Amstrad CPC 664 Capacitor Replacement Guide
Capacitor replacement for the Amstrad CPC 664.
Every value on this page is taken from Amstrad's own Electrical Parts List for the CPC664 in the service manual hosted on this wiki.[1]
⚠️ Safety
The computer runs from a low-voltage supply, but the CTM644 colour monitor and GT65 green monitor contain a CRT and mains-derived high voltage that persists after switch-off. See CRT Discharge Procedure before opening either. This page covers the computer.
Electrolytic capacitors
| Value | Circuit reference | Amstrad part no. |
| 100 µF / 16 V | C315 | 20028 |
| 100 µF / 10 V | C301, C304 | 20028 |
| 47 µF / 10 V | C129, C303, C306 | 1400244 |
| 22 µF / 10 V | C308 | 20025 |
| 1 µF / 50 V | C309, C311, C314, C316, C317 | 20062 |
Eleven electrolytics across five values — a smaller complement than the 464's thirteen.
Ceramic capacitors
| 0.1 µF / 16 V | C101–C128, C201–C213 | 24020 |
| 470 pF / 50 V | C307 | 24004 |
| 270 pF / 50 V | C313 | 900400 |
| 220 pF / 50 V | C133–C135, C310 | 400107 |
| 68 pF / 50 V | C130, C131 | 170826 |
| 47 pF / 50 V | C132 | 24002 |
Note the C201–C213 block — those are on the disk interface section, which the 464 does not have.[1]
Polystyrene capacitors
| 0.1 µF | C319 | 170852 |
| 0.068 µF | C302 | 170219 |
| 0.047 µF | C318 | 1409178 |
| 0.01 µF | C305 | 170218 |
| 0.001 µF | C312 | 170217 |
Polystyrene capacitors deform at soldering temperatures that an electrolytic shrugs off. Work quickly and keep the iron off the body.
A note from Amstrad on the disk PCB
The parts list carries an explicit instruction: no part numbers are given for any parts on that PCB, and Amstrad directed service agents to return the board complete for replacement rather than repair it to component level.[1] That is Amstrad's position in period, not a statement that the board is unrepairable today — but it does mean this manual will not give you component values for the disk PCB.
Before you start
- Read the value off your own board before ordering. Part numbers above are for cross-reference and do not imply availability.
- Anti-static precautions throughout.
- See Capacitor Failure Symptoms and Recommended Tools.
- Amstrad CPC 664 · Amstrad CPC 664 Maintenance Guide · Amstrad CPC 664 Troubleshooting Guide
- Amstrad CPC 464 Capacitor Replacement Guide — the sibling machine, with a different complement
- Amstrad CPC 664 Service Manual — the source for every value on this page
- Capacitor Failure Symptoms · Recommended Tools · CRT Discharge Procedure
