Macintosh Classic II
Revision as of 21:02, 7 April 2025 by Josh (talk | contribs)
TypePersonal Computer
ReleasedOctober 21, 1991
DiscontinuedSeptember 13, 1993
Intro priceUS$1,900
CPUMotorola 68030 @ 16 MHz
Memory2 MB RAM (expandable to 10 MB)
Storage1.44 MB 3.5" floppy drive, optional 40–80 MB SCSI hard drive
Display9" monochrome CRT (512×342 pixels)
SoundMonaural 8-bit, 22 kHz
Dimensions13.2" H × 9.6" W × 10.9" D
Weight16.5 lbs (7.5 kg)
OS / FirmwareSystem 6.0.8L – System 7.6.1
PredecessorMacintosh Classic
SuccessorMacintosh Color Classic
CodenamePerforma, Stardust, Apollo
Model no.M0420, M4150
The Macintosh Classic II, released in 1991, was the final compact black-and-white Macintosh to use the classic all-in-one design. Unlike its predecessor, it utilized the more advanced Motorola 68030 processor—similar to the SE/30—but without the PDS expansion slot or 32-bit clean ROM. It came with 2 MB of RAM standard and supported up to 10 MB via a single 100 ns 30-pin SIMM. The Classic II retained the 9-inch monochrome display, making it ideal for schools and business use, but with improved performance and more modern architecture.
Due to the similarities witth the Macintosh Classic, for details on disassembly, cleaning, voltage regulation, PRAM battery handling, and corrosion prevention, refer to the Macintosh Classic / Classic II General Maintenance page.
The Classic II consists of a logic board and analog board, similar in layout to the Macintosh SE/30 but with different ICs and no expansion slot. The analog board for the Classic II is identical to the Macintosh Classic. However, the logic board has some improvements over its predecessor.
Apple Service Manual
The complete Apple Service Manual archive is available at the Apple Service Manuals page. For the Classic II, you can download the service guide here: File:Macintosh Classic - Classic II.pdf
Macintosh Classic II PCB Schematics
Logic Board Analog Board
Macintosh Classic II Logic Board
File:Macintosh Classic II Schematic.pdf
Macintosh Classic Analog Board
File:Classic Analog Board Schematic.pdf
The Classic II is prone to logic board failure due to surface-mount capacitor leakage. For safe replacement procedures, refer to the Macintosh Classic II Capacitor Replacement Guide.
Retrobrite
For plastic restoration and case whitening instructions, visit the Retrobrite page.
A complete guide to common issues including no chime, no video, checkerboard pattern, logic board failure, and hard drive detection issues is available at the Macintosh Classic / Classic II Troubleshooting page.
