Help:Photographing hardware
Revision as of 22:10, 26 March 2026 by Josh (talk | contribs) (Created Help:Photographing hardware guide)
📷 Photographing Hardware
How to Take Great Photos for RTC Wiki Articles
Good photographs are essential for repair guides, board documentation, and component identification. This guide covers best practices for photographing vintage computer and console hardware.
Equipment
You don't need professional equipment — a modern smartphone camera is sufficient for most documentation. However, the following will improve your results:
Equipment Why It Helps
Macro lens (or phone macro attachment) Close-up shots of components, solder joints, and IC markings
Tripod or phone stand Eliminates camera shake for sharp images, especially at high zoom
Diffused lighting (desk lamp with white shade) Eliminates harsh shadows and hot spots on reflective PCBs
Anti-static mat (coloured background) Clean background, ESD protection, consistent appearance
Compressed air Clean dust before photographing
Board Photography
Full Board Shots
  • Clean the board first — use compressed air and IPA to remove dust and flux residue
  • Shoot from directly above (perpendicular to the board) for documentation photos
  • Fill the frame — the board should occupy most of the image
  • Use even lighting from both sides to avoid shadows under tall components
  • Include a ruler or coin for scale reference when photographing unfamiliar boards
  • Shoot BOTH sides — top and bottom of every PCB
Component Close-ups
  • Focus on the IC markings — these are the most useful identification feature
  • Use macro mode to capture part numbers, date codes, and manufacturer logos
  • Capacitor photos: capture any bulging, leaking, or corrosion. Show the polarity markings
  • Solder joint photos: get close enough to see cracked, cold, or dry joints
Board Revision Identification
  • Always photograph the board revision number printed on the PCB silkscreen
  • Capture date codes stamped on the board or major ICs
  • Include serial number stickers where present
Photographing for Repair Guides
Before/After Shots
  • Take a before photo showing the fault (e.g., bulging caps, corrosion, broken traces)
  • Take an after photo showing the completed repair
  • Use the same angle and lighting for both shots
Step-by-Step Documentation
  • Photograph each major step of a repair procedure
  • Annotate photos with arrows or circles highlighting the relevant area (use any image editor)
  • Include tool in frame when demonstrating a technique (e.g., soldering iron on a joint)
Photo Settings
Setting Recommendation
Resolution At least 2000×1500 pixels (higher is better for cropping)
Format JPEG is fine for most uses; PNG for screenshots or diagrams
White balance Set to match your lighting (auto usually works)
Flash OFF — use external lighting instead. Flash creates harsh reflections on PCBs
ISO Keep as low as possible (100-400) to reduce noise
Uploading to the Wiki
  • Use Special:Upload to upload your photos
  • Naming convention: Console_Name_Board_Revision_Description.jpg
    • Example: GameCube_DOL-CPU-30_Logic_Board_Top.jpg
  • Add a descriptive summary when uploading
  • Categorise your images (e.g., [[Category:Nintendo]])
  • Use [[File:Name.jpg|thumb|center|250px|Caption]] to embed in articles
Common Mistakes
  • ❌ Blurry photos — use a tripod/stand and good lighting
  • ❌ Flash reflections on PCB solder mask — use diffused external light
  • ❌ Cluttered background — use a clean mat or plain surface
  • ❌ Too far away — fill the frame with the subject
  • ❌ Missing scale reference — include something for size comparison
  • ❌ Only photographing one side — always shoot both sides of a PCB
