Macintosh IIvx
Revision as of 18:42, 1 October 2026 by Josh (talk | contribs) (Remove Category:Macintosh II series (created in error, to be deleted))
The Macintosh IIvx is a desktop Macintosh introduced by Apple on 19 October 1992 and discontinued on 21 October 1993.[1] It is the faster version of the Performa 600: the same case and basic logic board, with a 68882 FPU and a 32K cache soldered to the board. Macworld measured it 25 to 35 per cent faster than the Performa 600.[2] With the Performa 600 it was the first Macintosh in a metal case and the first with a built-in CD-ROM drive; the case and power supply were used again for the Centris 650, Quadra 650 and Power Macintosh 7100.[3][4] Apple's service manual and developer note cover it with the Macintosh IIvi and Performa 600.[5][6]
Macintosh IIvx
Macintosh IIvx (All About Apple museum)
TypeDesktop personal computer
Released19 October 1992
Discontinued21 October 1993
Intro priceUS$2,949-3,319 at introduction
CPUMotorola 68030 at 32 MHz (31.3344 MHz), 16 MHz bus
Memory4 MB soldered plus four 30-pin SIMM sockets, 68 MB maximum (80 ns)
StorageInternal SCSI hard drive, 40-400 MB; optional internal CD-ROM
Display—
SoundMono output through the speaker, stereo CD audio at the headphone jack; mono sound input
GraphicsBuilt in (DB-15), 512 KB or 1 MB VRAM on two VRAM SIMMs
ROM1 MB
FPU / coprocessorMotorola 68882
MediaInternal 1.4 MB floppy drive
Ports / interfaceTwo ADB, two RS-232/RS-422 serial (mini DIN-8), SCSI (DB-25), video (DB-15), headphone and microphone jacks
ExpansionThree NuBus slots, one 120-pin accelerator slot, one 5.25-inch bay
Power85-270 V AC auto-ranging; 112 W DC maximum
Dimensions6 × 13 × 16.5 in (150 × 325 × 412 mm)
Weight25 lb (11.3 kg)
OS / FirmwareSystem 7.1 to Mac OS 7.6.1
SuccessorMacintosh Centris 650
CodenameBrazil, Lego
Model no.M1350 (Gestalt ID 48)
History
Macworld reported in April 1993 that the IIvx belonged to Apple's new Centris mid-range line, but that Apple's lawyers had not finished the trademark check on the Centris name before it was released; Apple said it would not rename it.[7] The 68040 Macintosh Centris 650 arrived in the same case in February 1993, and Apple cut the IIvx's base price from US$2,949 to US$1,899.[4] Low End Mac found the IIvx slower than the Macintosh IIci, because its 32 MHz processor runs on a 16 MHz bus.[4]
Macintosh IIvx specifications (Apple)
Item Specification
Processor Motorola 68030 at 31.3344 MHz with built-in MMU; 68882 FPU at the same speed[6]
Cache 32K static RAM on the logic board; no bus snooping[6]
RAM 4 MB soldered (eight 1M × 4 DRAMs); four 30-pin SIMM sockets, all four filled with identical 80 ns SIMMs of 256K to 16 MB; 68 MB maximum[6]
ROM 1 MB, two 256K × 16 chips soldered to the board[6]
VRAM 512K (two 256K VRAM SIMMs) or 1 MB (two 512K SIMMs), 100 ns, fitted in identical pairs[6]
Video modes 512K: 512 × 384 at up to 16 bits per pixel, 640 × 480 at up to 8. 1 MB: 640 × 480 at up to 16[5]
Drives 1.4 MB floppy drive; 3.5-inch SCSI hard drive, 40-400 MB; optional 5.25-inch CD-ROM drive[5][6]
Expansion Three NuBus slots (13.9 W each, 41.7 W total); one 120-pin accelerator slot (5 W, 1 A at +5 V)[6]
Serial Two RS-232/RS-422 ports, 230.4 kbaud maximum, 0.92 Mbit/s with an external clock[5]
SCSI DB-25; up to six external devices[5]
Power supply 85-270 V AC, automatic; 112 W maximum, 130 W peak; switched monitor outlet, 3 A[6]
Environment Operating 10-40 °C; storage -40 to 47 °C; 5-95 % relative humidity; 0-3,048 m[5]
Case Painted sheet metal with plastic front and back bezels; 325 × 412 × 150 mm (13 × 16.5 × 6 in)[6]
The Service Source prints the machine's A/C line input as 100-120 V AC at 200 W, and the monitor outlet as 100-240 V AC, 3 A.[5] The developer note gives the supply's input as 85-270 V AC, selected automatically.[6] Low End Mac lists the supply as 230 W; Apple's figure is 112 W, and Macworld's review gives the same.[4][6][2]
Macintosh IIvx configurations at launch
Order number RAM VRAM Hard drive CD-ROM US list price
M1355LL/A 4 MB 512K 80 MB No $2,949
M1371LL/A 4 MB 512K 230 MB No $3,319
M1373LL/A 5 MB 1 MB 80 MB AppleCD 300i $3,219
Order numbers are EveryMac's; prices are Macworld's.[1][2]
Logic board
The VASP chip combines video, memory mapping, sound, clock generation and glue logic, and is similar to the V8 of the Macintosh LC. A 68HC05 microcontroller, as in the Macintosh IIsi, runs ADB, the clock, parameter RAM and soft power.[6] Apple's logic board part is 661-0759 for the IIvx (661-0760 IIvi, 661-0761 Performa 600).[5]
Because RAM is tested and sized before video starts, the screen stays blank for a while at start-up, longer with more RAM fitted.[6] The IIvx does not support 1-bit mode on Apple's 12-inch RGB monitor.[6]
Accelerator slot
The 120-pin slot is for accelerator cards, much like the IIci cache slot. Apple warns that it is not compatible with processor-direct cards for other Macintosh models; the connector is the same but the signals differ, and fitting one may damage the card and the computer. Cards must stay within 5 W.[6] A IIvx could be upgraded to a Centris 650 by exchanging the logic board, and Apple's Service Source refers the Power Macintosh 7100 upgrade to the 7100 manual.[5]
SCSI and CD-ROM
An active terminator on the logic board terminates the internal bus when no external device is attached, and switches off when a terminated external device is connected. The 3.5-inch hard drive must be terminated; a device in the 5.25-inch bay must not be. Apple's internal CD-ROM uses SCSI ID 3, and its audio goes to a four-pin connector on the logic board.[6] Apple's parts list shows AppleCD 300, 300i and 600i drives.[5]
Apple part 661-0758, the same as the Centris 650's.[5] Apple Rescue of Denver lists it as Apple 614-0009, 112 W, made by Delta (SMP-120EB) or Astec (AA16870).[3] Its 80 mm fan cools the whole machine.[6]
Power supply ratings (Apple developer note, Table 1-12)
Load +5 V +5 V trickle +12 V -12 V Total
Minimum 1.5 A 0 A 200 mA 0 A 9.9 W
Maximum 15 A 1 mA 2.5 A 600 mA 112 W
Peak 15 A 1 mA 6 A (12 s maximum) 600 mA 130 W
The trickle output is live whenever the machine is plugged in and runs the clock, parameter RAM and the ADB power-on circuit; the +12 V peak rating covers every internal drive spinning up at once.[6] Apple publishes no rail tolerances and no adjustment.[5]
Battery
A 3.6 V lithium cell keeps the clock and PRAM when the machine is unplugged.[1][6] Apple's test: measure on the 10 V DC range, positive probe on the end marked "+" on the logic board, and replace the battery below 2.8 V.[5] See Macintosh IIvx General Maintenance.
Capacitors
The IIvi board Recap-a-Mac documents has six 47 µF 16 V surface-mount electrolytics and two 220 µF 16 V axials, and Console5 sells one logic board kit for the IIvx, IIvi and Performa 600. See Macintosh IIvx Capacitor Replacement Guide.[8]
Maintenance and repair
  1. ↑ 1.0 1.1 1.2 Apple Macintosh IIvx Specs, EveryMac—link(accessed 2026-09-30) Introduced 19 October 1992, discontinued 21 October 1993; model M1350, Gestalt ID 48; order numbers M1355LL/A (4 MB, 512K VRAM, 80 MB), M1371LL/A (4 MB, 512K VRAM, 230 MB), M1373LL/A (5 MB, 1 MB VRAM, 80 MB, 2X CD-ROM); 3.6 V lithium battery; 25 lb.
  2. ↑ 2.0 2.1 2.2 Charles Seiter, "Macintosh IIvx: The latest desktop Mac is a faster version of the Performa 600", Macworld, December 1992, pp. 206-207, archive.org. Same case, logic board, CD-ROM option and I/O as the Performa 600; 68882 and 32K cache added; 35 per cent faster at some processor-intensive tasks and 25 per cent at others; three NuBus slots and a 112 W supply; prices US$2,949 (4 MB, 80 MB, 512K VRAM), US$3,319 (230 MB), US$3,219 (AppleCD 300i, 1 MB VRAM, 5 MB); IIvi for Europe and the Pacific at 16 MHz, no 68882 but a socket for one, no cache, US$2,900.
  3. ↑ 3.0 3.1 Quadra 650, IIvi, IIvx, Power Mac 7100, Performa 600 – Power Supply, Apple Rescue of Denver—link(accessed 2026-09-30) Apple 614-0009, 661-0758, 112 W; original to the Centris and Quadra 650, IIvi, IIvx, Power Macintosh 7100 and Performa 600; Delta SMP-120EB or Astec AA16870.
  4. ↑ 4.0 4.1 4.2 4.3 Mac IIvx, Low End Mac—link(accessed 2026-09-30) 32 MHz CPU on a 16 MHz bus; slower than the IIci; first Macs with a built-in CD-ROM drive and a metal case; base price cut from US$2,949 to US$1,899 when the Centris 650 appeared; code names Brazil and Lego; power supply given as 230 W.
  5. ↑ 5.00 5.01 5.02 5.03 5.04 5.05 5.06 5.07 5.08 5.09 5.10 5.11 5.12 5.13 Apple Computer, Macintosh IIvx, Macintosh IIvi, Performa 600 Service Source, File:Macintosh iivx.vi.perf 600.pdf; see Macintosh IIvx/IIvi/Performa 600 Service Source. Page numbers are the PDF's: Specifications pp. 5-13; Symptom Charts pp. 16-24; Take Apart pp. 26-51; Upgrades pp. 53-66; Battery Verification pp. 68-69; Battery Replacement pp. 70-72; Reset/Interrupt Switch pp. 73-74; Exploded View p. 76.
  6. ↑ 6.00 6.01 6.02 6.03 6.04 6.05 6.06 6.07 6.08 6.09 6.10 6.11 6.12 6.13 6.14 6.15 6.16 6.17 6.18 6.19 6.20 Apple Computer, Macintosh IIvx Developer Note (1992), also covering the Macintosh IIvi and Performa 600, File:Macintosh IIvx IIvi and Performa 600 Developer Note.pdf; see Macintosh IIvx IIvi and Performa 600 Developer Note. Printed page numbers: features pp. 2-3; compatibility (cache, accelerator slot, SCSI termination, video modes) pp. 4-5; VASP p. 6; ROM, RAM, VRAM pp. 9-10; ADB, clock, soft power pp. 19-20; accelerator slot power p. 25; enclosure and power supply pp. 27-28; internal drives pp. 29-32; software p. 35.
  7. ↑ Galen Gruman, "Centris 610 & 650", Macworld, April 1993, pp. 106-113, archive.org.
  8. ↑ Macintosh IIvi, Recap-a-Mac—link(accessed 2026-09-30)
