Amstrad CPC 664 Capacitor Replacement Guide
Revision as of 22:36, 21 September 2026 by Josh (talk | contribs) (Remove the correction notice section)
Capacitor replacement for the Amstrad CPC 664.
Every value on this page is taken from Amstrad's own Electrical Parts List for the CPC664 in the service manual hosted on this wiki.[1]
⚠️ Safety
The computer runs from a low-voltage supply, but the CTM644 colour monitor and GT65 green monitor contain a CRT and mains-derived high voltage that persists after switch-off. See CRT Discharge Procedure before opening either. This page covers the computer.
Electrolytic capacitors
CPC664 electrolytic capacitors[1]
Value Circuit reference Amstrad part no.
100 µF / 16 V C315 20028
100 µF / 10 V C301, C304 20028
47 µF / 10 V C129, C303, C306 1400244
22 µF / 10 V C308 20025
1 µF / 50 V C309, C311, C314, C316, C317 20062
Eleven electrolytics across five values — a smaller complement than the 464's thirteen.
Ceramic capacitors
CPC664 ceramic capacitors[1]
0.1 µF / 16 V C101–C128, C201–C213 24020
470 pF / 50 V C307 24004
270 pF / 50 V C313 900400
220 pF / 50 V C133–C135, C310 400107
68 pF / 50 V C130, C131 170826
47 pF / 50 V C132 24002
Note the C201–C213 block — those are on the disk interface section, which the 464 does not have.[1]
Polystyrene capacitors
CPC664 polystyrene capacitors[1]
0.1 µF C319 170852
0.068 µF C302 170219
0.047 µF C318 1409178
0.01 µF C305 170218
0.001 µF C312 170217
Polystyrene capacitors deform at soldering temperatures that an electrolytic shrugs off. Work quickly and keep the iron off the body.
A note from Amstrad on the disk PCB
The parts list carries an explicit instruction: no part numbers are given for any parts on that PCB, and Amstrad directed service agents to return the board complete for replacement rather than repair it to component level.[1] That is Amstrad's position in period, not a statement that the board is unrepairable today — but it does mean this manual will not give you component values for the disk PCB.
Before you start
  1. ↑ 1.0 1.1 1.2 1.3 1.4 1.5 Amstrad Consumer Electronics plc, CPC664 Service Manual, "Electrical Parts List CPC664", hosted at Amstrad CPC 664 Service Manual. Gives value, circuit reference and Amstrad part number for every capacitor, resistor and IC on the CPC664.
