SuperCPU and Turbo Accelerators
Revision as of 16:25, 24 April 2025 by Josh (talk | contribs) (Created page with "{{Infobox hardware | name = SuperCPU & Turbo Accelerators for the Commodore 64/128 | image = 250px | caption = The '''Creative Micro Designs SuperCPU v2''' with optional 16 MB SuperRAMCard | type = External plug-in accelerators (cartridge port) | designer = See individual entries (CMD, Schnedler Systems, Eberhard Poensgen, Individual Computers…) | manufacturer = Multiple (1990-present) | first_rele...")
Caption The Creative Micro Designs SuperCPU v2 with optional 16 MB SuperRAMCard
Type External plug-in accelerators (cartridge port)
Designer See individual entries (CMD, Schnedler Systems, Eberhard Poensgen, Individual Computers…)
Manufacturer Multiple (1990-present)
First released 1990 (Turbo Master CPU) – 2010 s (FPGA-based solutions)
Latest revision
Operating voltage 5 V DC from C-64 expansion port
Layers / PCB
Compatibility Commodore 64, 64C, SX-64 and (in most cases) Commodore 128 (in C-64 mode)
Features
Model No.
The SuperCPU and other “turbo” accelerators replace, augment or bypass the original 1 MHz 6510 of the Commodore 64/128, giving the 8-bit computer a dramatic speed-up while preserving almost full software compatibility. Approaches range from simple 4 MHz 6502 cards of the early 1990 s to modern FPGA-based cartridges with 48 MHz 65816 cores and cycle-perfect VIC-II synchronisation.
1 📜 Historical overview
Accelerator CPU / Core
(clock)
RAM on card First retail Bus interface Notes
Turbo Master CPU NMOS 6502 @ ≈4 MHz none 1990 Edge connector “Bank-stealing” waits during VIC DMA; requires stub ROM for KERNAL patching.
Flash 8 WDC 65C816 @ 8 MHz none 1993 Edge connector German kit; hardware wait-state generator for VIC access.
SuperCPU v1 / v2 WDC 65C816 @ 20 MHz (switch-able 1×/5×/20×) up to 16 MB (SuperRAMCard) 1996 / 1997 Edge connector pass-through Hitachi HD6120 glue logic (v1) → CMD FPGA (v2); fully transparent timing compensation.
Turbo Process WDC 65C02 @ ≈3.5 MHz none 1996 Internal daughter-board Installation required desoldering the 6510; limited commercial run.
Chameleon 64 (FPGA) 65816-compatible soft-core @ ~48 MHz* 16 MB SDRAM 2011 Docking-station / cartridge Also functions as stand-alone FPGA C-64. *Effective “Turbo” factors ×1…×11 selectable.
Ultimate 64 / U64 Elite FPGA SoC (65816-like) @ 48 MHz 16 MB SDRAM 2018 Replacement main-board Whole-system re-implementation; per-cycle compatible “soft-6510” plus Turbo.
  • Clock figures are the raw CPU frequency; effective speed-up depends on VIC-II DMA stealing and memory-wait strategies.*
2 🛠️ Technical principles
2.1 Bus arbitration
The VIC-II still needs 40 CPU cycles per raster line for video-DMA. Turbo accelerators therefore:
  • Stretch φ2 low-time (Turbo Master/Flash 8) so that fast code runs only when the VIC is idle.
  • Shadow RAM on-board and replay writes to the real C-64 DRAM during idle slots (SuperCPU).
 A fast 16-bit 65816 runs from zero-wait SRAM while the VIC keeps reading the slow motherboard RAM.
2.2 Memory mapping
Most units expose extra RAM through the standard \$FFxx banking lines (EXROM/GAME or REU registers). The SuperCPU’s *SuperRAMCard* appears at \$DF00 and can be logically mapped in 64 KB pages, giving GEOS 2.0 a full 4–16 MB workspace.
2.3 Compatibility layers
  • IO shadowing – writes to \$D000–\$DFFF are mirrored so that timers/sprites still update at 1 MHz cadence.
  • KERNAL patch – accelerators supply a tiny ROM that intercepts IRQ entry/exit to resynchronise with VIC safe-lines (Turbo Master).
  • Turbo OFF switch – most devices fall back to 1 MHz for cycle-exact demos or $DD00 colour‐cycle loading schemes.
3 📊 Benchmarks
Accelerator BASIC “PI Test”
(User port loop-back)
Assembly Dhrystone
(32-bit)
Notes
Seconds (1×) Speed-up DMIPS (1×) Speed-up
Un-accelerated 68 s 1.0× 0.18 1.0× Reference C-64 (1982)
Turbo Master CPU 19 s 3.5× 0.55 3.0× Wait-state hit at badlines
Flash 8 11 s 6.2× 0.95 5.3× Full 8 MHz except colour fetch
SuperCPU @20 MHz 3.4 s 20× 2.9 16× GEOS boots in ≈4 s!
Chameleon ×11 2.9 s 23× 3.2 18× “Cycle exact” turbo
U64 Turbo ×48 1.5 s 45× 5.8 32× RAM in SDRAM, VIC DMA virtualised
(Data averaged from user reports and SysInfo v4.4 runs.) Exact numbers vary with cache settings, memory contention and whether *bad-line* throttling is enabled.
4 💽 Software support
  • GEOS 2.0–2.1 detects the SuperCPU and patches its VBL handler for 20 MHz operation, giving near-instant screen redraw.
  • Turbo Macro Pro and 64tass include “SPDXL” assemblers that emit 65816 op-codes to exploit the 24-bit address space.
  • Games/Demos – few require the accelerator, but *Metal Dust* (2005) famously needs the SuperCPU’s 65816 and 4 MB RAM.
  • CP/M cartridge clones *cannot* coexist with turbo cards – both expect exclusive use of the expansion bus.
5 ⚡ Power & heat considerations
High-speed 65xx CPUs and external SRAM draw up to 800 mA at 5 V. Original Commodore “brick” PSUs are marginal; modern switch-mode supplies or a C64 Saver are strongly recommended. The SuperCPU v1’s CPLD runs hot (≈70 °C) – later v2 fixed this with a cooler FPGA and heat-spreaders.
6 🛒 Availability in 2025
  • Original CMD SuperCPUs are scarce (≈ €800 used).
  • Flash 8 occasionally appears as unpopulated PCBs on German forums.
  • Chameleon 64 V2 is still manufactured by Individual Computers (~€250).
  • Ultimate 64 Elite (replacement main-board with Turbo) ships in small batches several times a year.
7 🔧 DIY and open-source projects
  • SaRuMan 65816 core – open VHDL clone of the SuperCPU memory controller.
  • Pi1541-Turbo – over-clocks the 6510 only during disk-I/O by injecting a 2 MHz clock on φ2.
  • Kola-Max – bread-board prototype using a W65C816 @ 14 MHz plus dual-port SRAM (proof-of-concept, 2023 GitHub release).
