Macintosh Performa 6420
Revision as of 13:43, 27 September 2026 by Josh (talk | contribs) (Apple Service Source: the processor is a PowerPC 603ev, not a 603e; the DIMM specification differs between the Performa (168-pin fast-page 70 ns) and the Power Macintosh (168-pin EDO 60 ns) versions of the same machine; the 6420 ships with up to 24 MB and has 256K L2 as standard; the 6400/180 shipped a 4X AppleCD 600i and a 1.2 GB drive; the built-in speaker is a single MONO full-range speaker/subwoofer, stereo only via external speakers; and the input is 90-130 or 180-264 VAC set MANUALLY on...)
Macintosh Performa 6420/200
TypePersonal Computer
ReleasedNovember 12, 1996
DiscontinuedAugust 1, 1997
Intro pricen/a
CPUPowerPC 603ev @ 200 MHz
Memory16 MB RAM (Apple: ships with up to 24 MB), expandable to 136 MB
Storage2.4 GB IDE hard drive, 8X CD-ROM
DisplaySupports up to 1024ร—768 @ 8-bit
Sound16-bit stereo in/out with SRS 3D Surround; one mono full-range speaker/subwoofer
Dimensions16.0" H ร— 7.8" W ร— 16.9" D (40.6 ร— 19.8 ร— 42.9 cm)
Weight44.5 lbs (20.2 kg)
OS / FirmwareSystem 7.5.3 โ€“ Mac OS 9.1
PredecessorPerforma 6360
SuccessorPower Macintosh 6500
CodenameAlchemy (logic board)
Model no.M3548
The Macintosh Performa 6420 is a personal computer designed, manufactured and sold by Apple Computer from November 1996 to August 1997.[1] It is the European and Asian version of the Performa 6400/200, featuring identical specifications: a 200 MHz PowerPC 603e processor, 2.4 GB hard drive, and Apple's "InstaTower" mini-tower case with SRS 3D surround sound and integrated subwoofer.
The Performa 6420 shares its Alchemy logic board with the Performa 6400, Performa 6410, Performa 6360, and Power Macintosh 5400.
Hardware Overview
The Performa 6420 is functionally identical to the Performa 6400/200:
  • Processor: PowerPC 603ev at 200 MHz with integrated FPU (soldered)
  • RAM: 8 MB soldered on-board plus two 168-pin DIMM slots (70 ns), 16 MB standard, expandable to 136 MB
  • Storage: 2.4 GB IDE hard drive, 8X CD-ROM, 1.44 MB floppy
  • Video: 1 MB system RAM dedicated to video
  • Audio: SRS 3D surround sound with integrated subwoofer
  • Expansion: 2ร— PCI slots, communications slot, video I/O slot, TV tuner slot
  • Modem: 28.8k internal modem
Regional Variants
Model CPU Speed Hard Drive Region Order Number
Performa 6400/200 200 MHz 2.4 GB North America Various
Performa 6420/200 200 MHz 2.4 GB Europe, Asia, Japan M5513J/A (Japan)
The Performa 6420 uses a PowerPC 603e processor soldered to the Alchemy logic board and cooled by a fanless heatsink. The processor is a 32-bit design with a 64-bit data path to main memory. The 40 MHz system bus provides communication between the CPU and other components.
Third-party processor upgrades are available that can override the soldered CPU via the L2 cache slot.
Memory and Storage
RAM Configuration
Specification Details
RAM Type 168-pin DIMM
RAM Speed 70 ns
Standard RAM 16 MB
Maximum RAM 136 MB
Motherboard RAM 8 MB (soldered)
RAM Slots 2
Storage Systems
Component Specification
Hard Drive Interface IDE
Standard Hard Drive 2.4 GB
Optical Drive 8X CD-ROM
Floppy Drive 1.44 MB 3.5" (manual inject)
Display and Graphics
Video memory is integrated, with 1 MB of system RAM dedicated to video functions:
Resolution Color Depth
640ร—480 16-bit (Thousands)
800ร—600 16-bit (Thousands)
832ร—624 8-bit (256 colors)
1024ร—768 8-bit (256 colors)
A second display can be supported with the addition of a PCI video card.
Audio Capabilities
The Performa 6420's "InstaTower" case includes an integrated subwoofer speaker and supports SRS 3D surround sound. A bass level control knob on the rear of the case adjusts subwoofer output when external speakers are connected; without external speakers, the internal speaker provides full-range audio.
Two audio output jacks are providedโ€”one on the front panel and one on the rear. Connecting headphones to the front jack disables the internal speaker and rear output.
For detailed maintenance practices including cleaning, PRAM battery management, and general upkeep, refer to the dedicated Macintosh Performa 6400 General Maintenance page.
Detailed capacitor replacement guidelines for the logic board can be found on the Macintosh Performa 6400 Capacitor Replacement Guide page.
A comprehensive troubleshooting guide addressing power issues, startup problems, video issues, and other common problems is available on the Macintosh Performa 6400 Troubleshooting page.
Sub-system Specification (Macintosh Performa 6420, 1996)
CPU PowerPC 603ev @ 200 MHz
Bus width 64-bit data path
System Bus 40 MHz
ROM 4 MB
RAM 16 MB (expandable to 136 MB)
L1 Cache 32 KB
L2 Cache 256K, standard on the 6420
Video Up to 1024ร—768 @ 8-bit
Sound SRS 3D surround with subwoofer
Storage 2.4 GB IDE HDD, 8X CD-ROM
Ports ADB, Serial ร— 2, SCSI, Audio I/O
Power Specifications
Specification Value
Input voltage 90โ€“130 or 180โ€“264 VAC, set manually on the rear voltage switch
Frequency 47โ€“63 Hz
Maximum power 220 W continuous (Performa/Power Macintosh 6400); 140 W on the 6500
Apple service data
Apple's own figures, from the Performa/Power Macintosh 6400 and 6500 Series Service Source volume hosted on this wiki.[2]
Item Apple's figure
Processor PowerPC 603ev throughout: 180 MHz (6400/180, 6410), 200 MHz (6400/200, 6420), 225/250/275/300 MHz (6500)
Processor bus 64-bit wide, 40 MHz on the 6400 and 50 MHz on the 6500, supporting split address and data tenures
DRAM (Performa 6400, 6410, 6420) 16 MB — the 6420 ships with up to 24 MB — expandable to 136 MB in two sockets, 168-pin fast-paged mode, 70 ns or faster, 2K refresh
DRAM (Power Macintosh 6400) 16 MB, expandable to 136 MB, 168-pin extended data out (EDO), 60 ns or faster, 1K or 2K refresh — not the same part as the Performa takes
DRAM (6500) 32 MB (48 MB on some /275, 64 MB on the /300), expandable to 128 MB, 168-pin 5-volt buffered EDO, 60 ns or faster, 2K refresh
ROM / PRAM 4 MB ROM; 8K of non-volatile parameter memory
VRAM 1 MB built in on the 6400; 2 MB of 88 MHz synchronous graphic RAM on the 6500
Level 2 cache Optional 256K on the 6400, 6410 and 6500/225โ€“250 base; standard 256K on the 6420 and on the 6400/200 with Zip drive; standard 512K on the 6500/275 and 6500/300
CD-ROM AppleCD 600i on the 6400 (4X); AppleCD 1200i 8X on the 6410, 6420 and the 6400/200 with Zip; 12X or 24X on the 6500
Hard drive 1.2 GB IDE (6400), 1.6 GB (6410), 2.4 GB (6420 and 6400/200 with Zip), 2 GB (6500/225), 3 or 4 GB (6500/250), 4 or 6 GB (6500/275, /300)
SCSI One external port supporting up to six external devices, or five if the optional Zip drive is fitted
Expansion Two PCI slots; one communications slot (PCI-bus configuration); a TV/FM tuner port; a video-in slot whose 60-pin DAV connector takes an optional real-time video card, with an adapter cable for backward compatibility with Power Macintosh 5200 DVA cards
Sound 16-bit stereo in and out with SRS 3D Surround Sound; sample rates 11.025, 22.05 and 44.1 kHz; one rear line-level output, one front headphone jack, one stereo input
Speaker One built-in, full-range, monophonic speaker/subwoofer. Stereo comes only from external speakers, headphones or the monitor
Electrical 90โ€“130 or 180โ€“264 VAC, set manually by the voltage switch; 47โ€“63 Hz. 220 W maximum continuous on the 6400; 140 W maximum continuous on the 6500
Case Height 16 in. (406 mm), width 7 13/16 in. (198 mm), depth 16 7/8 in. (428 mm); 44.5 lb. (20.18 kg) without CD-ROM
Expansion bay Configured for 5.25-inch SCSI devices; a 3.5-inch SCSI device fits with a modified carrier
PRAM battery On a hook-and-loop base with a pull-up connector. Verify on the 10 V DC scale; replace below 3.0 V. Apple warns it is a lithium pack that could explode if mishandled — neutralise leakage with sodium bicarbonate, never vinegar
The voltage switch
This machine has a manually set voltage switch and Apple's own wording is that it "must be set correctly to avoid damaging the computer." Insert a screwdriver in the slot and set it to show "115" for supplies between 100 and 130 V or "230" for supplies between 200 and 270 V. Apple gives the line voltage as 90โ€“130 or 180โ€“264 VAC configured manually, at 47โ€“63 Hz — not a universal auto-ranging input. Apple's volume also prints a country-by-country voltage table, and notes that some countries use two standardised voltages.[2]
Things that are not faults
  • With external speakers attached the subwoofer works as a bass speaker; without them it produces
 full-range sound instead of just bass. The subwoofer balance control only does anything when
 external speakers are connected.[2]
  • Inserting a plug into either output jack disconnects the internal speaker, and the rear jack is
 muted when headphones are in the front jack. That is by design.[2]
  1. โ†‘ Apple Macintosh Performa 6420/200 Specs, EveryMac.comโ€”link(accessed 2026-02-10)
  2. โ†‘ 2.0 2.1 2.2 2.3 Apple Computer, Performa/Power Macintosh 6400 and 6500 Series, Service Source. Hosted here as Performa/Power Macintosh 6400 and 6500 Series Service Source (File:Powermac.perf_6400.6500.pdf). Basics, Specifications and Additional Procedures — Battery Verification chapters.
