RTC:Article wizard/Referencing
Permanently protected rtc
This page is "edit" protected. The "autoconfirmed" right is required to "edit" this page.<ul class='mw-logevent-loglines'> <li data-mw-logid="6021" data-mw-logaction="protect/protect" class="mw-logline-protect"> <a href="/index.php?title=Special:Log&amp;logid=6021" title="Special:Log">03:48, 5 September 2025</a> <a href="/User:Josh" class="mw-userlink" title="User:Josh"><bdi>Josh</bdi></a> <span class="mw-usertoollinks mw-changeslist-links"><span><a href="/User_talk:Josh" class="mw-usertoollinks-talk" title="User talk:Josh">talk</a></span> <span><a href="/Special:Contributions/Josh" class="mw-usertoollinks-contribs" title="Special:Contributions/Josh">contribs</a></span></span> protected <a href="/RTC:Article_wizard/Referencing" title="RTC:Article wizard/Referencing">RTC:Article wizard/Referencing</a> [Edit=Allow only autoconfirmed users] (indefinite) [Move=Allow only autoconfirmed users] (indefinite) <span class="mw-logevent-actionlink">(<a href="/index.php?title=RTC:Article_wizard/Referencing&amp;action=history&amp;offset=20250905024828" title="RTC:Article wizard/Referencing">hist</a>)</span> <span class="mw-logevent-tool"></span></li> </ul></ul>
This page is "move" protected. The "autoconfirmed" right is required to "move" this page.<ul class='mw-logevent-loglines'> <li data-mw-logid="6021" data-mw-logaction="protect/protect" class="mw-logline-protect"> <a href="/index.php?title=Special:Log&amp;logid=6021" title="Special:Log">03:48, 5 September 2025</a> <a href="/User:Josh" class="mw-userlink" title="User:Josh"><bdi>Josh</bdi></a> <span class="mw-usertoollinks mw-changeslist-links"><span><a href="/User_talk:Josh" class="mw-usertoollinks-talk" title="User talk:Josh">talk</a></span> <span><a href="/Special:Contributions/Josh" class="mw-usertoollinks-contribs" title="Special:Contributions/Josh">contribs</a></span></span> protected <a href="/RTC:Article_wizard/Referencing" title="RTC:Article wizard/Referencing">RTC:Article wizard/Referencing</a> [Edit=Allow only autoconfirmed users] (indefinite) [Move=Allow only autoconfirmed users] (indefinite) <span class="mw-logevent-actionlink">(<a href="/index.php?title=RTC:Article_wizard/Referencing&amp;action=history&amp;offset=20250905024828" title="RTC:Article wizard/Referencing">hist</a>)</span> <span class="mw-logevent-tool"></span></li> </ul></ul>
Revision as of 01:31, 5 September 2025 by Josh (talk | contribs) (Created page with "<noinclude>{{Pp-template}} </noinclude>{{RTC:Article wizard/Content|title=Referencing and notability |content=Your article '''will be declined''' if the topic is not '''notable''', '''violates copyright''', or is not '''referenced properly'''. ;Notability: :The topic of an article must already be covered in '''reliable sources''' that are '''independent''' of the subject. These in...")
RTC Article Wizard
Your article will be declined if the topic is not notable, violates copyright, or is not referenced properly.
Notability
The topic of an article must already be covered in reliable sources that are independent of the subject. These include academic journals, books, newspapers, magazines, and well established websites with a reputation for fact checking. Social media, crowd sourced websites, press releases, database entries, video uploads, or corporate/professional profiles do not qualify.
Copyright
Do not copy-paste or closely paraphrase material from sources. Rather, summarize what the source says in your own words.
Referencing
  • Reliable, independent sources (see above) are preferred over non-independent sources.
  • Non-independent sources (like company websites or press releases) can be used to verify basic facts only.
  • Blogs, social media, and tabloid journalism are generally not acceptable.
To create a reference, use <ref></ref> as follows
Bizco was founded in 1942.<ref>https://www.nytimes.com/bizco</ref>
More details on how to cite different types of materials can be found at our introduction to referencing guide.
