Macintosh Centris 650 Capacitor Replacement Guide
Revision as of 21:52, 21 September 2026 by Josh (talk | contribs) (Verification drive: flag unverified component data pending check against a primary source)
This guide covers capacitor replacement for the Macintosh Centris 650 and Macintosh Quadra 650. These systems share the same logic board and power supply design.
Important: Logic Board Uses Tantalum Capacitors
Unlike most Macintosh computers from the early 1990s, the Centris/Quadra 650 logic board uses tantalum capacitors instead of electrolytic capacitors. This is significant because:
  • Tantalum capacitors do not leak – They won't cause the corrosive damage seen in systems like the Macintosh IIsi or LC series
  • Preventive recapping is not required – You don't need to replace the logic board capacitors as a maintenance measure
  • Tantalum caps can fail differently – When they fail, they may short-circuit, sometimes with smoke or flame (rare)
The power supply unit (PSU), however, contains standard electrolytic capacitors that may need replacement.
Capacitor Inspection
Even though the logic board doesn't need preventive recapping, inspect both the logic board and power supply periodically:
Logic Board Inspection
  • Burn marks – Look for discoloration or charring near tantalum capacitors
  • Failed tantalum caps – May show visible damage or burn marks
  • Corrosion – Check for PRAM battery leakage (different from cap leakage)
Power Supply Inspection
  • Bulging Tops – Capacitors with domed tops have failed and must be replaced
  • Leaking Electrolyte – Brown or black residue around capacitor bases
  • Corrosion or PCB Staining – Electrolyte may spread across the PCB
  • Swelling – Any expansion of the capacitor body indicates failure
Power Supply Capacitor Replacement
The power supply contains electrolytic capacitors that degrade over time. If your Centris/Quadra 650 exhibits power issues, PSU recapping may be necessary.
Warning: The power supply contains high-voltage capacitors that can retain dangerous charge. Discharge the supply properly before servicing.
Common PSU Capacitor Values
Exact values vary by PSU revision. Common capacitors found include:
Typical Power Supply Capacitors
Capacitance Voltage Type Notes
1000µF 10V Electrolytic Secondary filtering
470µF 25V Electrolytic Secondary filtering
220µF 25V Electrolytic Various
100µF 25V Electrolytic Various
47µF 50V Electrolytic Various
10µF 50V Electrolytic Various
1µF 50V Film/Ceramic Replace with equivalent
Note: Open your specific PSU and document the capacitor values before ordering replacements. Values may differ between PSU revisions.
Logic Board Tantalum Capacitors
The logic board uses surface-mount tantalum capacitors. These do not need preventive replacement. If one fails (rare), replace only the failed component.
Signs of Tantalum Capacitor Failure
  • System won't power on (dead short)
  • Visible burn marks on or near the capacitor
  • Burning smell when system is powered
  • Smoke from logic board (power off immediately!)
Tantalum Replacement Procedure
If a tantalum cap fails and must be replaced:
  1. Identify the failed capacitor – Look for burn marks or measure with ESR meter
  2. Note polarity – Tantalum caps are polarized; mark orientation before removal
  3. Remove with hot air or soldering iron – Use appropriate SMD rework technique
  4. Clean pads – Remove residue with flux and solder wick
  5. Install replacement – Observe correct polarity
  6. Use quality replacements – Consider polymer tantalum or equivalent-value ceramic capacitors
Power Supply Capacitor Replacement Procedure
  1. Discharge the PSU – Wait 24+ hours after unplugging, or use a discharge tool
  2. Document capacitor locations – Photograph before removal
  3. Remove old capacitors – Use desoldering pump or wick
  4. Clean pads – Remove residue with isopropyl alcohol
  5. Install replacements – Observe correct polarity (stripe indicates negative on electrolytics)
  6. Use quality capacitors – Nichicon, Panasonic, Rubycon, or equivalent
  7. Solder securely – Ensure good solder flow
  8. Inspect work – Check for solder bridges or cold joints
  9. Test before reassembly – Verify voltages before connecting to logic board
  • Temperature-controlled soldering station (adjustable 300-400°C)
  • Desoldering pump or desoldering braid
  • Fine solder (0.5-0.8mm diameter, leaded preferred for vintage work)
  • Isopropyl alcohol (90%+) and ESD-safe brushes
  • Flux (no-clean or water-soluble)
  • Multimeter with capacitance testing
  • ESR meter (optional but helpful)
  • Safety glasses
  • Heat-resistant gloves
  • Capacitor discharge tool or resistor (for PSU)
Voltage Verification After Recap
After recapping the PSU, verify output voltages before connecting to the logic board:
  • +5V rail: 4.85V – 5.15V
  • +12V rail: 11.9V – 12.7V
  • -12V rail: -11.9V – -12.7V
Additional Tips
  • Order extra capacitors – Having spares saves time
  • Match or exceed voltage ratings – 25V cap can be replaced with 25V or higher
  • Match capacitance exactly – Don't substitute higher or lower values
  • Consider cap kits – Some vendors sell complete recap kits
  • Work in a well-ventilated area – Soldering fumes should be exhausted
  • Take your time – Rushing leads to mistakes
