Macintosh Plus Capacitor Replacement Guide
Revision as of 17:47, 4 April 2025 by Josh (talk | contribs)
๐Ÿ” Capacitor Inspection
Before replacing capacitors, inspect each one for signs of deterioration:
  • Bulging Tops โ€“ Capacitors should have a flat top. Swelling or doming indicates failure.
  • Leaking Electrolyte โ€“ A brown or white crust around leads shows electrolyte leakage.
  • Corrosion or PCB Staining โ€“ Indicates internal leakage and should prompt immediate replacement.
๐Ÿ“‹ Macintosh Plus Capacitor List
๐Ÿงฏ Analog Board Capacitors
Macintosh SE Analog Board Capacitors (identical layout to Plus)
The Macintosh Plus analog board contains many large electrolytic capacitors that should be replaced proactively:
Analog Board Capacitor Specifications
C1 3.9ยตF 35V 1x
C2 4700ยตF 16V 1x
C3 220ยตF 16V 2x
C5 47ยตF 10V 1x
C6 22ยตF 50V 2x
C10 33ยตF 16V 2x
C11 10ยตF 160V 1x
C12 22ยตF 50V 2x
C18 33ยตF 16V 2x
C24 2200ยตF 16V 4x
C27 2200ยตF 16V 1x
C28 1000ยตF 16V 1x
C30 2200ยตF 16V 1x
C31 220ยตF 16V 1x
C32 2200ยตF 16V 1x
C33 4700pF 250V 2x
C34 100ยตF 200V 4x
C35 100ยตF 200V 1x
C36 4700pF 250V 1x
C37 0.47ยตF 250V 1x
C38 100ยตF 200V 1x
C39 100ยตF 200V 1x
C42 470ยตF 10V 2x
C45 470ยตF 10V 1x
๐Ÿ”ง Logic Board Capacitors
Macintosh Plus Logic Board Capacitor Locations
The Macintosh Plus logic board contains fewer electrolytic capacitors than the analog board but they are still critical for operation.
Macintosh Plus Logic Board Capacitor Specifications
C5 33ยตF 16V 1x
C20 33ยตF 16V 1x
C22 4.7ยตF 35V 1x
๐Ÿ› ๏ธ Capacitor Replacement Procedure
  1. Discharge CRT โ€“ Safely discharge the CRT before any internal work.
  2. Remove Boards โ€“ Label and disconnect cables; remove analog and logic boards.
  3. Desolder Old Caps โ€“ Use a soldering iron, wick, or pump to cleanly remove components.
  4. Insert Replacements โ€“ Observe correct polarity (marked with a stripe).
  5. Solder Securely โ€“ Ensure joints are shiny, clean, and well-adhered.
  6. Trim Leads & Inspect โ€“ Trim excess leads and double-check all work.
  7. Check for Shorts โ€“ Use a multimeter to verify no shorts before powering on.
  • Desoldering pump or braid
  • Fine leaded solder (0.5 mm)
  • Isopropyl alcohol & ESD brush
  • Multimeter
  • Safety glasses & gloves
โš™๏ธ Voltage Adjustment After Recap
Use a multimeter to verify voltages at the floppy drive power connector:
  • +5V rail: 4.85V โ€“ 5.15V
  • +12V rail: 11.9V โ€“ 12.7V
๐Ÿ’ก Additional Tips
  • Power the Mac periodically to prolong capacitor life.
  • Use brand-name capacitors (e.g., Nichicon, Panasonic, Rubycon).
  • Replace in groups or full sets for best results.
  • Always verify polarity and double-check each joint.
  • Dispose of old capacitors via proper e-waste channels.
