Power Macintosh 7100
Revision as of 07:16, 2 October 2026 by Josh (talk | contribs) (Link hosted owner's guide)
The Power Macintosh 7100 is a desktop Macintosh with a PowerPC 601 processor, introduced by Apple on 14 March 1994 at 66 MHz with the first Power Macintosh range and raised to 80 MHz on 3 January 1995.[1][2] It uses the case of the Macintosh Quadra 650 family, which Apple's specification pages call the IIvx form factor,[3] and Apple sold a 7100/66 logic board upgrade kit for the Quadra 650 and Centris 650.[4] Wikipedia records that its development code name was "Carl Sagan", which led to a dispute with the astronomer.[5]
Power Macintosh 7100/80. Photo: Matt Gibson, Wikimedia Commons, CC BY 2.0
TypeDesktop personal computer
Released14 March 1994 (7100/66, 7100/66AV); 3 January 1995 (7100/80, 7100/80AV)
Discontinued6 January 1996 (7100/80, Apple)
CPUPowerPC 601 at 66 or 80 MHz; 33 or 40 MHz bus
Memory8 MB soldered; four 72-pin SIMM sockets used in pairs; 136 MB maximum
Storage250 or 500 MB (7100/66) or 500 or 700 MB (7100/80) SCSI hard drive
Display—
Sound16-bit stereo input and output
GraphicsHDI-45 port driven from main memory; PDS video card with 1 or 2 MB VRAM (2 MB on the AV card) and a DB-15 port
ROM4 MB, on a SIMM
FPU / coprocessorBuilt into the PowerPC 601
Media1.4 MB SuperDrive (manual insert); AppleCD 300i Plus on the 7100/66AV and some 80 MHz machines
Ports / interfaceADB, two GeoPort serial, SCSI (DB-25), AAUI-15 Ethernet, HDI-45 and DB-15 video, sound in and out
ExpansionThree NuBus slots; one PDS (holds the video card); L2 cache SIMM slot
Power100–240 V AC, auto-ranging; 167 W maximum continuous input
Dimensions152 × 330 × 419 mm (6.0 × 13.0 × 16.5 in)
Weight24 lb (Service Source); 25 lb (Apple specification pages)
OS / FirmwareSystem 7.1.2 (7100/66) or 7.5 (7100/80); supported to Mac OS 9
Models
Power Macintosh 7100 models (Apple specification pages)
Model Introduced Discontinued Clock / bus L2 cache Video card
7100/66 14 March 1994 3 January 1995 66 / 33 MHz Optional 2 MB Video Card (1 MB VRAM, expandable to 2 MB)
7100/66AV 14 March 1994 3 January 1995 66 / 33 MHz Optional AV Card, 2 MB VRAM, S-video in and out
7100/80 3 January 1995 6 January 1996 80 / 40 MHz 256K 2 MB Video Card (1 MB VRAM, expandable to 2 MB)
7100/80AV 3 January 1995 5 August 1995 80 / 40 MHz 256K AV Card, 2 MB VRAM, S-video in and out
Sources: Apple's specification pages and service manual.[1][2][6][7] The AV models use the same logic board as the others; the difference is the Power Macintosh AV Card in the PDS slot (p. 8).[4]
Apple's figures for the Power Macintosh 7100
Item Figure
Processor PowerPC 601 at 66 MHz (needs System 7.1.2 or later) or 80 MHz (System 7.5 with enabler 1.1.1 or later); built-in MMU and FPU; 32K on-chip cache (p. 20)
RAM 8 MB soldered to the logic board; four SIMM sockets taking pairs of the same size and speed, 72-pin, noncomposite, 80 ns or faster; 136 MB maximum (p. 21)
ROM 4 MB, on a SIMM in a socket that is interchangeable with the cache SIMM socket (pp. 21, 86)
Video DRAM-based HDI-45 port on the logic board, which drives AudioVision monitors directly and, with an HDI-45 to DB-15 adapter, monitors up to 17 inches; PDS video card with a DB-15 port for monitors up to 21 inches. The 2 MB Video Card has 1 MB VRAM, expandable to 2 MB with four 256K VRAM SIMMs; the AV Card has 2 MB (pp. 22, 27–30)
Level-2 cache Optional 256K SIMM on the 7100/66; standard 256K on the 7100/80 (p. 22)
Storage 250 or 500 MB (7100/66) or 500 or 700 MB (7100/80) SCSI hard drive; manual-insert 1.4 MB SuperDrive; AppleCD 300i Plus standard on the 7100/66AV and on some 7100/80 and 7100/80AV machines (pp. 23–24)
Ports SCSI DB-25 for up to six external devices (five with an internal CD-ROM); two GeoPort serial ports (mini DIN-9, taking DIN-8 plugs); one ADB port, 500 mA; AAUI-15 Ethernet (p. 25)
Expansion One 182-pin processor-direct slot, normally holding the video card; three NuBus slots (p. 26)
Sound 16-bit stereo in and out at 48, 44.1, 24 and 22.05 kHz; 1 V peak-to-peak line level (p. 26)
Electrical 100–240 V AC, automatically configured, 50–60 Hz; 167 W maximum continuous and 230 W peak input, excluding the monitor; 112 W continuous DC output (p. 31)
Physical 6.0 × 13.0 × 16.5 in (152 × 330 × 419 mm); 24 lb (11.3 kg) (p. 32)
Clock battery Long-life lithium; replace below 3.2 V (pp. 22, 120)
Source: the service manual at the pages given.[4] Apple's specification pages give the battery as 3.6 V lithium, the weight as 25 lb and the supply as 230 W maximum, 1.9 A.[1]
Apple's logic board connector diagram (Service Source p. 18)
The video card must be fitted
Apple says the 7100/66 and 7100/80 "must have a video card installed in the PDS slot": a missing card "can result in a system that won't boot or a system that crashes" (p. 8). The upgrade instructions add that the card is needed "for proper bus termination" (p. 111), and Apple's chart for intermittent crashes includes checking for it (p. 40).[4] Third-party processor upgrades for the 7100 also go in the PDS; Low End Mac notes that some carry a pass-through connector for the video card.[3]
Memory
SIMMs go in matched pairs of the same size and speed, noncomposite only (p. 21). With bad SIMMs fitted, a 7100 does not play the death chimes of earlier Macs; it shows a dialog box saying a bad SIMM has been found (p. 7).[4] Low End Mac says the 7100 will not recognise more than 32 MB per SIMM even when 64 MB SIMMs are fitted.[3]
Cooling
The power supply has its own fan. Apple's take-apart chapter covers a second fan clipped under the drive chassis next to the DRAM heat sink, fitted only to the 7100/80 and 7100/80AV (pp. 78–82). The chart for intermittent shutdowns starts with clearing the air vents, because thermal protection may shut the machine down; Apple says it "should be OK" again after 30 to 40 minutes (p. 39).[4]
Known faults
  • A machine that will not power up: Apple's first step is always the logic board reset, which removes the battery and presses the rear power-on button (pp. 6, 124–128).
  • Clicking, chirping or thumping: replace the power supply, then the logic board (p. 38).
  • A Multiple Scan monitor on a 7100/66AV showing ghosting or smearing: replace the AV Card (p. 43).
  • A one-part error chord at start-up: Apple's chart isolates the hard drive and floppy drive by unplugging them in turn before replacing the logic board (p. 37).
Source: service manual.[4] All of Apple's charts are on Power Macintosh 7100 Troubleshooting.
Service parts
Power Macintosh 7100 parts (Apple exploded view, p. 132)
Part Apple part number
Logic board 661-0897, 661-0208
Power supply 661-0758
Power supply strap 922-0906
Manual-insert floppy drive 661-0121
Top housing 922-0405
Front panel 922-0899
Internal chassis 922-0058
Speaker 922-0055
Bottom housing 922-0898
Source: exploded view.[4] The manual does not say which of the two logic board numbers applies to which model.
Maintenance and repair
  1. ↑ 1.0 1.1 1.2 Apple, "Power Macintosh 7100/66: Technical Specifications". 601 at 66 MHz; data path 64-bit, 33 MHz; L2 optional; 3 NuBus, PDS filled; video DB-15 and HDI-45; Ethernet AAUI-15; 230 max watts, 1.9 A, 100–240 V; battery type 3.6V lithium; 8 MB on the logic board; four 72-pin SIMM slots in groups of 2; 8–136 MB; 80 ns; introduced 3/14/1994; discontinued 1/3/1995; form factor IIvx; Gestalt ID 112; 25 lb; 6 × 13 × 16.5 in; System 7.1.2; supported to Mac OS 9; 2x CD.
  2. ↑ 2.0 2.1 Apple, "Power Macintosh 7100/80: Technical Specifications". 601 at 80 MHz; data path 64-bit, 40 MHz; L2 256K; introduced 1/3/1995; discontinued 1/6/1996; Gestalt ID 47; System 7.5 with PowerPC Enabler 1.1.1.
  3. ↑ 3.0 3.1 3.2 Low End Mac, "Power Mac 7100" (LEM Staff). Built into the Quadra 650 case with three NuBus slots and a PDS; processor upgrades fit the PDS and may include a pass-through for the video card; RAM "will not recognize more than 32 MB per SIMM even if you install 64 MB SIMMs"; floppy sled shared with the IIvi, IIvx, Centris 650 and Quadra 650; PRAM battery 3.6 V half-AA; 230 W supply.
  4. ↑ 4.0 4.1 4.2 4.3 4.4 4.5 4.6 4.7 Apple Computer, Service Source: Power Macintosh 7100 Series (1995), File:Powermac_7100_series.pdf; see Power Macintosh 7100 Series Service Source. Page numbers are PDF pages: Troubleshooting Tips pp. 6–8, Rear Panel pp. 15–16, Logic Board Connectors pp. 17–18, Specifications pp. 20–33, Symptom Charts pp. 36–51, Take Apart pp. 53–88, Upgrades pp. 90–117, Additional Procedures pp. 119–130, Exploded View p. 132.
  5. ↑ Wikipedia, "Power Macintosh 7100". Introduced March 1994, sold until January 1996; code name "Carl Sagan", later "BHA"; Sagan's lawsuits.
  6. ↑ Apple, "Power Macintosh 7100/66AV: Technical Specifications". Includes S-video ports for video in and out; RCA ports via an included adapter; 2 MB VRAM built in; introduced 3/14/1994; discontinued 1/3/1995.
  7. ↑ Apple, "Power Macintosh 7100/80AV: Technical Specifications". Introduced 1/3/1995; discontinued 8/5/1995.
