Atari 2600 General Maintenance
Routine care for the Atari 2600, from the six-switch CX2600 to the 2600 Jr. Fault diagnosis is on the Atari 2600 Troubleshooting Guide and capacitor values on the Atari 2600 Capacitor Replacement Guide. Designators, part numbers and voltages are from Atari's field service manual for the 2600 and 2600A.[1]
Before you start
[edit | edit source]- Disconnect the power adaptor.
- Use an anti-static wrist strap. Atari warns that the four LSI chips (A200–A203 on the CX2600) are very sensitive to static and asks technicians to wear a grounding band and to remove chips with a chip puller.[1]
- Work in a ventilated space when using solvents, and apply solvent with a brush or bud.
The largest capacitor is the 2200 µF 16 V reservoir: C106 on the CX2600 switchboard, C243 on a CX2600A.[1] It sits on the unregulated input of roughly 9 V, so there is no dangerous stored charge in this console.
Cleaning
[edit | edit source]Case
[edit | edit source]- Mild soap solution on a damp microfibre cloth.
- Cotton buds around the switches and the cartridge slot.
- Melamine foam for stubborn marks on textured plastic. It is a mild abrasive, so keep it away from printed graphics.
- 70 % isopropyl alcohol for adhesive residue.
Inside
[edit | edit source]- Blow loose dust out with compressed air.
- Clean the board with a soft brush and 99 % isopropyl alcohol.
- Look closely at the regulator and its heatsink, the cartridge connector, the controller ports and the power jack joints.
- Let the board dry fully before reassembly.
RF shield
[edit | edit source]The shield tabs are twisted metal and fatigue if bent repeatedly; straighten them slowly with needle-nose pliers. On reassembly make sure the shield sits flat. On the CX2600, the manual's NTSC tech tips list several parts that must be kept clear of the casting when the motherboard goes back in: L200 and the "chicklet" capacitors under the shroud (tip 15), C220 and C239 pushed away from the J200 shroud (tip 17), and long leads trimmed on Taiwan-built units (tip 18). Motherboards of Rev 8 and earlier need an insulating dot over a trace in the upper-left corner so that it cannot touch the casting (tip 6).[1]
Cartridge slot
[edit | edit source]The cartridge connector J200 is a 24-contact edge connector.[1] Dirty contacts give a black screen, garbled graphics and games that only work when the cartridge is moved.
- With the console assembled, clean the contacts with a cotton bud or a lint-free cloth over a card, dampened with 99 % isopropyl alcohol, and let the slot dry.
- With the board out, check that the two plastic tabs in the slot are intact (they open the dust covers on Atari cartridges) and check continuity from each contact to its trace.
Early 2600s have a green J200 connector. Atari found it unreliable after many insertions and replaces it if a unit is intermittent when the cartridge is wiggled.[1]
Switches
[edit | edit source]On the CX2600 the switches are on the switchboard: S101–S104 are slide switches, S105 and S106 are spring-return switches and S107 is an SPDT switch. On the CX2600A, S201 and S204 are DPDT slide switches, S202 and S203 are spring-return, and S200, S205 and S206 are PCB slide switches.[1]
- Work a stiff switch through its travel repeatedly, then apply contact cleaner and work it again.
- Tip 14 in the manual's NTSC tech tips: reset any CX2600 switch that does not sit flat and square to the board.[1]
- On the CX2600 the power switch is S101. Atari's flowchart replaces it when unregulated voltage reaches one side and not the regulator.[1]
Atari's static modifications add static strips to the switches: C017294 and C017297 on the CX2600 switchboard, and strips on the front-panel switches of CX2600A boards of Revs 1–13.[1]
Controller ports
[edit | edit source]The DE-9 ports oxidise, giving directions that do not register or an intermittent fire button. Spray contact cleaner into the port and insert and remove a plug several times. Tip 9: check J202 and J203 for pushed-back or broken pins and replace any that show problems.[1] A broken port is replaced with a PCB-mount DE-9.
Power
[edit | edit source]Power input
[edit | edit source]The console takes unregulated DC from an external adaptor, which Atari calls the "battery eliminator".[1] On the CX2600A the input is a 3.5 mm jack, J201 in the parts list; on the CX-2600A schematic the tip is positive and the sleeve grounded.[1][2] A barrel plug does not fit it.
Tip 8 in the manual's NTSC tech tips: with a game running, move the power plug in a small circle; if the picture goes off, replace the jack.[1] Reflow dull or cracked joints on the jack.
Voltage regulator
[edit | edit source]Regulation to +5 V is inside the console, by a 78M05 (Atari C014348, TO-220): A101 on the CX2600 switchboard, A203 on the CX2600A.[1]
| Point | Expected |
| Regulator input (A101 pin 1) | 7.5–9 V unregulated DC |
| Regulator output (A101 pin 3) | +5 V |
| J101 pin 1 (to the motherboard) | +5 V |
| J101 pin 2 | +9 V |
If +9 V is present at J101 pin 2 but +5 V is missing at pin 1, Atari's chart checks C101 for a short and otherwise replaces A101.[1]
When refitting the regulator, clean the old compound off the tab and the heatsink, apply a thin film of fresh compound, and tighten the fixing firmly. Tip 19: on early units with a standup regulator and heatsink, look for hairline cracks between the regulator and the switchboard, and make sure the regulator is held firmly by its Tinnerman clip.[1]
The 78M05 is a 500 mA part. A 7805 is the pin-compatible 1 A part. It does not run cooler: the dissipation is set by the input-to-output drop and the current the console draws.
Controllers
Joystick
[edit | edit source]Atari's section on game controllers describes the joystick as five calculator-type keypads on a small board, four under the stick and one under the button; a diagonal closes two at once. The earliest joysticks used five spring-loaded buttons, which Atari says cannot be repaired.[1] Clean the board and the contact domes with isopropyl alcohol and check each direction with a meter or a game.
Paddles
[edit | edit source]Each paddle is a 1 MΩ potentiometer.[1] Jitter comes from the track. Spray contact cleaner into the potentiometer and rotate it through its full range a number of times, or open it and clean the track. Replacement potentiometers need the right value and shaft.
Driving controller
[edit | edit source]The driving controller uses a switching device that produces a two-bit Gray code as it turns, not a potentiometer.[1] Clean its contacts with contact cleaner.
Cartridges
[edit | edit source]- Clean the contacts with a cotton bud and 99 % isopropyl alcohol. A pencil eraser shifts stubborn oxidation; do not use anything harder on the gold plating.
- On Atari cartridges with a spring-loaded dust cover, hold the cover open while cleaning and release it gently.
- Clean labels with a barely damp cloth. Alcohol can lift the print.
Replacement parts
[edit | edit source]| Part | Specification |
| Voltage regulator | 78M05 (Atari C014348), TO-220; a 7805 is pin-compatible[1] |
| Power input jack (CX2600A) | 3.5 mm jack, J201 (Atari 79-5918)[1][2] |
| Main reservoir capacitor | 2200 µF 16 V (C106 on the CX2600, C243 on the CX2600A)[1] |
| Cartridge connector | J200, 12/24 contacts[1] |
| Controller ports | DE-9, J202 and J203[1] |
| Capacitors generally | See Atari 2600 Capacitor Replacement Guide |
The TIA (A201) and the 6532 (A202) are Atari-numbered parts (C010444 and C010750); replacements come from donor consoles.[1]
[edit | edit source]- Atari 2600
- Atari 2600 Troubleshooting Guide
- Atari 2600 Capacitor Replacement Guide
- Atari 5200 General Maintenance
- Capacitor Failure Symptoms
- Recommended Tools
[edit | edit source]- ↑ 1.00 1.01 1.02 1.03 1.04 1.05 1.06 1.07 1.08 1.09 1.10 1.11 1.12 1.13 1.14 1.15 1.16 1.17 1.18 1.19 1.20 1.21 1.22 1.23 1.24 1.25 Atari, Inc., Video Computer System Field Service Manual, Domestic Model 2600/2600A, FD100133 Rev. 02. Section 1 (theory of operation), Section 3 (model modifications and checklist, pp. 3-2 to 3-6), Section 4 (flowcharts), Section 7 (game controllers), Section 8 (CX2600 and CX2600A parts lists), NTSC tech tips and service bulletins. Hosted here as Atari 2600 and 2600A Field Service Manual (PDF).
- ↑ 2.0 2.1 Atari, Inc., Video Computer System (Main Board) schematic, CX-2600A, sheet 2 of 4, 30 May 1982: external power jack (tip positive), 2200 µF 16 V reservoir, regulator and +5 V distribution. See File:Schematic Atari2600A 2000.png.
