Power Macintosh/Performa 5000 Series Service Source
Revision as of 08:28, 25 September 2026 by Josh (talk | contribs) (P4 verification: turn document holder into a real documentation page (contents with PDF page numbers, Apple's own specifications, honest gaps, citing pages))
The Power Macintosh/Performa 5000 Series volume of Apple's Service Source is a 309-page service manual covering the Power Macintosh 5400/120, 5400/180, 5400/200 and 5500/225, and the international Performa 5400/160, 5400/180, 5420 and 5420/180. The PDF was distilled on 1 May 1997.
The cover title is wider than the contents. Despite being titled “5000 Series”, this volume covers only the 5400 and 5500; Apple's own Basics chapter is headed “Power Macintosh/Performa 5400 and 5500 Series”. The 5200/5300 and the 5260/5280 have their own volumes.
Service Source volumes are module-level documents. They give Apple's own specifications, symptom charts, take-apart procedures and module part numbers, but they do not carry schematics, board-level parts lists or component values, so they cannot be used to source a capacitor table. Where a figure below is quoted, it is quoted as Apple printed it.
Specifications as Apple prints them
Item As printed
CPU, 5400/120 PowerPC 603e at 120 MHz
CPU, 5400/160 PowerPC 603e at 160 MHz
Line voltage 100–240 VAC
Frequency 47–63 Hz
Power 125 W
Surge and inrush surge voltage 300 V RMS for 100 ms; peak inrush current 40 A pk; 2.5 A maximum; 220 W maximum for all line and load conditions
Battery replace if below 3.0 V, measured with the I/O door and logic board removed
Contents
Reconstructed from the manual's own running headers; page numbers are positions in the PDF, so a citation can be checked directly.
  • Basics — System Overview (pdf p. 3), Rev. B, 5000 Series (pdf p. 4), Configurations (pdf p. 5), Service Strategy (pdf p. 15), User Controls (pdf p. 18), Internal Expansion Connections (pdf p. 19), Intelligent Device Electronics (IDE) Hard Drive (pdf p. 20), Video-In Card (pdf p. 21), TV Tuner Module (pdf p. 22), Digital Audio Video (DAV) Technology (pdf p. 27), External Video Connector (pdf p. 29), Apple Presentation System (pdf p. 30), Peripheral Component Interconnect (PCI) (pdf p. 31), GeoPort Technology (pdf p. 32), The Cuda Chip (pdf p. 34), Dual In-Line Memory Modules (DIMMs) (pdf p. 35), CRT and Degauss Frame (pdf p. 38), Front View (pdf p. 39), Rear View (pdf p. 40), I/O Panel (pdf p. 41), 5400/5500 Logic Board (pdf p. 42)
  • Specifications — Introduction (pdf p. 44), Processor (pdf p. 45), Memory (pdf p. 47), Disk Storage (pdf p. 50), I/O Interfaces (pdf p. 52), I/O Devices (pdf p. 56), Sound and Video (pdf p. 58), Electrical (pdf p. 66), Physical (pdf p. 67), Environmental (pdf p. 68)
  • Troubleshooting — General (pdf p. 70), First Checklist (pdf p. 71), Symptom Charts (pdf p. 72)
  • Take Apart — Drive and Control Bezel (pdf p. 99), Floppy Drive (pdf p. 102), CD-ROM Drive (pdf p. 106), Front Panel Control Board (pdf p. 110), I/O Door (pdf p. 115), Logic Board (pdf p. 118), Video Card (pdf p. 124), PCI Adapter (pdf p. 125), NTSC Video-Out Card (5500) (pdf p. 126), Rear Housing (pdf p. 128), Front Bezel (pdf p. 132), Internal Microphone (pdf p. 136), Rear EMI Shield (pdf p. 138), Speakers, Original Version (pdf p. 141), Speakers, Rev. B (pdf p. 145), Hard Drive (pdf p. 150), TV Tuner (pdf p. 154), Power Supply, Original Version (pdf p. 157), Power Supply, Rev. B (pdf p. 169), Video Board (pdf p. 173), Analog Shield (pdf p. 177), Analog Board, Original Version (pdf p. 180), Analog Board, Rev. B (pdf p. 188), Internal RGB Cable (pdf p. 192), Fan (pdf p. 194), Tilt/Swivel Base (pdf p. 198), CRT (pdf p. 201), Chassis/Wiring Harness (pdf p. 207)
  • Upgrades — TV or TV/FM Tuner (pdf p. 211), 5400/5500 DIMM Upgrade (pdf p. 214), Communications Card Installation (pdf p. 222), External Video Connector (pdf p. 227), PCI Card (pdf p. 233), L2 Cache Installation (pdf p. 243)
  • Additional Procedures — Battery Verification (pdf p. 245), Battery Replacement (pdf p. 247), Cuda Chip Reset (pdf p. 249), Logic Board Reset (pdf p. 250), PM 5500/225 Logic Board Identification (pdf p. 253), Processor Fan (pdf p. 260)
  • Adjustments — Light Meter Setup (pdf p. 263), Geometry (pdf p. 269), Video (pdf p. 286), High Voltage (pdf p. 301)
Notable content
The High Voltage adjustment is the interesting one: it is one of very few places where an Apple Service Source volume asks the technician to set an EHT level rather than simply replace a module. Note also that Take Apart prints two different procedures for the power supply, the analogue board and the speakers — “Original Version” and “Rev. B” — so identify the revision before ordering a part. Work on the high-voltage section only after following CRT Discharge Procedure.
  • No schematic, no parts list, no component values.
  • The Adjustments chapter is Light Meter Setup, Geometry, Video and High Voltage.
Pages that cite this document
This machine contains a high-vacuum picture tube and a live analogue board. Follow CRT Discharge Procedure before working inside one.
Download: Powermac.perf_5400.5500.pdf (6.9 MB)
