Acorn System 5
Revision as of 21:53, 17 June 2026 by Josh (talk | contribs) (Create Acorn System series page (cited; sourced from System manuals/catalogue))
Acorn System 5
Acorn System 5 (front): Eurocards on the left, two 5.25" drives on the right
TypeModular microcomputer (Eurocard)
ReleasedLate 1982 (handbook dated 1 March 1983)
CPU6502 @ 1 MHz (2 MHz 6502A option)
Memory32 KB DRAM (standard), expandable
StorageTwo 5.25" floppy disc drives, disc controller (Intel 8271)
Display80×25 or 40×25 teletext VDU
Sound
OS / FirmwareAcorn DOS
PredecessorAcorn System 4
SuccessorAcorn Atom / BBC Micro (home line)
The Acorn System 5 was the last of Acorn's rack-mounted Eurocard machines, released in late 1982. It was housed in an extra-height single 19-inch frame holding two vertically-mounted 5.25-inch floppy drives and either seven or ten Eurocard slots, and was supplied complete with a power supply, fully assembled only.[1] After the System 5, Acorn sold the Eurocard business to its reseller Control Universal.
Configuration
As standard the System 5 had a 1 MHz 6502 (a 2 MHz 6502A board was an option), 32 KB of DRAM, a floppy-disc controller and either the 80×25 or the 40×25 teletext VDU card; the remaining slots could take interface cards, a further 16 KB DRAM card and/or an Econet adapter.[1][2] A documented System 5 (an ex-school Econet server) has a 2 MHz 6502A card, an 80×25 VDU card, 32K DRAM cards, an Econet card and an Intel 8271 floppy-controller card driving two 80-track drives.
Maintenance and repair
  1. 1.0 1.1 "Acorn System", Wikipedia. Source for the System 5 frame (7 or 10 slots, two vertical 5.25-inch drives), the standard configuration (1 MHz 6502, 32K DRAM, disc controller, 80×25 or 40×25 VDU), the 2 MHz 6502A and Econet options, and the late-1982 release.
  2. Whytehead, Chris. "Acorn System 5", Chris's Acorns / The Centre for Computing History. Source for the 10-slot card cage, the example configuration (2 MHz 6502A CPU, 80×25 VDU, 32K DRAM cards, Econet, Intel 8271 floppy controller, two 80-track drives) and the System keyboard plugging into the CPU card.
