MacsBug Reference and Debugging Guide
The MacsBug Reference and Debugging Guide is Apple Computer, Inc.'s developer manual for MacsBug 6.2, published by Apple Developer Press, 1995 (© 1994, 1990 Apple Computer, Inc.). 410 pages, with full bookmarks and a text layer.
MacsBug is Apple's low-level assembly-language debugger for the 68 K Macintosh — the tool that catches a machine at the moment it crashes, below the level any application-level debugger reaches.
Contents
edit- Preface: About This Manual (p. xxi)
- 1. MacsBug and Low-Level Debugging (p. 1) — error handling on the Macintosh, why low-level debugging, new features in 6.2
- 2. Getting Started (p. 9) — installing MacsBug, installing under A/UX, displaying MacsBug on a different monitor (System 3.2–6.x and System 7.0 differ), the Debugger Prefs file, the MacsBug display regions (command line, PC, output, status/stack/register), invoking MacsBug — the programmer's switch, an 'FKEY' resource, or
DebugStrfrom source - 3. An Assembly-Language Primer (p. 33) — 68 K instruction syntax and every addressing mode
- 4. Macintosh Memory Organization (p. 65) — the memory map and its regions, using low-memory globals to draw a memory map, memory management under System 7, 32-bit addressing, virtual memory, registers, templates, the heap and heap blocks, and detecting a corrupted heap
- 5–6 — the stack and A-traps, Macintosh interrupts and code that runs at interrupt time, VBL tasks, the A-trap action table, the file system (drive queue, file control blocks, file I/O queue)
- 7. Debugging Strategies (p. 163) — before the crash and after it; the named failure modes "The Deep Freeze", "The Restart Surprise", "Nasty Pointers", "No Room to Maneuver"
- 8 — macros,
'mxbm'resources, dcmds and how to build one - 9. MacsBug Commands (p. 207) — the full command reference, alphabetically from ATB
What it is good for on this wiki
editA Macintosh that crashes reproducibly at a known address is diagnosable with this book and a keyboard, without opening the case. Chapter 7 is the part worth reading: it separates a software crash from a hardware fault by what the machine does at the moment of failure, which is exactly the question a repairer needs answered before desoldering anything.
Chapter 4's memory map and low-memory globals are also the reference behind the address interpretation used in Sad Mac Error Codes — though the Sad Mac codes themselves come from the ROM, not from MacsBug.
What it does not contain
editNo hardware information of any kind. No schematic, no part number, no component value, no voltage, no connector pinout. It is a software debugger manual. Do not cite it for a hardware figure.
edit- Sad Mac Error Codes · Sad Mac Decoder · Diagnostic Serial Console
- Category:Apple Programming Documentation
- Programmers Guide to MPW 1990 — Apple's command-line development environment, the toolchain MacsBug was used beside (that page's file was never uploaded)
- Programming For System 7 1991 — the System 7 memory model this manual's chapter 4 describes from the debugger's side
Download the MacsBug Reference and Debugging Guide here: MacsBug Reference and Debugging Guide.pdf (1.5 MB)
