Macintosh Performa 6310CD
Revision as of 13:26, 10 February 2026 by Josh (talk | contribs) (Convert redirect to full standalone article)
The Macintosh Performa 6310CD is a PowerPC-based desktop personal computer manufactured by Apple Computer, Inc. and released on February 14, 1996.[1] It is the European and Asian version of the Performa 6300CD, featuring identical specifications: a 100 MHz PowerPC 603e processor, 16 MB of RAM, a 1.2 GB IDE hard drive, and a 4X CD-ROM drive in a compact desktop case based on the Macintosh Quadra 630 form factor.
TypePersonal Computer
ReleasedFebruary 14, 1996
DiscontinuedOctober 1, 1996
Intro pricen/a
CPUPowerPC 603e @ 100 MHz
Memory16 MB RAM (expandable to 64 MB)
Storage1.2 GB IDE hard drive, 4X CD-ROM
DisplayDB-15 video output (640×480 16-bit, 800×600 8-bit)
SoundMonophonic input, stereo output
Dimensions4.3" H × 12.6" W × 16.5" D (10.9 × 32 × 41.9 cm)
Weight19 lbs (8.6 kg)
OS / FirmwareSystem 7.5.1 – Mac OS 9.1
PredecessorPerforma 6200CD
SuccessorPerforma 6360
Model no.M3076
The Performa 6310CD shares its logic board (Model M3076, Gestalt ID 42) with the Performa 6300CD and Performa 5300CD all-in-one system.
Hardware Overview
The Performa 6310CD is functionally identical to the Performa 6300CD:
  • Processor: PowerPC 603e at 100 MHz with integrated FPU
  • RAM: 16 MB standard via two 72-pin SIMM slots (80 ns), expandable to 64 MB
  • Storage: 1.2 GB IDE hard drive, 4X CD-ROM, 1.44 MB floppy
  • Video: 1 MB system RAM dedicated to video (640×480 16-bit, 800×600/832×624 8-bit)
  • Expansion: LC PDS slot, communications slot, video I/O slot, TV tuner slot
Regional Differences
Model Region Order Number Notes
Performa 6300CD North America Various Bundled with 15" monitor
Performa 6310CD Europe, Asia, Japan M4730J/A (Japan) International version
For detailed maintenance practices including cleaning, PRAM battery management, connector corrosion prevention, and voltage adjustments, refer to the dedicated Macintosh Performa 6300CD General Maintenance page.
Detailed capacitor replacement guidelines for the logic board can be found on the Macintosh Performa 6300CD Capacitor Replacement Guide page.
A comprehensive troubleshooting guide addressing no power, startup issues, video problems, and other common failures is available on the Macintosh Performa 6300CD Troubleshooting page.
Sub-system Specification (Macintosh Performa 6310CD, 1996)
CPU PowerPC 603e @ 100 MHz
Bus width 32-bit data (I/O) • 64-bit data (CPU)
ROM 4 MB
RAM 16 MB (expandable to 64 MB)
L1 Cache 32 KB
L2 Cache 256 KB
Video 640×480 16-bit, 800×600 8-bit
Sound Mono input, stereo output
Disks 1.2 GB IDE HDD, 1.44 MB floppy, 4X CD-ROM
Ports ADB, SCSI, 2× Serial, Audio I/O, Video out
Power Specifications
  • Input: 100V-240V AC, 50-60 Hz
  • Maximum power consumption: 55 Watts
  1. Macintosh Performa 6310CD Specs, EveryMac.com—link(accessed 2026-02-10)
