Psion Series 3a
Revision as of 23:48, 8 September 2026 by Josh (talk | contribs) (Create Psion page set: researched from Psion manuals, service documentation and community repair sources)
Psion Series 3a
A Psion Series 3a
DeveloperPsion PLC
ManufacturerPsion PLC
TypeClamshell palmtop / PDA
Released1993
Discontinued1998
Intro priceFrom £269 (256 KB, 1993)
CPUNEC V30H @ 7.68 MHz, integrated into Psion's ASIC9
Memory1 MB ROM; 256 KB, 512 KB, 1 MB or 2 MB RAM
StorageTwo internal Solid State Disk (SSD) slots
Display480 × 160 monochrome LCD with a grey plane
SoundMembrane speaker, built-in microphone, 12-bit sound recording
Dimensions165 mm × 85 mm × 22 mm
Weight275 g including batteries
OS / FirmwareEPOC16 (SIBO), with OPL
PredecessorPsion Series 3
SuccessorPsion Series 3c
Model no.Also sold as the Psion Series 3aR (Russian) and the Acorn Pocket Book II
The Psion Series 3a is the 1993 development of the Psion Series 3, and the machine most people mean when they say "Psion 3". It doubled the processor speed, gave the screen 67 % more area and a grey plane, and added sound recording — while keeping the same case, the same two AA cells and the same 80-hour battery life.[1]
Internally it is the first machine to use ASIC9, the Psion custom chip that folds the V30H processor and the earlier ASIC1 and ASIC2 support chips into one device.[2]
Psion Series 3a specification[1][3]
Item Specification
Processor NEC V30H (80C86-compatible, 16-bit) at 7.68 MHz, inside Psion's ASIC9
ROM 1 MB
RAM 256 KB or 512 KB at launch; 1 MB and 2 MB added in 1995
Display 480 × 160 monochrome LCD with an additional grey plane. No backlight.
Keyboard 58-key QWERTY plus 8 reprogrammable application buttons
Sound Membrane speaker, built-in microphone, 12-bit sound recording (uncompressed, about 8 KB per second)
Storage Two internal SSD slots (RAM, Flash I and Flash II packs)
Serial RS-232C at 19,200 bit/s via the 3Link pod
Main power 2 × AA cells, about 80 hours
Backup power CR1620 lithium coin cell
External power 9 V, 150 mA
Size and weight 165 × 85 × 22 mm, 275 g with batteries
ASIC9
The Series 3 and its MC and HC siblings used three chips — the V30H, ASIC1 (the system controller, about 4300 gates in a 100-pin flat pack) and ASIC2 (the clock, keyboard, buzzer, SSD and power-supply interface, about 2200 gates in an 80-pin flat pack). ASIC9 integrates all three.[2]
That integration bought several things that matter when you are working on a 3a:[2]
  • Double the clock speed. The Series 3 was held to 3.84 MHz because ASIC1 assembled each 16-bit word from two 8-bit ROM reads, needing about 250 ns ROM. ASIC9 does 16-bit accesses, so the same 200 ns mask ROM supports 7.68 MHz.
  • Bank-switched memory beyond the V30H's 1 MB limit, through four page registers PSEL0–PSEL3, giving a 16 MB RAM space and a 16 MB ROM space.
  • A hardware 32-bit real-time clock clocked at 1 Hz. On the earlier ASIC1/ASIC2 machines the CPU had to wake periodically to keep time, and if it could not start — no main batteries — the time was lost. The 3a keeps time independently.
  • Hardware wait on pack access, which stops the CPU clock automatically when the serial controller is busy instead of polling for it.
  • Switch-on from the membrane key pads, not just the on key.
  • Improved grey scale: the second video map became an attribute map that dims only set pixels.
Power rails
SIBO machines run four power states — standby, backup, idle and operating — and the supply generates a set of named rails. Knowing what each does turns a dead machine into a traceable fault.[2]
SIBO supply rails[2]
Rail Purpose Notes
Vcc1 ASIC9 and all the memory — present in every state Nominally 3.3 V on ASIC9 machines. Current-limited to a few hundred microamps in standby. Powered from the backup cell in the backup state.
Vcc2 The processor and anything that can shut down Fixed at 5 V even in a 3.3 V system. Off in standby, on automatically in idle or operating.
Vcc3 The LCD module and its display drivers Software switchable, 5 V or 3.3 V
Vcc5 The 5 V pin on the external SSD slots Software switchable
Vee1 LCD bias — the contrast rail Software switchable negative rail from a flyback converter. Contrast is set by a DAC in software, not by a potentiometer.
Vh +16 V programming voltage for Flash SSDs Software switchable flyback converter. Needed to write and format Flash packs — not to read them.
Keyboard, buzzer and NMI
The keyboard is a matrix scanned by driving each column high in turn and reading the rows; the interface supports up to 16 rows × 12 columns, though 8 × 12 is normal.[2]
A watchdog counts up at 4 Hz and raises an NMI if it is not reset — about 0.75 seconds with interrupts disabled. NMIs are also generated by power-fail and by the SSD and expansion-port door microswitches.[2] That last point explains why door switches matter so much on these machines.
Inside
A German-keyboard 3a. The icon strip above the keyboard is the button bar — a separate PCB with its own ribbon cable to the mainboard, and one of the two commonest fault points on the machine.
The mainboard carries the large square Psion custom ASIC on the left, the ROM at the far right, and the SRAM devices inboard of the ROM. A 256 KB machine has two SRAMs fitted and spare solder pads for two more — which is what makes the 512 KB upgrade possible.[4]
Fitting two more SRAMs takes a 256 KB machine to 512 KB. The original devices were Sony parts; at least one attempt with Hitachi 628128 devices produced a "Memory corruption" message, which suggests the substitute was not compatible.[4]
Variants
  • Psion Series 3aR — a Russian-market machine with Russian software in ROM. All other Series 3 models shipped with English software in ROM and were localised by installing software.[1]
  • Acorn Pocket Book II — Acorn's rebadged 3a for schools, in 256 KB, 512 KB and 1 MB versions. Agenda was renamed Schedule and a Plotter graphing application was added.[1]
Solid State Disks
The two bays take Psion SSD packs, in two families:[1]
  • RAM SSDs need their own button cell to hold data, but can be rewritten freely.
  • Flash SSDs (Flash I and Flash II) need no cell and were cheaper per megabyte, but space from deleted or modified files is not reclaimed until the whole pack is reformatted — every change writes a new copy of the file into the remaining space.
That makes RAM packs the better choice for data that changes often, and Flash packs the better choice for archives.
Known problems
The Series 3 clamshell has three documented weak points, all of which the Psion Series 3a Troubleshooting Guide covers in detail:[1]
  • Breakage of any of the four hinges
  • Loss of function in the button bar between the two halves of the clam
  • Deterioration of the cable linking the keyboard half to the screen, producing vertical lines on the display
General maintenance
Batteries, the battery lead, the SSD slots and how you open the lid are what determine whether a 3a survives. See the Psion Series 3a General Maintenance guide.
See the Psion Series 3a Troubleshooting Guide.
Hinge repair
All four hinges can be repaired, and the procedure is documented step by step. See the Psion Series 3a Hinge Repair guide.
  1. 1.0 1.1 1.2 1.3 1.4 1.5 "Psion Series 3", Wikipedia. Source for the model history and dates, screen resolutions, RAM options, the 1995 revision, the 3aR and Acorn Pocket Book variants, the DTMF dialling feature, the SSD bay arrangement, and the documented hinge, button-bar and screen-cable problems.
  2. 2.0 2.1 2.2 2.3 2.4 2.5 2.6 Psion PLC, SIBO Hardware Reference, version 2.10, 3 February 1995, published in the Psion Documentation Project. Source for the SIBO architecture, ASIC1/ASIC2/ASIC9, the memory decoding and bank switching, the interrupt allocation, the keyboard and buzzer interfaces, the watchdog, the NMI sources, the power states and every supply rail described on this page.
  3. "Psion specifications", netogram.com. Source for the comparative specification figures for the Series 3, 3a, 3c and Siena, including ROM sizes, keyboard layouts, serial speeds, external power requirements and weights.
  4. 4.0 4.1 David Kimberlin-Wyer, "Psion Series 3a Memory Upgrade", primrosebank.net. Source for the 18-step disassembly procedure, the board layout, the spare SRAM pads, the two keyboard membrane types and the reassembly caution about the bowed button bar.
