltage adjustments, please see the dedicated Macintosh 512K General Maintenance page.
The Macintosh 512K features two primary PCBs: the **Logic Board** and **Analog Board**. Below are the detailed schematics and the official Apple service manual.
Apple Service Manual
| Logic Board | Analog Board |
Detailed capacitor replacement guidelines for both analog and logic boards can be found on the Macintosh 512K Capacitor Replacement Guide page.
Retrobrite
A comprehensive troubleshooting guide addressing no power, chime but no video, intermittent operation, Sad Mac errors, and floppy drive problems is available on the Macintosh 512K Troubleshooting page.
