Atari 800XE Capacitor Replacement Guide
Revision as of 20:18, 29 March 2026 by Josh (talk | contribs) (Created Atari 800XE Capacitor Replacement Guide — full cap list for both PCB variants)
Replacing the original electrolytic capacitors ("recapping") in your Atari 800XE is essential preventive maintenance for long-term reliability. The 800XE is electronically identical to the Atari 65XE and uses the same motherboard designs, so all capacitor references, locations, and values in this guide apply equally to both models.
Ageing electrolytic capacitors lose capacitance and develop high ESR (Equivalent Series Resistance) over time, leading to power instability, video artefacts, audio distortion, random crashes, or complete failure to boot. Proactively recapping the board protects the irreplaceable custom chipset (ANTIC, GTIA, POKEY, FREDDIE) from voltage ripple and instability.
Before starting, examine all electrolytic capacitors on the mainboard for:
  • Bulging or domed tops — indicates internal gas pressure from electrolyte breakdown.
  • Leaking electrolyte — brown, green, or white crust around the base or leads. Can corrode PCB traces.
  • Discolouration of the PCB beneath or around a capacitor — a sign of past leakage.
  • Random resets, video glitches, or audio hum — often the first symptoms of dried-out or high-ESR capacitors, even if they look visually fine.
If any capacitor shows visible signs of failure, it is strongly recommended to replace all electrolytic capacitors on the board as a preventive measure.
Identifying Your PCB Revision
The 800XE was manufactured on two different motherboard designs. Identify your board revision before ordering parts, as the capacitor count, values, and locations differ:
800XE / 65XE PCB Variants
Board Number RAM Type Electrolytic Cap Count Notes
C070067 (Rev B/C) 8 × 4164 DRAM 11 electrolytic capacitors Original XE board; through-hole construction
CA200519 2 × 41464 DRAM Fewer electrolytics (simplified power path) Cost-reduced board; some SMD components
Capacitor List — C070067 Board
The C070067 is the original and most common XE motherboard. The following electrolytic capacitors are present:
Atari 800XE / 65XE — C070067 Board Electrolytic Capacitors
Ref. Designator Capacitance Voltage Rating Type Function / Location
C1 470 µF 16 V Radial Main +5 V input filter — primary power smoothing
C2 22 µF 16 V Radial Power decoupling — ANTIC/GTIA area
C3 22 µF 16 V Radial Power decoupling — CPU/ROM area
C10 22 µF 16 V Radial Power decoupling — RAM area
C19 4.7 µF 35 V Radial Video output coupling — composite video path
C20 4.7 µF 35 V Radial Video chroma coupling — monitor port
C22 4.7 µF 35 V Radial Video luminance coupling — monitor port
C24 10 µF 16 V Radial Audio output coupling — amplifier stage
C50 10 µF 16 V Radial Reset circuit timing capacitor
C71 22 µF 16 V Radial SIO / serial port decoupling
C98 10 µF 16 V Radial Power decoupling — peripheral interface area
Notes:
  • All capacitors on the C070067 board are through-hole radial electrolytics.
  • C1 (470 µF) is the largest and most critical — a failed C1 causes widespread power instability.
  • C24 (10 µF audio coupling) is a common failure point, causing weak or distorted sound.
  • C19, C20, and C22 (4.7 µF/35 V) affect video quality — failed caps cause washed-out colours or missing chroma/luma.
Capacitor List — CA200519 Board
The CA200519 is the cost-reduced board used in later production 800XE and 65XE units. It uses fewer discrete components and may include some SMD electrolytic capacitors.
Atari 800XE / 65XE — CA200519 Board Electrolytic Capacitors
C20 4.7 µF 35 V Radial Video coupling
C22 4.7 µF 35 V Radial Video coupling
C24 10 µF 16 V Radial or SMD Audio output coupling
Notes:
  • The CA200519 board has fewer electrolytic capacitors due to the simplified power distribution.
  • Some later CA200519 revisions may use SMD electrolytic capacitors in certain positions. Replace with equivalent SMD parts, or carefully adapt radial types if SMD replacements are unavailable.
  • Always cross-check your specific board's silkscreen — minor layout differences exist between production runs.
Replacement Capacitor Specifications
When sourcing replacement capacitors:
Recommended Replacement Specifications
Parameter Recommendation
Temperature rating 105 °C (mandatory — do not use 85 °C rated parts)
ESR Low-ESR types preferred (especially for C1 and power decoupling positions)
Voltage rating Use equal or higher voltage rating than the original (never lower)
Capacitance Match original value exactly
Brands Nichicon, Panasonic, Rubycon, United Chemi-Con (avoid generic/unbranded)
Lead spacing 5 mm for most 10–22 µF; 5–7.5 mm for 470 µF (check PCB pad spacing)
Maximum height 18 mm or less — must clear the metal RF shield
Tools Required
  • Temperature-controlled soldering iron (15–40 W, fine chisel or conical tip)
  • Desoldering pump (solder sucker) and/or desoldering braid (wick)
  • Isopropyl alcohol (IPA, 99%) and a small brush or lint-free cloth
  • Lead-free or leaded solder, 0.5–0.7 mm diameter
  • ESR meter (optional but recommended for testing old capacitors before removal)
  • Flush-cut side cutters for trimming leads
  • Antistatic wrist strap
  • Multimeter for post-recap voltage verification
Step-by-Step Procedure
  1. Disassemble the 800XE: Remove the five case screws from underneath. Gently lift the top case. Disconnect the keyboard membrane cable.
  2. Remove the mainboard: Unscrew the PCB mounting screws. Carefully lift out the board, noting the orientation of all connectors and any shielding.
  3. Remove the RF shield (if present) to access all capacitors.
  4. Document the board: Photograph the board before starting — note the orientation (polarity stripe) of each electrolytic capacitor.
  5. Desolder old capacitors: Heat each lead from the underside and use a desoldering pump or wick to remove solder. Gently pull the capacitor free once both leads are clear. Do not force — you risk lifting pads.
  6. Clean the pads: Remove old flux and any leaked electrolyte residue using IPA and a brush. Inspect pads and nearby traces for corrosion damage.
  7. Install new capacitors: Observe correct polarity — the longer lead is positive; the silkscreen typically marks the negative (–) pad with a stripe or filled half-circle. Insert the new capacitor, bend leads slightly to hold it in place, and solder from the underside.
  8. Trim leads: Cut flush with the solder joint using side cutters.
  9. Inspect all joints: Check for solder bridges, cold joints, or missed connections.
  10. Reassemble: Refit the RF shield, mainboard, keyboard cable, and case.
Post-Recap Verification
After recapping, verify correct operation before reassembling the case:
Voltage and Ripple Checks
Expected Voltage Rails After Recapping (no cartridge, no peripherals)
Test Point Nominal Value Acceptable Range Maximum Ripple (peak-to-peak)
+5 V at mainboard input (C1) 5.00 V 4.85–5.15 V < 50 mV
+5 V at CPU pin 8 5.00 V 4.85–5.15 V < 50 mV
+5 V at ANTIC pin 40 5.00 V 4.85–5.15 V < 50 mV
+5 V at GTIA pin 24 5.00 V 4.85–5.15 V < 50 mV
+5 V at RAM Vcc 5.00 V 4.85–5.15 V < 50 mV
Functional Checks
  • Boot test: Power on — the system should display the blue READY screen within 2–3 seconds.
  • Audio test: Press keys to hear key-click sounds. Load a program with sound if possible.
  • Video quality: Check for clean, stable video via composite output. No jitter, rolling, or colour bleed.
  • Keyboard test: Verify all keys respond correctly.
  • Peripheral test: Connect an SIO device (disk drive or SIO2SD) and verify communication.
Power Supply (External)
The 800XE uses an external +5 V DC power supply. If you observe unstable voltages or excessive ripple after recapping the mainboard, the PSU itself may need attention:
Typical XE Power Supply Capacitor
Capacitance Voltage Notes
2200 µF 16 V or 25 V Main filter capacitor inside PSU enclosure
Warning: The external PSU contains mains-voltage components. Only open and service it if you are experienced with mains electrical safety. Discharge all capacitors before working inside.
Troubleshooting After Recapping
If the 800XE does not boot correctly after recapping:
  • Check polarity of all new capacitors — a reversed electrolytic will fail quickly and may damage the board.
  • Inspect for solder bridges between adjacent pads or traces.
  • Verify no pads were lifted during desoldering — repair with thin wire jumpers if necessary.
  • Re-check voltages at all IC Vcc pins to ensure power is reaching the entire board.
  • Test with a current-limited power supply (if available) for the first power-on after recapping — this protects against short circuits.
For further diagnostic procedures, see the Atari 800XE Troubleshooting Guide.
Additional Tips
  • Always check the PSU first — a failing external PSU can damage newly installed capacitors.
  • Keep capacitor height under 18 mm to ensure the metal RF shield fits correctly.
  • Double-check polarity before soldering — reversed electrolytics can burst or explode.
  • Clean all leaked electrolyte thoroughly — it is corrosive and will continue to eat traces if left in place.
  • Power up with a fuse or current-limited supply for the first test after recapping.
  • Consider adding IC sockets while the board is open — this makes future chip testing and replacement much easier.
