Macintosh SE/30 Capacitor Replacement Guide
Replacing electrolytic capacitors (recapping) in your Macintosh SE/30 is essential for restoring power stability, ensuring clean video output, and preventing long-term damage due to capacitor leakage. This guide outlines the recommended procedure and provides complete analog and logic board capacitor specifications.
Capacitor Inspection
- Bulging Tops – Swollen or domed caps indicate internal gas buildup.
- Electrolyte Leakage – Brown/white crust or residue near leads shows capacitor failure.
- Corroded Pads or Traces – PCB staining or corrosion suggests leakage damage.
Macintosh SE/30 Capacitor List
Analog Board Capacitors
The SE/30 analog board is nearly identical to that of the Macintosh SE and Plus, and shares the same capacitor layout:
| C1 | 3.9µF | 35V | 1x |
| C2 | 4700µF | 16V | 1x |
| C3 | 220µF | 16V | 2x |
| C5 | 47µF | 10V | 1x |
| C6 | 22µF | 50V | 2x |
| C10 | 33µF | 16V | 2x |
| C11 | 10µF | 160V | 1x |
| C12 | 22µF | 50V | 2x |
| C18 | 33µF | 16V | 2x |
| C24 | 2200µF | 16V | 4x |
| C27 | 2200µF | 16V | 1x |
| C28 | 1000µF | 16V | 1x |
| C30 | 2200µF | 16V | 1x |
| C31 | 220µF | 16V | 1x |
| C32 | 2200µF | 16V | 1x |
| C33 | 4700pF | 250V | 2x |
| C34 | 100µF | 200V | 4x |
| C35 | 100µF | 200V | 1x |
| C36 | 4700pF | 250V | 1x |
| C37 | 0.47µF | 250V | 1x |
| C38 | 100µF | 200V | 1x |
| C39 | 100µF | 200V | 1x |
| C42 | 470µF | 10V | 2x |
| C45 | 470µF | 10V | 1x |
Logic Board Capacitors
The SE/30 logic board is particularly prone to capacitor failure and corrosion, making recapping especially important.
| C1 – C10 | 47µF | 16V | 10x |
| C11 | 1µF | 50V | 1x |
- Discharge the CRT – Follow standard CRT discharge procedures before working inside.
- Remove the Logic & Analog Boards – Label cables and safely extract both boards.
- Desolder Old Capacitors – Use a quality soldering iron, braid, or pump to remove components cleanly.
- Install New Capacitors – Insert with correct polarity (check for stripe on negative side).
- Solder Carefully – Ensure clean, shiny joints without cold solder bridges.
- Trim Leads & Inspect Work – Cut excess and examine under light or magnification.
- Test for Shorts – Use a multimeter to confirm there are no shorts across power rails.
Recommended Tools
- Desoldering braid or vacuum pump
- Quality leaded solder (0.5 mm recommended)
- Isopropyl alcohol and ESD brush
- Multimeter
- Safety goggles and insulated gloves
Voltage Adjustment After Recap
- +5V rail: 4.85V – 5.15V
- +12V rail: 11.9V – 12.7V
Use the analog board's trimmer potentiometer (R56) to fine-tune if necessary.
Tips for Best Results
- Always recap the logic board first – leaking caps often cause corrosion damage.
- Use quality capacitors (e.g., Nichicon, Panasonic, Rubycon).
- Turn on the system periodically to prolong capacitor lifespan.
- Replace in full sets for even aging and reliability.
- Clean the board thoroughly with isopropyl alcohol after removal.
