Acorn Risc PC 600 Troubleshooting Guide
This guide gives diagnosis for the Acorn Risc PC 600 (ARM610, board 0197,000). It uses the Power On Self Test (POST), the on-board diagnostics and the parts/electrical data in the Acorn Risc PC Technical Reference Manual, which also contains the full circuit diagrams (Appendix C).[1]
⚠️ Mains warning
The Risc PC has a fan-cooled mains PSU in the base slice. Disconnect the mains lead before removing the cover. The PSU primary side is at mains potential; do not open the PSU module unless competent with mains switch-mode supplies (discharge the primary bulk capacitor first).
The Risc PC always runs a POST immediately after power-on. The progress is shown by the screen colour, and a failure is signalled both on screen (red) and by the floppy-disc LED flashing an 8-digit hexadecimal fault code.[1]
Normal sequence (screen colour):
- Purple — testing has started; brief ROM and RAM tests run, then IOMD and VIDC20 are initialised and tested. This phase is quick. A crash or halt here, with no further activity, indicates a major fault, most likely in the I/O system.
- The screen mode is set from the video ID[0] pin: VGA if a VGA/SVGA/Multiscan monitor pulls ID low, otherwise a 15 kHz TV-style mode. If no stable display appears, suspect the monitor connection, a video fault, or a fundamental fault preventing the test software from running.
- Blue — a more extensive memory test, then brief video and sound tests.
- Purple again — the ARM processor ID is read (needs good RAM).
- Green (pass) or Red (fail). On a pass the green screen is usually not seen, because RISC OS starts immediately and shows a black screen with the memory-size message. On a fail, the screen stays red and the floppy LED flashes the fault code.
Reading the LED code: the 8-digit hex code is flashed as 8 groups of 4 flashes; a long flash = 1, a short flash = 0. For example a ROM failure on an ARM610 machine is code 00000219.[1]
| Code | Meaning | First-look |
| 00000200 | ROM failed checksum | Reseat/replace the RISC OS ROMs; check ROM data/address lines |
| 00001000 | IOC register test failed | IOMD or its bus; check seating and tracks |
| 00004000 | VIDC (Virq interrupt) timing failed | VIDC20 or its clock/interrupt path |
| 00008000 | Sound (Sirq interrupt) timing failed | VIDC20 sound / sound DMA path |
| 00010000 | CMOS unreadable | I²C path to the CMOS/RTC; battery/clock circuitry |
| 00020000 | RAM control line failure | Classic leaked-electrolyte symptom — inspect/recap and repair corroded RAM-control tracks; reseat SIMMs |
| 00040000 | Long RAM test failure | Faulty SIMM; substitute |
| Code | Meaning |
| 00000001 | Self-test due to power-on |
| 00000040 | Integrated I/O controller fitted |
| 00000080 | VRAM present |
| 00000100 | CMOS RAM checksum error |
A POST interface box (plugged into the parallel/printer port) shows each test and a PASS/FAIL bitmap on an LCD, running the tests slowly so the screen-colour phases are clearly visible.[1]
First: power
If the machine is completely dead:
- Disconnect the mains lead and check the mains-plug fuse.
- With the lid open (mains reconnected, take care), confirm the PSU rails and that the PSU fan runs. A dead rail points to the PSU module.
- Check the on-board fuses FS1 (2 A) and FS2 (800 mA) for continuity — a subsystem dead with the main rails present is often a blown on-board fuse.[1]
Always suspect leaked electrolyte
On a Risc PC, intermittent and progressive faults are frequently leaked surface-mount electrolytic capacitors rather than a failed IC. The POST RAM control line failure (00020000) code in particular is the classic result of leaked electrolyte corroding the RAM-control tracks. Inspect the board under magnification for crusty residue and discoloured pads around the surface-mount electrolytics before deeper diagnosis; recapping and cleaning often clears otherwise-baffling faults — see Acorn Risc PC 600 Capacitor Guide.
Symptom table
| Symptom | Probable cause | Action |
| Completely dead | Mains fuse, PSU, or on-board fuse | Check plug fuse, PSU rails/fan, FS1/FS2 |
| Stays on a purple screen / crashes early in POST | Major I/O-system fault (IOMD) or RAM | Inspect for leaked electrolyte; reseat SIMMs; check IOMD |
| Red screen, floppy LED flashing | POST fault — read the code | Decode the 8-hex LED code (table above) |
| No stable display, machine otherwise alive | Monitor/cable, video ID pin, or VIDC20 | Try a known monitor; check the VGA connector; verify VIDC20 |
| Random crashes, RAM errors (code 00020000/00040000) | Leaked electrolyte on RAM control lines, or a bad SIMM | Recap and clean; reseat/substitute SIMMs |
| Lost configuration / wrong clock | Flat or leaked NiMH battery (BT1) | Clean corrosion, repair tracks, replace cell |
| No / distorted sound (code 00008000) | VIDC20 sound path or leaked audio-stage caps | Recap; check the sound DMA path |
| Hard disc not found | IDE cable/power or dead drive | Reseat the cable; replace the drive (mind the RISC OS 3.5 ~512 MB limit) |
| One subsystem dead, rails present | Blown on-board fuse | Check FS1/FS2 |
| Won't start with a second CPU/PC card fitted | CPU-card seating or a faulty card | Reseat; test with the primary CPU card only |
CPU card, SIMMs and VRAM
The processor is on a plug-in card in one of two CPU sockets (the second socket takes a second processor or an x86 PC card). A machine that will not start should be retested with only the primary CPU card fitted, the card reseated, and the DRAM SIMMs and VRAM reseated. The POST reads the ARM ID late in the sequence, so a CPU-card or RAM fault often shows as a hang on the second purple phase.[1]
Storage and ports
- Hard disc not detected: check the 40-way IDE cable and drive power; reseat. RISC OS 3.50 limits ADFS discs to about 512 MB.
- Floppy: clean the head and try a known-good disc before suspecting the FDC37C665 'Combo' controller.
- Serial/parallel: handled by the FDC37C665; check the connector and the controller.
- Expansion: clean the podule backplane connector and the network-card slot; a machine that misbehaves only with a card fitted usually has a dirty or shorted contact.
Common fault catalogue
- Completely dead — mains fuse, PSU module, or on-board FS1/FS2.
- Crashes early (purple), or RAM-control fault (00020000) — leaked surface-mount electrolytics on the RAM control lines; recap and clean (the most common Risc PC cause).
- ROM checksum fault (00000200) — reseat/replace the RISC OS ROMs.
- VIDC/sound timing faults (00004000/00008000) — VIDC20 path; check after a recap.
- Lost time/config — flat or leaked NiMH battery (BT1).
- No display — monitor/cable, video ID pin, or VIDC20.
- No hard disc — IDE cable/power or a dead drive.
- Subsystem dead, rails good — blown on-board fuse FS1/FS2.
- Acorn Risc PC 600
- Acorn Risc PC 600 Maintenance Guide
- Acorn Risc PC 600 Capacitor Guide
- Acorn Risc PC 700 Troubleshooting Guide
- Acorn Risc PC Technical Reference Manual · Capacitor Failure Symptoms
- ↑ 1.0 1.1 1.2 1.3 1.4 1.5 Acorn Risc PC Technical Reference Manual (Issue 1, September 1994; part 0497,057), Acorn Computers — hosted on this wiki. Source for the Power On Self Test sequence and fault/status codes, the on-board fuses FS1 (2 A) and FS2 (800 mA), the NiMH battery, the IOMD/VIDC20/FDC37C665 architecture, the engineering drawings (Appendix C) and the main-PCB parts list.
