Atari 5200
Revision as of 08:58, 27 September 2026 by Josh (talk | contribs) (Link the documentation page for each cited manual, keeping the File: link as the direct download)
Atari 5200
Atari 5200 4-port model with controllers
ManufacturerAtari, Inc.
TypeHome video game console
ReleasedNovember 1982 (4-port)
1983 (2-port)
Intro priceUS$269 (1982)
CPU6502 variant, Atari C014806, at U2/A2
Memory16 KB DRAM
StorageROM cartridge
DisplayANTIC + GTIA, NTSC only
SoundPOKEY, 4 channels
OS / Firmware2 KB ROM (Atari C019156)
PredecessorAtari 2600
Model no.CX5200
The Atari 5200 SuperSystem is a home video game console released by Atari, Inc. in November 1982. It uses the same custom chipset as the Atari 8-bit computer line — ANTIC, GTIA and POKEY around a 6502 — in a console package. It was sold in North America only; there was never a PAL Atari 5200.
This page concentrates on the information a repairer needs. Atari's CX5200 Field Service Manual is the primary source for almost everything below.[1]
The three PC boards
Atari shipped three different main boards, and they are not interchangeable for service purposes — the designator prefix itself changes between them.[1]
Production boards
Board Ports Designators Identification Notes
CA018087 (original 4-port) 4 U1–U29 — Needs retrofit kit CA023019 to work with the CX55 VCS cartridge adaptor
CA020108 (4-port "Universal") 4 A1–A28 Serial number on the base has a + as its third character U4 and U15 (74LS244) deleted; U14 and U28 replaced by a 74LS125 at A14 and a 74LS51 at A15; provisional circuitry for the VCS cartridge adaptor added
CA021374 (2-port) 2 A1–A28 Two controller ports As the Universal board, plus: ports 3 and 4 and their discrete components removed; A12 and A13 removed; manual switchbox instead of the automatic one; the power adaptor plugs into the console instead of the switchbox
Atari's serial-number identification for the Universal board is a plus sign as the third character, for example "AT+213…".[1] Collectors usually call this the "asterisk" board.
Integrated circuits
Chip locations
Function Device CA018087 CA020108 / CA021374
Microprocessor Atari C014806 (6502 variant) U2 A2
Display list processor ANTIC, Atari C012296 U3 A3
Graphics GTIA, Atari C014805 U5 A5
Sound, pots, keypad scan POKEY, Atari C012294 U7 A7
System ROM Atari C019156 (4096 × 8) U8 A8
Reset and video buffer 4050 U1 A1
Address decode 74LS139 U6 A6
Keypad multiplexers 4052 U9–U13 A9–A13 (A12, A13 absent on the 2-port)
DRAM address multiplexers 74LS258 U16, U17 A16, A17
RAM, 8 × 16 K × 1 DRAM MB8118 or 4516 family U18–U25 A18–A25
Power on/off latch 4013 U29 A26
+5 V regulators 78M05 (Atari C014348) VR1, VR2 VR1, VR2
The 6502, ANTIC, GTIA, POKEY and ROM identifications come from Atari's parts lists and the console schematic;[1][2] the remaining functional descriptions are from the Console5 TechWiki, a secondary source.[3]
The 5200 schematic marks the RAM as MB8118-12 with the note "typical 8 chips"; Console5 lists the equivalent 4516. Either way these are 16 K × 1 dynamic RAMs, eight of them, giving 16 KB.[2][3]
Power
This is where the 4-port and 2-port machines genuinely differ, and where most surviving 5200s fail.
4-port: power through the switchbox
The original and Universal 4-port consoles have no power connector of their own. Power and RF share one cable to the CX522 switchbox, which also contains a relay that switches the television between aerial and console.
  • Power pack: CX521 AC/DC Power Adaptor, Atari P/N C018187. Output: 9.3 volts DC at 1.95 A.[4] It is a linear supply: transformer, bridge rectifier, a 3300 µF/25 V reservoir and an MDL-5 fuse, all inside the brick.[2]
  • Atari's tech tip warns explicitly: do not use an HCD power adaptor with the CX5200 — it will damage both the adaptor and the switchbox.[4]
  • The switchbox select switch has two positions: NORMAL, which lets the console switch the television automatically when the power switch is pressed, and STANDBY, which allows television viewing while the console is on.[1]
2-port
The 2-port console takes its own adaptor (Atari A.C. adaptor assembly CA021673) directly into the rear of the case, and uses a conventional manual switchbox.[1]
Inside the console
Regulation is by two +5 V regulators, VR1 and VR2, on a heatsink assembly (Atari CA019069). Atari's parts list gives the device as a 78M05 (C014348, the 500 mA part, the same regulator used in the Atari 2600); the slightly earlier schematic prints LM340T-5. Each regulator works with an MJE-210 power transistor, and a +9 V rail is taken from the unregulated supply as well as the two +5 V rails.[1][2]
Expected readings, from Atari's diagnostic flow charts:[1]
Test point Expected If wrong
Core of J3 (power/RF input) 10–12 V DC RF cable, switchbox or power pack
Input of VR2 +12 V
Output of VR2 (pin 3) +5 V Check for a short on the output
Pin 13 of U29 (A26), the 4013 latch Toggles between 13 V and 0 V when the power switch S2 is pressed Power latch fault
Pin 3 of the RF module +5 V L13, the RF module, or an open to VCC2
The cartridge carries the +5 V jumper
The console's +5 V distribution is jumpered through the cartridge: the schematic marks a link between J1 pins 36 and 18 as "jumper in plug-in ROM cartridge".[2] A 5200 with no cartridge in the slot is therefore not fully powered. This is designed behaviour, not a fault, and it is worth knowing before you start probing a "dead" console with an empty slot.
Capacitors
The 5200 has remarkably few aluminium electrolytics — essentially one, and its value depends on the board:[1][3]
Ref CA018087 (original 4-port) CA020108 and CA021374 Type
C45 4700 µF 25 V (Atari C016033) 47 µF 25 V (Atari C020121) Electrolytic, radial
C41, C42, C119, C144 10 µF 20 V 10 µF 20 V Tantalum, axial
C13, C14 820 pF 25 V 820 pF 25 V Polystyrene, audio circuit (Atari C018621)
C43, C44 0.22 µF 100 V 0.22 µF 100 V Polyester, radial
C19, C99–C106 0.047 µF 100 V 0.047 µF 100 V Polyester, radial
Everything else on the board is a ceramic axial. The big 4700 µF at C45 on the original 4-port board is there because that board's supply comes through the switchbox cable; the later boards, which take a shorter or separate supply path, use only 47 µF in the same position.
Controllers
The CX52 controller (Atari CA018107, used on all models) has an analogue joystick, a 12-key keypad, two fire buttons on each side and three select buttons.[1] The keypad, fire buttons and select buttons all run through a single flex circuit, which is the controller's main wear item.
On the console side, the keypad matrix is scanned through five (or three, on the 2-port) 4052 analogue multiplexers, with a 470 Ω series resistor and a 470 pF capacitor on each port line.[2] A controller fault that affects one port only is usually the flex circuit or the port's 4052; a fault affecting all ports points at POKEY.
Atari's potentiometer adjustment procedure gives real numbers to work to:[1]
  1. With the arm off the wiper shaft, adjust the shaft so that the reading between pot terminals 2 and 3 is 5 kΩ–20 kΩ.
  2. Fit the arm in the documented position and reassemble.
  3. With the joystick at position 1, the reading through the cable (connector pins 11 and 9, and pins 10 and 9) should be no greater than 50 kΩ.
  4. At position 2 the reading should be at least about 100 kΩ greater than at position 1.
  5. If the test fails, replace the pots; if the pots have already been replaced, replace the actuator plates, which must be replaced as a complete unit with the slide block.
The non-centring design uses a rubber boot rather than springs. Atari published a boot replacement procedure and a knob puller tool (FC100214) because the knob is difficult to remove without one.[4]
Known factory faults
  • Rockwell 6502 MPUs with date code 8250 and later (stamped with the letters RC) have a timing defect. Atari's factory modification adds an R–C network on the component side of the board at U14A pin 1 and U6A pin 4. The network does not need to be removed to use another manufacturer's MPU or a Rockwell part with a different date code.[4]
  • CX55 VCS cartridge adaptor compatibility. Original CA018087 boards need retrofit kit CA023019, which solders wires to pins 24, 30 and 11 of J1. Atari's procedure carries an explicit warning: if the red jumper wire is grounded, the 5200 power adaptor will burn out.[4]
Cartridge slot
The cartridge socket J1 has at least 36 positions; the +5 V jumper occupies pins 18 and 36.[2]
Maintenance and repair
Schematics
Atari 5200
Motherboard RF Switch Box and Power Supply Accessories
Atari 5200 Console Schematic
Atari 5200 RF Switchbox and Power Supply Schematic
Atari 5200 Accessories Schematic
Service documentation
  1. ↑ 1.00 1.01 1.02 1.03 1.04 1.05 1.06 1.07 1.08 1.09 1.10 Atari, Inc., CX5200 Field Service Manual, document FD100127 Rev. 4, July 1983, Sunnyvale, California. Section 1, console and PC board differences; Section 2, silkscreens and schematics; Sections 3/3A, testing; Sections 4/4A, diagnostic flow charts; Section 6, game controller; Section 8, parts lists for all three boards. Hosted here as Atari CX5200 Field Service Manual (PDF).
  2. ↑ 2.0 2.1 2.2 2.3 2.4 2.5 2.6 Atari, Inc., Atari 5200 Programmable Video Game System schematics, sheet 1 (processing, I/O, ROM and RAM) and sheet 2 of 2 (RF switchbox and power supply), 23 February 1983. See File:Schematic Atari5200 4000.png and File:Schematic Atari5200 RFSwitchbox 2000.png.
  3. ↑ 3.0 3.1 3.2 Console5 TechWiki, "Atari 5200", chip info and capacitor list. Secondary source: a capacitor-kit vendor's component list, not manufacturer documentation.
  4. ↑ 4.0 4.1 4.2 4.3 4.4 Atari, Inc., Atari 2600 and Atari 5200 Field Change Orders, Upgrade Bulletins and Tech Tips: Tech Tip, model ATARI CX5200, 17 November 1982, "CX5200 Power Adaptor"; Tech Tip, model CX5200, 20 January 1983, "Defective Rockwell 6502 MPU on CX5200 PC Board"; and the CX5200 retrofit procedure for kit CA023019. Hosted here as Atari 2600 and 5200 Field Change Orders and Tech Tips (PDF).
