Macintosh Plus Capacitor Replacement Guide
๐ Capacitor Inspection
Before replacing capacitors, inspect each one for signs of deterioration:
- Bulging Tops โ Capacitors should have a flat top. Swelling or doming indicates failure.
- Leaking Electrolyte โ A brown or white crust around leads shows electrolyte leakage.
- Corrosion or PCB Staining โ Indicates internal leakage and should prompt immediate replacement.
๐ Macintosh Plus Capacitor List
๐งฏ Analog Board Capacitors
The Macintosh Plus analog board contains many large electrolytic capacitors that should be replaced proactively:
| C1 | 3.9ยตF | 35V | 1x |
| C2 | 4700ยตF | 16V | 1x |
| C3 | 220ยตF | 16V | 2x |
| C5 | 47ยตF | 10V | 1x |
| C6 | 22ยตF | 50V | 2x |
| C10 | 33ยตF | 16V | 2x |
| C11 | 10ยตF | 160V | 1x |
| C12 | 22ยตF | 50V | 2x |
| C18 | 33ยตF | 16V | 2x |
| C24 | 2200ยตF | 16V | 4x |
| C27 | 2200ยตF | 16V | 1x |
| C28 | 1000ยตF | 16V | 1x |
| C30 | 2200ยตF | 16V | 1x |
| C31 | 220ยตF | 16V | 1x |
| C32 | 2200ยตF | 16V | 1x |
| C33 | 4700pF | 250V | 2x |
| C34 | 100ยตF | 200V | 4x |
| C35 | 100ยตF | 200V | 1x |
| C36 | 4700pF | 250V | 1x |
| C37 | 0.47ยตF | 250V | 1x |
| C38 | 100ยตF | 200V | 1x |
| C39 | 100ยตF | 200V | 1x |
| C42 | 470ยตF | 10V | 2x |
| C45 | 470ยตF | 10V | 1x |
๐ง Logic Board Capacitors
The Macintosh Plus logic board contains fewer electrolytic capacitors than the analog board but they are still critical for operation.
| C5 | 33ยตF | 16V | 1x |
| C20 | 33ยตF | 16V | 1x |
| C22 | 4.7ยตF | 35V | 1x |
๐ ๏ธ Capacitor Replacement Procedure
- Discharge CRT โ Safely discharge the CRT before any internal work.
- Remove Boards โ Label and disconnect cables; remove analog and logic boards.
- Desolder Old Caps โ Use a soldering iron, wick, or pump to cleanly remove components.
- Insert Replacements โ Observe correct polarity (marked with a stripe).
- Solder Securely โ Ensure joints are shiny, clean, and well-adhered.
- Trim Leads & Inspect โ Trim excess leads and double-check all work.
- Check for Shorts โ Use a multimeter to verify no shorts before powering on.
๐งฐ Recommended Tools
- Temperature-controlled soldering iron
- Desoldering pump or braid
- Fine leaded solder (0.5 mm)
- Isopropyl alcohol & ESD brush
- Multimeter
- Safety glasses & gloves
โ๏ธ Voltage Adjustment After Recap
Use a multimeter to verify voltages at the floppy drive power connector:
- +5V rail: 4.85V โ 5.15V
- +12V rail: 11.9V โ 12.7V
๐ก Additional Tips
- Power the Mac periodically to prolong capacitor life.
- Use brand-name capacitors (e.g., Nichicon, Panasonic, Rubycon).
- Replace in groups or full sets for best results.
- Always verify polarity and double-check each joint.
- Dispose of old capacitors via proper e-waste channels.
