Atari 2600
Revision as of 19:20, 19 September 2025 by Josh (talk | contribs) (→Schematics)
The Atari 2600, originally sold as the Atari Video Computer System (Atari VCS), is an 8-bit home video game console developed and manufactured by Atari, Inc. Released in September 1977, it popularized the use of ROM cartridges for game storage and established the modern video game console market. The system is built around the MOS Technology 6507 processor and the custom Television Interface Adaptor (TIA) chip, which handles graphics and sound generation without a frame buffer, requiring precise timing in software.
Atari 2600
Atari 2600 4-switch "woodgrain" model (1980-1982)
ManufacturerAtari, Inc.
TypeHome video game console
Released11 September 1977 (as Video Computer System)
NA: September 1977
EU: 1978
JP: October 1983 (as Atari 2800)
Discontinued1 January 1992
Intro priceUS$199 (1977)
CPUMOS Technology 6507 @ 1.19 MHz (NTSC) / 1.18 MHz (PAL)
Memory128 bytes RAM (within 6532 RIOT)
StorageROM cartridge (2 KB - 64 KB with bank switching)
Display160 × 192 pixels (NTSC), 160 × 228 (PAL), 128 colors
SoundTIA custom chip, 2 channel mono
Dimensions340 mm W × 240 mm D × 64 mm H (6-switch)
Weight1.36 kg (Heavy Sixer), 1.14 kg (Light Sixer)
OS / FirmwareNone
PredecessorDedicated Pong consoles
SuccessorAtari 5200
CodenameStella
Model no.CX2600, CX2600A, 2600 Jr.
System Architecture
Sub-system Specification
CPU MOS Technology 6507 @ 1.193182 MHz (NTSC) / 1.182298 MHz (PAL)
6502 variant with 13 address lines (8 KB address space)
Graphics/Sound Television Interface Adaptor (TIA) CO10444 (NTSC) / CO11903 (PAL)
Generates video signal in real-time without frame buffer
RAM/I/O/Timer MOS Technology 6532 RIOT
128 bytes RAM, two 8-bit I/O ports, programmable timer
Video 160 × 192 pixels (NTSC), 160 × 228 (PAL)
128 colors (NTSC), 104 colors (PAL), 8 colors (SECAM)
Sprites 2 players (8 pixels wide), 2 missiles (1 pixel), 1 ball (1 pixel)
All sprites can be stretched to 2×, 4×, or 8× width
Background 40-pixel playfield (20-bit register, mirrored or repeated)
Audio 2 independent channels, 4-bit volume, 5-bit frequency control
31 kHz max frequency, square wave and noise generation
ROM Space 4 KB standard, up to 64 KB with bank switching
Memory Map
6507 Address Space
Range Size Purpose
$0000-$007F 128 bytes TIA registers (write)
$0030-$003D 14 bytes TIA registers (read)
$0080-$00FF 128 bytes RIOT RAM (also mirrored at $0180-$01FF)
$0280-$0297 24 bytes RIOT I/O and timer
$1000-$1FFF 4 KB Cartridge ROM (mirrored at $3000, $5000, $7000, $9000, $B000, $D000, $F000)
TIA Register Map
Key TIA Registers
Address Register Function
$00 VSYNC Vertical sync set-clear
$01 VBLANK Vertical blank set-clear
$02 WSYNC Wait for horizontal sync
$04-$05 NUSIZ0-1 Number-size player-missile 0-1
$06-$09 COLUP0-1, COLUPF, COLUBK Color registers
$0A CTRLPF Playfield control
$0D-$0F PF0-2 Playfield graphics
$10-$14 RESP0-1, RESM0-1, RESBL Reset sprite positions
$1B-$1D GRP0-1 Graphics player 0-1
$20-$24 HMP0-1, HMM0-1, HMBL Horizontal motion
$2A HMOVE Apply horizontal motion
$2C CXCLR Clear collision latches
Model Variants
Production Models
Model Years Description Key Features
Heavy Sixer 1977-1978 CX2600, thick plastic base Sunnyvale manufacture, 6 front switches, channel selector
Light Sixer 1978-1980 CX2600, cost-reduced Taiwan/Hong Kong manufacture, thinner case
4-Switch Woodgrain 1980-1982 CX2600A Difficulty switches moved to rear, single PCB design
4-Switch Vader 1982-1983 CX2600A All-black case, same internals as woodgrain
2600 Jr. (Short Rainbow) 1984-1985 Cost-reduced Smaller form factor, rainbow stripe
2600 Jr. (Long Rainbow) 1986-1991 Final revision Extended rainbow, slight PCB changes
Motherboard Revisions
Early 6-switch models used a two-board design with the main board housed in thick RF shielding and a separate switch board connected via ribbon cable. The 4-switch models consolidated to a single angled PCB. Key revisions include:
  • Pre-Rev 14: CD4050 buffer IC for controller inputs (prone to static damage)
  • Rev 14-15: Added static protection diodes, improved color output
  • Jr. models: Fully integrated single board, cost-optimized design
The Atari 2600 requires regular maintenance to ensure reliable operation after 40+ years. Common maintenance tasks include cleaning cartridge slots with isopropyl alcohol, treating oxidized switch contacts with DeoxIT, and ensuring proper ventilation to prevent overheating. The cartridge connector's 24 gold-plated contacts are prone to tarnishing and should be cleaned periodically. Power switches on 6-switch models frequently develop oxidation that can be resolved by working the switch repeatedly or applying contact cleaner through the switch opening.
Troubleshooting Guide
Common failures include blank screens caused by dirty cartridge contacts, power supply issues from failed 7805 voltage regulators, and static-damaged controller ports. The TIA chip is particularly sensitive to failure and typically requires replacement from a donor unit. No video output often indicates oxidized power switch contacts or failed electrolytic capacitors. Audio problems frequently stem from failed 820pF styrene capacitors (C206/C207 on 6-switch, C53/C54 on Jr.) which should be replaced with ceramic equivalents.
Capacitor Replacement
Critical capacitors requiring replacement on all models include the main 2200µF 16V filter capacitor and multiple 4.7µF bypass capacitors. The 6-switch models additionally require replacement of C103/C104 (0.22µF) near the voltage regulator to eliminate video artifacts. Styrene capacitors C206/C207 (6-switch) or C53/C54 (Jr.) commonly fail and cause audio loss. The 7805 voltage regulator should be upgraded from the original 0.5A rated part to a 1A version during any capacitor replacement.
Power Supply
The console uses an external 9V DC power adapter (500mA minimum) with center-positive polarity. Internal regulation provides:
  • +5V: Main logic supply (should measure 4.85-5.15V)
  • Unregulated 9V: Direct to TIA for video generation
The 7805 voltage regulator mounted to the RF shield (6-switch) or heat sink (4-switch/Jr.) frequently fails after decades of operation. Symptoms include no power, intermittent operation, or voltage outside specifications.
Controller Ports
The DE-9 controller ports support various peripherals:
  • Standard joystick: 4 directions + 1 fire button
  • Paddle controllers: Analog rotation via 1MΩ potentiometer
  • Driving controller: Continuous rotation encoder
  • Keyboard controllers: 12-key matrix (0-9, #, *)
  • Track Ball: Digital pulses for X/Y movement
Port pinout is compatible with Commodore, Atari 8-bit computers, and Sega Master System (single button games only).
Cartridge Slot
The 24-pin (2×12) edge connector accepts cartridges from 2 KB to 64 KB using various bank-switching schemes:
  • Standard 2K/4K: Direct mapped, no switching
  • F8 (8K): Atari standard, two 4K banks
  • F6/F4 (16K): Four banks switched via $FFF6-$FFF9
  • F0 (Megaboy): 64K with special switching
Cartridges contain mask ROM or EPROM chips, with some including additional RAM (Super Chip) or coprocessors (DPC, Pitfall II).
Video Output
The TIA generates composite video internally, output through an RF modulator on channels 2 or 3 (selectable on some models). The video signal consists of:
  • Horizontal: 228 color clocks per line (160 visible pixels)
  • Vertical: 262 lines NTSC (192 visible), 312 lines PAL (228 visible)
  • Frame rate: 59.92 Hz NTSC, 49.70 Hz PAL
Common video modifications include composite output (bypassing RF modulator) and S-Video separation for improved picture quality.
Audio System
The TIA contains two independent audio channels, each with:
  • Frequency divider: 5-bit (32 settings)
  • Audio control: 4-bit waveform/noise selection
  • Volume: 4-bit (16 levels)
Output is mixed to mono and routed through the RF modulator. Common modifications add stereo output by separating the two TIA audio channels.
Common IC Identification
Atari Part Standard Part Function
C010745 MOS 6507 CPU
C010750 MOS 6532 RIOT (RAM/IO/Timer)
C010444 TIA (NTSC) Television Interface Adaptor
C011903 TIA (PAL) Television Interface Adaptor
C012173A CD4050 Hex buffer (early models)
Technical Specifications Summary
  • Clock Speed: 1.19 MHz (NTSC), 3.58 MHz pixel clock
  • Instruction Timing: ~1.5 machine cycles per 160 pixels (racing the beam)
  • Color Palette: 128 colors (16 hues × 8 luminance levels) NTSC
  • Maximum Sprites: 5 hardware sprites, software multiplexed for more
  • Playfield: 40 pixels wide, asymmetric or mirrored/repeated
Service Information
Detailed schematics and service information are available in the Atari Field Service Manual. The system uses all through-hole components, making repairs feasible with basic soldering equipment. Common replacement parts include:
  • 7805 voltage regulator: Standard TO-220 package
  • Power jack: 3.5mm × 1.3mm barrel connector
  • RF modulator: UM1233 or compatible
  • Controller ports: DE-9 female connectors
Schematics
Atari 2600 PAL
Motherboard Control Panel RF Modulator
Atari 2600 Console Schematic - PAL
Atari 2600 Control Panel Schematic - PAL
Atar i2600 Modulator Schematic - PAL
Atari 2600 - CX2600 - NTSC
Motherboard - CX2600 Motherboard - CX2600 A RF Sections
Atari 2600 CX2600 Schematic - NTSC
Atari 2600 A Schematic - NTSC
Atari 2600 RF Sections Schematic - NTSC
Atari 2600 Accessories
Accessories CX22 Trackball
Atari 2600 Accessories Schematic
Atari 2600 CX22 Schematic
